Is there a thread on how to bleed the coolant system? | FerrariChat
Discussion in '308/328' started by oceanview328, Jan 21, 2013.
  1. oceanview328
    oceanview328 Karting
    Dec 7, 2012
    214
    Charleston, SC
    Ed
  2. Ehamilton
    Ehamilton F1 Rookie
    2,519
    Durham, NC; USA
    Eric Hamilton
    There's such a thread now, but it's pretty straightforward. Start with the motor cold.
    1) Remove cap from overflow tank, verify fluid level. If you stick your index finger down into the reservoir the tip should be in the water. Leave cap off.
    2) crack open the bleeder screw at the radiator (top, passenger side, rear edge). Air will flow out and then coolant; close the bleeder again when you're getting just coolant.
    3) if you have a bleeder screw on the top of the thermostat housing, open it up. Unless you've dropped a few tens of dollars on Verell's magic bolt (highly recommended) it'll come all the way out - don't drop it. Tighten it back down when you're getting just coolant.
    4) top up the reservoir to the finger-dipping level if necessary, replace cap, drive.
  3. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Is there a thread? It's only one of the most discussed 308 subjects of all time! I think fchat's search feature might be in order.
  4. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    As noted, there are TONS of threads/opinions re this subject but just do what Ehamilton posted; that's all that is required. If periodic bleeding is required, the cooling system needs servicing to discover where the air leak is coming from. You should never have to bleed between coolant changes.
  5. oceanview328
    Dec 7, 2012
    214
    Charleston, SC
    Ed
    Thanks guys.
    I did search without finding anything to start with. But, I went back and broadened my search to include all groups (not just 308/328) and then I found a couple.
    I still have two questions:
    1. Is the radiator bleed screw supposed to have some type of copper washer or something? Is it a common thing I can easily find?
    2. I filled the reservoir almost all the way (I may have over filled it) and once the engine warmed up, water came out of the overflow tube for a while and then stopped. So, I replaced the radiator cap and topped off the reservoir and once the engine warmed up, it overflowed again. Is it supposed to do that if it's overfilled?
  6. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,301
    1) Yes there should be a washer there - think its fibre - but as long as its not leaking it should be OK.
    2) See recent thread http://www.ferrarichat.com/forum/308-328/395741-expansion-tank-release-87-328-a.html
    You almost certainly did overfill it to start with. As long as the cap is working right it will keep spitting coolant out till it finds the level it wants to be at. When cold the expansion tank will be less than half full (seems to be the concensus).
  7. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    Yep - it will overflow until the coolant level is "correct." Remember, it is an expansion tank, NOT an overflow tank. It is there to provide room for the coolant to increase in volume as it gets hot. If you fill the tank - or even 1/2 fill it - there is insufficient room to accommodate the expanded volume and over it goes until the excess is eliminated.
    Oops - sorry, I see that I was posting while another post answered the question...
  8. oceanview328
    Dec 7, 2012
    214
    Charleston, SC
    Ed
    Thanks again guys.
    Yes, my radiator bleed screw is leaking and I can't get it to stop. I also don't see it (or even the bleed screw itself) on any of the parts sites' exploded views.
    Where can I find this little washer?
  9. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,301
    Not 100% certain from the parts diag but I think 11194071 which substitutes to 11194074
    TAV 22, parts 13&14 (I think!)
    Otherwise, get creative with some kind of fibre washer from your local plumber's merchant :)
  10. craiggo
    craiggo Formula Junior
    406
    Redwood City
    Craig
    One more thing to do. Once it gets to temp, turn on the heater both sides, and let it circulate for a few minutes. After that, you my get more bleed off from the expansion tank.
    Craig
  11. shawxhurst
    shawxhurst Formula Junior
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    There are excellent step-by-step instructions at http://www.birdmanferrari.com. A rubber O-ring will work just fine on the radiator bleed screw. There is also a thread on this by Verell
  12. BigTex
    79,321
    Houston, Texas
    Bubba
    Leave 2" to 3" air in the Expansion Tank...no worries...
    Recheck it after bleeding fluid of course...when cool!!!
  13. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    I bought a rubber little circle at homedepot in the plumbing section. It's the best seal I have used.
    Also, I used a Stant pressure tester (hooks to the expansion tank) so that I could put pressure In the system. I found a few leaks at the various couplers and now all is sealed. I wish I would have done this lone ago.
  14. Ehamilton
    Ehamilton F1 Rookie
    2,519
    Durham, NC; USA
    Eric Hamilton
    You can replace the whole thing from Ricambi, try: Ferrari Parts : 95800014 : 95800014 Radiator Bleed Thumbscrew.
    Or you can find an ordinary faucet washer, the same little rubber thing you'd use to repair a dripping faucet in your house, that's the right size. Any hardware store will have them.
  15. oceanview328
    Dec 7, 2012
    214
    Charleston, SC
    Ed
    Thanks guys. This is my first time checking out the Birdman web site. VERY cool stuff.
  16. bill brooks
    bill brooks F1 Veteran
    BANNED Silver Subscribed
    Jul 30, 2007
    5,961
    waynesburg,pa
    bill brooks
    #16 bill brooks, Jan 22, 2013
    i kinda like this solution to air purging.
    it can be done hot or cold with no fear of scalding.
    also the towel beneath the schrader valve prevents water from going where you don't
    want it to.
  17. oceanview328
    Dec 7, 2012
    214
    Charleston, SC
    Ed
    Wow, that motor is Cleeeeennnnnn.
    Looks cool. Where did you get it?
  18. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
  19. Verell
    Verell F1 Veteran
    May 5, 2001
    7,020
    Groton, MA
    Verell Boaen
    CAUTION:
    Only use a vacuum refill system if you are positive your hoses are in very good condition. There's a long sad thread about what happened to Birdman when he vacuum refillled his Mondial & then headed out for Montreal.
    Short version is with old hoses, when the vacuum collapses them they shed flakes of rubber that clog up the radiator and heater elements. Yes, they have to be replaced!
  20. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    I actually didn't need much suction and regulated it as I went. I didn't let the valve suck the hoses flat :D
  21. bill brooks
    Jul 30, 2007
    5,961
    waynesburg,pa
    bill brooks
    thanks.
    we eat dinner on it as often as possible.
  22. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,282
    Ventura, California
    Robert Garven
    #22 robertgarven, Jan 23, 2013
    the real trick is:
    get a paper cup. Poke a hole in the top near the edge with a sharp awl. Stick a sharpie pen in there to make it wider. Slip it over your bleeder screw. Loosen screw. Start engine. When thermostat opens and water bleeds out shut bleeder screw. Pour coolant in container to recycle. This way you dont drip coolant all over your radiator etc.
    here is another clean engine! :p
