Is there a head puller jig for a 355? | FerrariChat
Discussion in '348/355' started by yelcab, Nov 14, 2018.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,701
    San Carlos, CA
    Mitchell Le
    I just pulled a head on a 355 with corrosion around a single head stud. That was bad enough to take all day. Got me to thinking, did someone design a head puller jig for a 355? This is common enough of a problem on 308 that there are tools for this out there. One can mount a plate to the top of a 355 heads using the number of M6 studs, but where would the pressure be put against the block / head studs?
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    Wouldn't surprise me if one of the pro wrenches came up with something.
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I don't see a way to do it. If you used the spark plug thread as a jack location that would be very risky to the threads and pushing on the piston tops.
    Using a wood wedge (gently) around the perimeter at the deck surface would probably be the best.
    I recall one of mine being pretty stubborn and I just used a rubber mallet to tap around the head.
  4. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    If they are very tight I grab them with a cherry picker put a little pressure and wack them with a dead blow hammer a few times until they come loose, put them back on with the picker also when they weight too much to handle at my old age.
    xo
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    getragV8, INRange and Dave rocks like this.
  6. Nader
    Nader Formula Junior
    Feb 12, 2011
    990
    East of Seattle
    If the belts are off and valves are closed, stuff a ball of string in the cylinders through the plug holes, then manually crank the engine.
  7. fatbillybob
    Aug 10, 2002
    29,433
    socal
    Gearhead's guide to Thanksgiving.....
    SoCal1 likes this.
  8. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,295
    CT
    John Kreskovsky
    Vinegar.
    ernie likes this.
