Is the external shift gate required for the transmission? | FerrariChat
Discussion in 'Technical Q&A' started by andrew911, Nov 18, 2005.
  1. andrew911
    andrew911 F1 Rookie
    2,893
    Northern NJ
    I have an interesting technical question- no idea why I thought of it....is the external shift gate needed in Ferraris? If you somehow removed it, would the shifter still have "gates" within the transmission to guide the shifter as in a typical stick shift, or is the outside gate literally needed to keep the shifter in line? I love the gate and wouldn't want to see anyone remove one, it's more of a curiousity question...
  2. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    It's not needed.
  3. Steve Magnusson
    26,509
    I'd have to disagree, and say, that for "reasonably safe" operation, it is required.
    It's a little like asking: "Do I need a windshield to drive on the freeway?" -- "no" is a technically correct answer (ignoring the vehicle laws), but that wouldn't be the safest thing to do -- JMO.
  4. matteo
    Aug 1, 2002
    13,748
    Heir Butt
    I was basing that on sitting in the garage without the shiftgate on. I guess I need to read the entire thread. I would never drive the car without it.
  5. andrew911
    andrew911 F1 Rookie
    2,893
    Northern NJ
    Could it be different from model to model as well i.e. 330 vs. 1980's testarossa vs. 2000 360 or 550?
  6. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,327
    Canada
    Newman
    Having had a 308 gearbox in pieces I would say the gate is required. All transmissions Ive ever had apart need a gate somewhere (usually directly under the shifter inside the transmission housing). Ferrari chooses to expose it and its a brilliant idea.
  7. LarryS
    LarryS Formula Junior
    Nov 14, 2003
    302
    Fremont, CA
    Larry S
    Curious... What parts is a Ferrari transmission missing, that say a Fiat X1/9 has, that would require the external shift gate?
  8. Newman
    Dec 26, 2001
    14,327
    Canada
    Newman
    Ferraris are missing the internal gate (not all but a 308 sure is).
  9. Boxer12
    Boxer12 Formula 3
    Jun 1, 2003
    1,672
    Considering that the shift lever never touches the shift gate, I don't see how it is 'required' or 'necessary for safe ops'. Sure, it guides you to the correct gear if you have a slipout or something, but that doesn't much happen. Most of the time, you never look at it and never touch it. Just my 2c.
  10. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,855
    MO
    Omar
    I love the open gate design.
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,565
    The twilight zone
    The Butcher
    I've driven mine with the gate off, it works just fine. The problem is of course there is no reverse lock-out and it's much easier to select the wrong gear, like 4 or R instead of 2....the up side is the need to perfectly align the linkage goes away.
  12. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    32,524
    E ' ' '/ F
    Merritt Tockkrazy
    There's a reverse lock out on the 3x8?
  13. Auraraptor
    Sep 25, 2002
    13,855
    MO
    Omar
    You press down on the shifter stock to get into reverse.
  14. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Correct...well, at least, correct as long as your shifter tab and/or gate tab haven't been ground down or worn off.
    The reverse lockout tab on my shifter looks as though someone dremmeled it off. Car goes right into reverse without pressing down on the shifter!
    Yikes!
  15. docweed
    docweed Formula Junior
    Dec 8, 2004
    452
    Morgantown,WV
    Chuck Stewart
    Huh???
  16. Auraraptor
    Sep 25, 2002
    13,855
    MO
    Omar
    Proper procedure to engage reverse on a 328 (assuming everything is factory)
    1. Depress clutch, engage first
    2. While clutch still depressed move up to the center of the gate, keeping on the left side of the gate (where there is R and 1st)
    3. When you reach the center of the gate press gently down on the shifter stock, it should go down an a little (inch or so)
    4. While still pressing downward, move the lever into reverse
    If you don't first go into 1, sometimes you will get a grind since reverse isn't syncroed.
    If you don't need to press down, you may have either a worn bushing or as No Doubt stated, the mechanism might have been modified from factory.
  17. Jdubbya
    Jdubbya The $10 Trillion Man
    42,273
    PNW
  18. hetek
    hetek Karting
    Aug 8, 2005
    141
    LI, NY
    What about those aftermarket gates that have the teeth beveled at an angle. Claims that it makes it easier grabbing the next gear and quicker shifts.
    Doesn't this somehow force the tranny to wear?
  19. andrew911
    andrew911 F1 Rookie
    2,893
    Northern NJ
    This bascially answers my original question- all transmissions have an internal gate. But other's mentioning they actually drove their cars without the exposed gate in place, and another comment that someone said their stick never really touches the gate makes me wonder if there is still some sort of an internal guide of some sort.
    Again, no idea of why I thought of this- more of an engineering curiousity of mine.
  20. Newman
    Dec 26, 2001
    14,327
    Canada
    Newman
    There is no other gate inside the gearbox but the detent/lockout mechanism in the bottom of the gearbox gives you the engagment feel and holds the shifter/syncro hub in place. Without the gate, if you chose to, you could apply pressure to 2 shift rods at the same time and if you were a complete moron and were deliberate enough, you could engage 2 gears at the same time destroying your gearbox in an instant. The gate gives you dirrection and insurance that you wont screw something up so it is required and all cars have some sort of gate somewhere on the car or gearbox for this reason.
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,565
    The twilight zone
    The Butcher
    No, but it does ever so slightly reduce a safety factor. Without the plate in place, the internal linkage can operate 2 gear sliders at the same time. If the trans shifts into 2 gears at the same time, it will fail catastrophically. There are interlock pins inside the trans in addition to the external plate to prevent that...but the pins can wear. But I guess the most likely thing in selecting 2 at the same time is that the pin do work and you simply get no gear at all, the lever will feel stuck in neutral until you slide a little to one side or the other. You can also go too far to the side and miss all the gears.
    The reason I had mine out without the shift plate is that I was having trouble shifting and wanted to see if it was a trans problem or just a linkage alignment issue....it was the linkage.
    edit:
    I need to learn to type faster, it looks like Newman posted the answer while I was still typing :)
  22. Newman
    Dec 26, 2001
    14,327
    Canada
    Newman
    Ooooops, almost verbatim.
