360 - Is the 360 a reliable car? | FerrariChat
360 Is the 360 a reliable car?
Discussion in '360/430' started by Mcgigins, May 19, 2020.
Tags:
  1. Mcgigins
    Mcgigins Rookie
    May 13, 2020
    1
    McGigins
    I’ve heard conflicting opinions from a few different 360 owners about the reliably of the 360. I’m hoping an owner on here can clear up the confusion.
  2. mello
    mello F1 Veteran
    5,042
    CA Bay Area
    Steve
    I'm going to start by asking, "what are the negative things you've heard?"
  3. Apollo 11
    Apollo 11 Karting
    Feb 11, 2019
    114
    San Francisco, CA
    Randy
    I've only owned mine for just over a year (2003 360 Spider) with just under 20K miles on it. I added about 3k of the 20k. Other than the yearly service, I have had nothing go wrong with it. It came with 10 years of service records and had been serviced regularly.
    Graz likes this.
  4. hwyman
    hwyman Formula Junior
    Jun 25, 2015
    329
    Canada / Los Angeles
    Depends on a lot of factors.... I had a buddy own a 99 that he never serviced and trashed for 10 years and nothing went wrong. Others have lots of small issues regularly (which in Ferrari world costs alot) .... Its part luck of the draw and despite what I said about my buddies unicorn.. how it was maintained. Definitely a car used a modest amount each year and serviced each year will be more reliable than a garage queen. They're still cars that benefit from regular use
    SpencerMarks likes this.
  5. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Mighty Joe likes this.
  6. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Summary:
    Set aside money for repairs as just like any other car they will break.
    The difference is the amount of money it takes to repair it as the parts and labor are not cheap.
    These cars are aging so it will require repairs as parts age they break.
    If you can do the work yourself you can save a lot of money. And you can find parts for much less, just do a Google search.
    The last 3 months of my F430 ownership I spent almost $13K. I have a post here somewhere.
    Not complaining, just sharing facts.
    To me, Ferrari's are just like family when it comes to spending money.
    They are worth every penny as the smile they put on your face every time you see it and drive it is priceless.
    pnoyR35 and MalcQV like this.
  7. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,742
    Memphis, TN
    #7 EastMemphis, May 19, 2020
    Reliable is a relative term. Is a 360 a reliable Ferrari? Maybe. Is it as reliable as a Honda CR-V? No.
    I've had my 360 for a little more than six months and 1,000 miles and it has always started and driven. Has it run without problems? No. I've had to fix a lot of little things but nothing that I can't personally handle. If I had brought it to a service place every time something weird happened, it would cost thousands. By maintaining it myself, costs have been modest.
    One thing about the 360. It's a car that the average person with mechanical experience can handle. The parts are available. There are videos online for common issues. There's a rich aftermarket. There's the wealth of experience and documentation here and other places online. Ferrari's seem to be built to be taken apart and put back together.
    What I would say about the 360 is that it appears to be a car with robust guts and fragile sub-systems. So get a car with good guts and you're likely to be able to fix the rest yourself.
    The other side of the coin is what you get out of ownership. I've had all kinds of sports cars, this is my first F car. The difference is quite stunning in every aspect. I love the hand made quality of my 360. I love the feel the car gives me as I race through twisties, hitting my shift points on the money (I have a gated). I love the sound and fury at 8k RPM's as I zoom t 120 MPH with the top down. What is that worth?
  8. SRLC716
    SRLC716 Formula Junior
    286
    Buffalo
    Sam
    This is nail on the head. It’s PRICELESS.
    To OP, I’ve found mine to be reliable with a couple of minor issues which I think are normal for a car of its age. Water pump, ac, plugs. Otherwise she runs strong.
    EastMemphis likes this.
  9. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    817
    S La
    F1 and tops are responsible for the bad reputation. Stick shift coupe complaints and problems are rare. So if you want a look at me, look at me, finger flip shifter, you will have to pay to play and that is worth it for most finger flipper spyder drivers.
  10. hessank
    hessank Formula 3
    1,746
    Canada, Florida
    Fred
    Don't want to jinx myself but my car has been rock steady.
    Other than a rad fan last year, it has been only maintenance stuff over the past 5 years.
    No issues with my Spider top
    Then again my car is NOT a garage queen
  11. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Why does this look like a troll thread? One post and it is "I heard ....."
    Apollo 11, KC360 FL and EastMemphis like this.
  12. Skippr1999
    Skippr1999 F1 Rookie
    4,216
    My CS has been bulletproof for the past 6 yrs. I’ve owned it. Never had a single F1 issue, failure light, nothing.
    KC360 FL likes this.
  13. one4torque
    one4torque F1 Veteran
    5,123
    Houston
    One4torque
    In my 2 yrs:
    01 19k miles when purchased used
    Now at 23k miles
    shifter bushing fail- self
    water pump- shop
    Belt svc- shop
    Tires- shop
    Pads rotors- self
    Alm siren- self
    Alm bypass mod- shop
    Battery- self
    Headers- self
    Mm’s- self
    Clutch block fitting leak r/r- shop
    Stickies- self
    Headliner fell off- self
    Drivers door cable- self
    Flasher relay fail- self
    Mass air meters - self
    Sups module and rear acc sensor fail- self
    Ash tray cover fell off- self
    I’m sure I forgot a few things.
    you be the judge -:)
    car is tight now— so putting some enjoyable miles on her!
    Gumart1, whatheheck and Dewinator like this.
  14. Dewinator
    Dewinator F1 Veteran
    6,051
    WA
    I haven’t had too much trouble with mine in 2.5 years, but hopefully it’s not too reliable! The most important criteria for an expensive car to be an enthusiast’s car rather than a *****’s car is being inconvenient to own and operate! :cool:
  15. Skippr1999
    4,216
    I’ll add. Stickies, headliner fell down, alarm battery replacement.
  16. Mighty Joe
    Mighty Joe Formula 3
    Sep 3, 2010
    1,125
    Atlanta, GA
    Joe
    I had my '03 360 Modena for 3.5 years! Loved every minute of it. I did put a Tubi exhaust on it because, well...you know!!! Had zero issues with the car. In fact it came up for sale early this year and I thought seriously about buying it back!!! But, moved on to another Ferrari experience!
  17. knocker
    knocker F1 World Champ
    11,841
    Sydney Aus
    Adrian
    Mines done 115,000klm and runs like a Swiss clock but if it sits In the garage for longer than 2 weeks it grumbles, they use parts up due to being a little racing car, things wear out due to the stresses put on the components in a high performance car but it’s a car, drive it as much as you can and Service the thing When due, should be fine
  18. Graz
    Graz Formula 3
    Oct 15, 2012
    2,296
    New Jersey and Florida
    Graziano
    Very reliable. On my 4th Gated 360 and other than annual maintenance all good. Obviously I can’t get enough of them :)
  19. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,790
    western hemisphere
    I have had mine for 5 days now and haven't had a single issue. :D
  20. Ron328
    Ron328 F1 Rookie
    2,615
    Willamette Valley, Oregon
    Ron
    Will be 6 years of ownership this August. Except for the right ECU going bad, no other problems. Never had F1 problems (I just jinxed myself! :)). I think it has been "cheaper" than my 328.
  21. Targaflorio0199
    Targaflorio0199 Karting
    Jun 25, 2019
    89
    Targa
    Owned my 2005 360 Spider - F1 box for over a year. The top had to be realigned by my specialist. As it wasn’t closing.
    A cheap fix. That’s it. Serviced annually . Driven once a week. Added 1k miles in 12 months. Zero problems.
    The big expense with these paddle shift cars is the dreaded clutch change.
    If you can’t work on the car yourself, the best thing to do is to get a honest, fair Ferrari specialist. Will save you big money at the annual service et al.
  22. jdlegg
    jdlegg Karting
    Dec 22, 2009
    231
    Bryan
    James D
    Had a 2000 360 6-speed coupe for ~13 years (purchased in '07 with 19K on it). Put 15K miles on it, many of them on track, during the 13 years. Had the usual issues - water pump, heat exchanger (that one was a mess), sticky bits, headliner, etc. Also had the belts done 3 times. Brakes/rotors were replaced at least twice (due to tracking). It was a solid car but never had to depend on it for daily transportation. Recently parted with it and only (occasionally) miss the gated shifter.
  23. vrsurgeon
    vrsurgeon F1 World Champ
    15,918
    Charleston, SC
    Curt
    10 years of ownership. I help Corolla drivers that break down. When you look up "reliable" on google. There's a picture of the 360. Right below the actual image result of a Camry is a 360 for a carnauba wax ad so that's something. When chuck Norris wants to catch the bad guy in a Lambo, he does it in a 360. Cause it starts. First maybe second time. But it starts! And you can't have a car chase scene if the car doesn't start. So yeah reliable.
  24. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    21 Reponses and counting to a OP with 1 post. I am sticking to my guess at tolling
    Husker, Apollo 11 and KC360 FL like this.
  25. MalcQV
    MalcQV F1 Rookie
    Oct 11, 2004
    3,292
    Manchester, UK
    Malc Holden
    Reliable - 100% for a 19 years old car.
    Things do wear out with age not just mileage. It won't ever be as cheap on maintenance in comparison to my low spec 2018 Mercedes (live in the Europe so it is kind of domestic) though. However it'll give me way more fun and ultimately a bigger return.
    With a 19 years old car you have to expect to spend money I would say, but obviously you have Ferrari tax to pay on a 360 :p
