Is Loctite Green 290 appropriate for use on the head studs on a 246GT (Iron) Block | FerrariChat
Discussion in '206/246' started by 72Dino246GT(Eur), Nov 29, 2010.
  1. 72Dino246GT(Eur)
    Dec 1, 2005
    34
    SFO Bay Area
    Peter Hollyer
    (This has also been posted in the technical section)
    Is Loctite Green 290 appropriate for use on the head studs that are installed in the holes that open into the water jacket of an (iron) 246GT engine block?
    If not; what is recommended?
    From Loctite Threadlocker 290 overview:
    Recommended For use on metal fasteners 1/12" (2.2 mm) to 1/2" (12.7 mm) in diameter such as pre-assembled fasteners, instrumentation crews, carburetors and electrical connectors
    From Loctite Threadlocker 290 Features:
    Benefit: Protects threads-Prevents rusting of threads
    Peter
  2. dino clay
    dino clay Karting
    Oct 31, 2007
    185
    san mateo, cal
    clay cavanaugh
    No!!!!! Use a drop of oil only and re torque heads several times over a 72 hour period. Glue is not what keeps bolts and studs tight, stretch keeps them tight. Re torque is because studs stretch and lose their torque over time over a short time and this is one way to make sure of tightness w/out the need to remove head nuts and re torque after initial warming of a new engine. Because, you have to remove cams to access head nuts.
    clay
  3. dino clay
    dino clay Karting
    Oct 31, 2007
    185
    san mateo, cal
    clay cavanaugh
    Coolant keeps studs from rusting in the block, Use DVM to measure electrolysis in the coolant to check status of your coolant. These block head combination rarely show damage from electrolysis.
  4. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #4 synchro, Dec 17, 2010
    Yes, in the block, but up from that the exhaust side studs suffer from corrosion and caking.
    Here are photos of myself and Bernd Buschen of European Autowerke disassembling the engine of Dino 05702. Note the last photo, where the exhaust studs are really grungey while the intake side are fairly clean. All are being replaced regardless of condition and only 2-3 on each side were difficult to remove.
  5. Darr247
    Darr247 Rookie
    Dec 30, 2010
    1
    Either you or I misunderstood the question, that appeared to me to be about the end of the studs that go into the block (and often penetrate water jackets), not the nuts which go on the other end of the studs.
    The equivalent of the ultimately-recommended Loctite 572 would be Permatex part number 59235, by the way. They both come in 50ml tubes for $11-$12 USD, also.
  6. dino clay
    dino clay Karting
    Oct 31, 2007
    185
    san mateo, cal
    clay cavanaugh
    no damage, no loctite. damage, replace studs and maintain coolant w/a good antifreeze. When you remove studs you will find no corrosion on threads.
    clay
  7. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    wont new studs have initial stretch that long established ones have gone through?
    why change them if they are not broke?
  8. swift53
    swift53 F1 Veteran
    7,993
    E.S.
    Alberto
    I think replacing them is a good insurance policy, specially if they have been known to strip the threads on torquing down.
    If they break on a re-torque of the heads while in the car, well...you can see the inherent pain that otherwise could have been prevented beforehand, with the engine out.
    I am also curious about what sort of product to use on the stud threads at the block, as you certainly would not want the stud to unthread itself if you loosen the head nuts to re-torque the head gaskets after a rebuild.
    My guess, blue Loctite, as they are never coming back out, right?
    Regards, Alberto
  9. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    do you replace the because of old age or times disturbed, re-tourqued?
    Or if in doubt change?
  10. swift53
    swift53 F1 Veteran
    7,993
    E.S.
    Alberto
    All the possible reasons you mention, lack of quality, unknown history, etc, etc, ....and that I like to sleep well at night....
    Regards, Alberto
