430 - Instrument Panel Not Functioning - Blown Fuse? | FerrariChat
430 Instrument Panel Not Functioning - Blown Fuse?
Discussion in '360/430' started by NorCalGuy, Dec 19, 2021.
  1. NorCalGuy
    NorCalGuy Karting
    Sep 28, 2018
    65
    Pleasanton, CA
    NorCalGuy
    All - need your expertise to help diagnose an issue with instrument panel not functioning. Went to start the car today and upon turning key, the instrument panel did not light up or function at all. Nothing turned on, the entire instrument panel was dead...no warning lights, systems check OK lights, tach/rpm, or gauges.
    However, the car started normally, headlights, taillights, turn signals, interior lights, throttle response, work just fine. My guess is a bad fuse/relay? After letting the car warm up for a bit, I did re-start the car thinking might be just a glitch, but again, instrument panel still not functioning.
    Note, doubt this would make a difference, but car has sat for a week in the garage and weather has turned cold, dipping into 33-36 degrees at night (yes, that's cold for us in Cali). Possibly cause an issue with electronics?
    Appreciate any help you can offer.
    Thanks and kind regards.
  2. Qavion
    Qavion F1 World Champ
    13,827
    Ian Riddell
    #2 Qavion, Dec 19, 2021
    The panel gets live battery power from fuse AF9 in the frunk and ignition power from fuse AF15 also in the frunk.
    I'm surprised the car functioned normally though. The instrument panel provides things like vehicle speed to all the car's ECUs.... but then these ECUs might be trying to put on warning lights to tell you this (and these lights aren't working). The instrument panel enables the windscreen wipers (do these work?)
    I'm not certain it's a power issue, but check the fuses anyway.
    hessank likes this.
  3. Qavion
    13,827
    Ian Riddell
  4. NorCalGuy
    NorCalGuy Karting
    Sep 28, 2018
    65
    Pleasanton, CA
    NorCalGuy
    Qavion, thanks for your reply...wipers do NOT work. FYI, windows working fine. Note, have not tried to drive the car, only started on/off a few times. Afraid to drive with instrument panel no working.
    Qavion likes this.
  5. Qavion
    13,827
    Ian Riddell
    Just noticed that the Interior Light Timer Module receives ignition power from fuse AF15. I'm not sure what effect it would have on the interior lights if the fuse was blown. Your interior lights work, but is the delay still working? If the delay is working, the fuse may be ok and fuse AF9 may be the culprit.
  6. Qavion
    13,827
    Ian Riddell
    For reference, those fuses are 5 amps. If only one fuse was blown and you had no spares, I suppose you could use frunk fuses AF20 (Position lights front LH and rear RH) or AF16 (Position lights front RH and LH rear) on a "get you home" basis. There doesn't seem to be any more 5A fuses on the car other than the ones which power the immobiliser system.
  7. NorCalGuy
    NorCalGuy Karting
    Sep 28, 2018
    65
    Pleasanton, CA
    NorCalGuy
    Thanks! Appreciate the additional information.
  8. NorCalGuy
    NorCalGuy Karting
    Sep 28, 2018
    65
    Pleasanton, CA
    NorCalGuy
    Problem solved! Thanks for your help. Purchased $5.00 worth of 5amp fuses, changed both the AF9/15...turned the key and instrument panel lit up like my Christmas tree. Whew! Big sigh of relief.
    Schmidty23 and Qavion like this.
  9. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    but why did that fuse pop?
    keep an eye on that
    great that it was a low cost fix
    Qavion likes this.
  10. Qavion
    13,827
    Ian Riddell
    Did both blow?
    Certainly cheaper than a panel repair, but as Greg says, why did one of more fuses blow? If you can narrow it down to one fuse, we can look at things other than the panel which might have caused the fuse to blow.
  11. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    I was waiting for your reply, Ian
    Good points
    Strange that a panel fuse would pop.
    NorCalGuy, does your car have an accessory stereo system (amp) etc?
  12. NorCalGuy
    NorCalGuy Karting
    Sep 28, 2018
    65
    Pleasanton, CA
    NorCalGuy
    No idea, but will keep an eye on.
  13. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    do you have a separate stereo setup and/or amp?
  14. NorCalGuy
    NorCalGuy Karting
    Sep 28, 2018
    65
    Pleasanton, CA
    NorCalGuy
    No mods, stereo is stock. I'm taking into my Indy repair shop on Monday for its annual oil change, will have them give it the once-over.
    Again, truly appreciate your assistance. Hope you and your family have great Christmas Holiday.
    Qavion likes this.
  15. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Who is your Indy?
    Happy Holiday to you
  16. NorCalGuy
    NorCalGuy Karting
    Sep 28, 2018
    65
    Pleasanton, CA
    NorCalGuy
    I take it to Roselli Foreign Car Repair in San Jose.
    Mario Andretti likes this.
  17. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    OK I know who that group is
  18. Mario Andretti
    Mario Andretti Formula 3
    1,744
    Boston
    They are a very decent shop. Roberto did the PPI on my F430 earlier this year.
  19. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    They did quite a bit of work on a friend's 360 recently
    Very busy shop
  20. NorCalGuy
    NorCalGuy Karting
    Sep 28, 2018
    65
    Pleasanton, CA
    NorCalGuy
    Yes, Roberto has done quite a bit of work on my 07 F430 over the years (fluid changes, new clutch, valve cover gaskets, etc.). His shop always full of great eye-candy, too.
