I’m skeptical, too good to be true sticky button fix?
Discussion in '458 Italia/488/F8' started by Nsd991, Jan 11, 2024.
Thoughts?
  1. Looks legit
    6 vote(s)
    60.0%
  2. No Way
    4 vote(s)
    40.0%
  1. Nsd991
    Nsd991 Formula Junior
    Jul 19, 2012
    538
    Thoughts?
  2. PMiranda
    PMiranda Formula Junior
    Jul 23, 2004
    632
    Austin, TX
    Looks way easier than actually removing the buttons, and if yours aren't scratched too deeply it might turn out quite well.
  3. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    10,961
    St. Louis, MO
    Eric
    I'm sure that it can work...... but it's all in the prep. I don't like the idea of spraying inside the car and risking over spray.
  4. Nsd991
    Jul 19, 2012
    538
    Yeah no way will I try this. Thank goodness I don’t need to……..YET
    It’s part of the Ferrari tax to get them re done professionally
  5. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,246
    Tampa FL
    @Eric C you can do it…. What’s another project?
    Ivan Drago, Eric C and AD211 like this.
  6. todd cloud
    todd cloud Formula 3
    Jun 21, 2019
    1,044
    Todd
    no
  7. Mrpseudonym
    Mrpseudonym Formula Junior
    586
    Sydney, Australia
    Yeah, someone on here needs to try it first, on their friends Ferrari
  8. Snapshift
    Snapshift Formula Junior
    898
    Centralia IL
    Lyle D. Pahnke
    The alcohol will strip the coating off the backplates on the switch panels to the sides of the cluster. The backplate is white plastic under the black coating.( Ask me how I know, flat black paint fixed it ok). If you are not too vigorous with the alcohol and just get the surface of the sticky off, it might be ok. The difficult ones are the surrounds to the rt and Lt TFT screens. The alcohol will remove the anti reflective coating on the screens if not disassembled and separated. Those are real sticky but since I dont touch them all that much decided to leave well enough alone. The rear view mirror I removed and scrubbed all the stick coating off down to the black base plastic and that is where I left it. Satisfied with that.
    Eric C likes this.
  9. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,948
    MD and NE
    Robbie
  10. Ivan Drago
    Ivan Drago Formula 3
    Jul 14, 2021
    1,213
    Midwest
    Ivan Drago
    What are you trying to say with your post exactly?
  11. 285ferrari
    Sponsor
    Sep 11, 2004
    20,948
    MD and NE
    Robbie
    I'm saying the ONLY way to do them properly is to remove them. The sticky coating on most parts wraps around the sides and sometimes rear of the parts. Wiping something, alcohol, a cleaner of some sort on those parts to loosen the sticky, is in turn dripping down and around inside that component. That liquid will start to corrode the inside of the parts, corrode electronics, etc. I have seen it 100 times. On top of the fact, that goo will start making it's way to the sides and seeping out eventually, once the inside temps get hot and humid. Not to mention spraying inside the car? You freaking kidding me, where is that overspray going??
    SAFE4NOW, Boiler Inspector and Willl like this.
  12. bagombo
    bagombo Karting
    Dec 27, 2013
    51
    Monaco
    I think the spray to dry editing in this video is doing a lot of the heavy lifting. No way in hell would I want to try this on my car.
  13. Ivan Drago
    Jul 14, 2021
    1,213
    Midwest
    Ivan Drago
    Thanks, thats a good response.
  14. Eric C
    Mar 20, 2009
    10,961
    St. Louis, MO
    Eric
    So you're saying that it's worth doing if the owner is willing to go through the trouble le of removing the parts that need to be redone.
  15. stevdug
    stevdug Karting
    234
    Tulsa
    Steve
    This is great, it's almost as good as the magical rattle can spray on paint scratch remover I've seen the ads for. I'm sure you can cover up the sticky but the problem is still going to be there.
  16. 458yogi
    458yogi Rookie
    Aug 28, 2022
    16
    Long Beach CA
    Sal
    I completed something similar in my car.
    Except I removed and disassembled all buttons.
    It took a very long time to remove all panels and clean each part.
    The result turned out perfect, just make sure to be ready to spend countless of hours on a project like this.
    FYI. The bumpy road button on the steering wheels is different, so you don’t want to spray clear on it, as it will dissolve the graphic on the button ( all other buttons are fine)
    I’ll add photos of my results
  17. stevdug
    stevdug Karting
    234
    Tulsa
    Steve
    To be clear "yes" you can do this (I did, there is info in some of the sticky threads about my clean up) but #1 you need to take things apart, and #2 don't use rattle can paint if you expect it to last for any length of time, #3 be aware that different parts have different tolerances as to the base coat,( the part that has the letters etched into it) wiping away. I went into mine thinking if I destroyed some of the lettering I would send them away to get new laser etching, and I did ruin some so Ii did send those away and they returned looking fantastic. The parts that I was successful in not ruining the graphics also looked great after I resprayed with automotive grade flat clear.
  18. 285ferrari
    Sponsor
    Sep 11, 2004
    20,948
    MD and NE
    Robbie
    Absolutely, they will be cleaned, refinished and NEVER get sticky again
  19. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Fort Lauderdale, Florida
    Todd
    But they also won’t be the soft touch material they originally were. They’ll just be plastic painted buttons like any Toyota.
  20. 285ferrari
    Sponsor
    Sep 11, 2004
    20,948
    MD and NE
    Robbie
    Parts are painted, NOT colored plastic like a Toyota, big difference. Original parts soft touch which fails - $$$$$$ - Refinished parts that won't fail $$ - - I guess if you have money to pi$$ away, have at it. I like money..lol
  21. Eric C
    Mar 20, 2009
    10,961
    St. Louis, MO
    Eric
    I prefer my buttons not to feel like flesh. Yall are freaks.
    mdrums likes this.
  22. stevdug
    stevdug Karting
    234
    Tulsa
    Steve
    As I would look at my perfect finger print impression in the gooey main controller I would fondly recall complaints on other forums about not having soft touch plastics :). Eventhough the finish is not soft touch after repair it still has a quality feel about it, and just puts the car interior enjoyment back to where it should be.
    Eric C likes this.
  23. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,246
    Tampa FL
    You push my buttons ;-)
    Eric C likes this.
  24. Eric C
    Mar 20, 2009
    10,961
    St. Louis, MO
    Eric
    Gross. Did you poop yourself?
  25. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    I removed all mine and sent them off to a real doll factory and had them done in cyber skin. Some get warm when I touch them and other ones moan.
    bamaman and NYC Fred like this.
