Ok you ham heads. This has been in the house for about 15 years (I think) used it for a couple years, then just lost interest. I no longer have the original box, but it will be carefully packed and shipped anywhere in the continental USA for FREE!! I also confess I stole this description from Ebay as I have little technical expertise in this area. Icom IC-R71A in absolutely beautiful condition. . this one is pristine--check out the pictures. Read the reviewsthis radio stacks up with the best of them. This is the highly desirable version with passband tuning. Works great. The R71A is noted for fantastic audio and this one is no exception. The ICOM manual is included. Here are some specs on the radio: The Icom IC-R71A utilizes a DFM (direct feed mixer) to make the R71A virtually immune to interference from strong adjacent signals. This, coupled with a 100 dB dynamic range, means solid performance for the casual listener or serious DXer. The receiver system is a multi-mode, quadruple conversion superheterodyne covering 100 kHz to 30 MHz with a CPU controlled, 10 Hz step VFO with 100 Hz display resolution. Advanced features include: Pass Band Tuning, IF notch, adjustable AGC, adjustable noise blanker and built-in preamplifier. The R71A also hosts a variety of user conveniences including two independent VFOs, dial lock, squelch, tone and direct keypad entry. A 32 channel scanning, tunable memory that stores frequency, VFO and mode is also built into the R71A. The rear panel has two, selectable antenna inputs: SO-239 jack and Hi-Z wire input. The top panel features a built-in speaker, plus there is an external antenna jack on the rear panel. · 100 kHz to 30 MHz range · Dual VFO's · AM, FM (optional), LSB, USB, CW, RTTY · 32 memory channels · Analogue signal meter (S-Meter) · Pass Band Tuning (not in all units, but IS in this one) · IF notch · Adjustable AGC · Adjustable noise blanker (NB) · Built-in preamplifier/attenuator · Adjustable squelch · Tone control · Front panel light dimmer · Tilt bar and carrying handle · It does work like new, but should you find a defect, it comes with 100% money back guarantee. Also for sale on ebay as a buy it now, so if it goes there first, I'll post here. Price $259.00, includes shipping - paypal only please. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
