I turned the key & my $$$ flashed before my eyes.......!!!!! | Page 5 | FerrariChat
Discussion in 'Boxers/TR/M' started by kerrywittig, Apr 22, 2010.
  1. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,402
    Alabama (was Mich.)
    Jeff
    QUOTE FROM EARLIER POST:
    "Now there is a new twist to as what may have been the real culprit of the belt failure........Yes no doubt there was substantial oil contamination.....but....the 10mm nut on the adjuster was able to be removed while bolted in place with my fingers. 2 to 3 turns and ....Boing went the spring......"
    The cam belt tension is basically constant, it is locked down by the bolt that goes through the center of the tensioner bearing. Once the tensioner is "set" during belt installation...bearing cannot move unless the center bolt loosened - and that would be an immediate disaster. While it is VERY disturbing to hear that the 10mm nut was only several turns onto the threads...it is probably not the root cause of the belt failure. The shearing off of belt teeth as shown in the pictures...suggests a failure of the belt material itself.
  2. samsaprunoff
    samsaprunoff F1 Rookie
    4,188
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Jeff,
    Could it not also be possible that an event stopping the Cam from turning cause the belt to look like this (i.e. dropped valve, drive pulley bearing, etc )?
    Cheers,
    Sam
  3. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,402
    Alabama (was Mich.)
    Jeff
    Yes Sam...those are also possibilities. Kerry said that the cams are not seized, so it's not a bearing problem. It could be a dropped valve...that will have to be determined after some disassembly.
    I'm still tending to agree with Kerry's earlier view that oil contamination may be the major issue. The left side (U.S. car driver's side) cam belt is nearest to the engine block, and the right side belt is further out in front. If the car sat idle for an extended period of time like over a winter, with the cam belt subjected to the oil leak...and the motor was not turned over during that time...it would have to have some effect I would think.
    I have also heard theories of belts taking a "set" if left in the same position for extended periods of time. I don't know if this would affect the belt teeth or not though.
    Knowing Kerry...he will find out the true cause....
  4. Hawaii
    Hawaii Formula Junior
    Jan 28, 2007
    847
    Maui
    Emery
    "The shearing off of belt teeth as shown in the pictures...suggests a failure of the belt material itself. "
    I don't see any pictures of the belts??? I'm I missing something?
  5. Rifledriver
    34,138
    Austin TX
    A dropped valve presents no problem to the cam or cam drive. It does present a problem to the piston and head.
    If a cam is not or did not sieze in the head that was one of the mythical belt failures that according to some nitwits around here never happens. Oil may have played a part but that could not be seen from the pictures. If Kerry is amenable I would like to see the belt. Be more than happy to send it right back.
  6. Rifledriver
    34,138
    Austin TX
    See post 75
  7. samsaprunoff
    4,188
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Brian,
    I guess I was inferring that the dropped valve jammed into the piston and thus causing the cam to stop moving. Indeed, a bit of an inference on my part however, I was just looking at other possibilities.
    Cheers,
    Sam
  8. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
    #108 kerrywittig, May 13, 2010
    Just to put the, "How did this happen!" debate to rest...............
    This happened because of owner/operator error......or should I say MY procrastination. I knew of the leaky crank seal and I just kept putting it off and I finally got bit....MY BAD!!
    Rifle offered to take a look at the belt and we spoke about it in fact. I related to Brian that the belt was very much oil soaked.....you know when the rubber almost feels "soapy".....and we have agreed that there is no need to send the belt out to the left coast just so he can immediately have the same obvious conclusion.
    At this point it is a matter of getting the heads off, gettting valves ordered and sending it all to the machine shop. I am most concerned about ordering the correct gaskets and seals, as far as what I really will need.............Want to get just what I need and not waste money on gaskets "in sets" that I won't use. If any of you out there have any gaskets, seals or valves collecting dust on a shelf and want some pocket money let me know..........big pockets....LOL!
    Hey if anyone would like to "LOAN" me the TR specific head bolt wrench I could put up a deposit of twice the value (approx. $1000) and turn it around in a day...........any takers?
    Oil soaked & frugal ME
  9. Rifledriver
    34,138
    Austin TX
    I understand but if it drops a valve it would be out of contact with the cam.
    The main thing all should remember. Belts are very strong. If they are not chemically or age compromised this will not happen. It really is that simple.
    There is a lot of paranoia here about belts. They are very good, they are very reliable. Juts change them at the proper time and keep the petro chemicals off them.
    You want horror stories? I'll tell you horror stories and they all involve chain drive motors.
  10. Rifledriver
    34,138
    Austin TX
    Kerry, I just sent a PM.
    BTW For everyone else. The Hill tool listed for the 4 valve motors DOES fit TR's. It is for ALL 4v motors, not just the V8's.
  11. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,648
    Land of Slugs & Moss
    Han Solo
    THIS is something I would be interested in hearing. I have seen damage in done by a timing chain on the front of an inline 6 when the guides disintegrated. Not pretty. Timing cover and water pump destroyed, engine block gouged.
  12. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Oil doesn't evaporate. The belts will either have oil residue on them, or they won't --- that will tell you something.............
  13. finnerty
    May 18, 2004
    10,406
    #113 finnerty, May 13, 2010
    My bad....
    I posted my previous comment before reading your last post, Kerry.
    I guess that question has already been answered --- and, you likely have your "smoking gun"...or, should I say, your "slippery gun" :)
  14. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    I just ordered the Hill tool # 95971393A (Courtesy of Mr. Rifle)...........Spoke with Daniel and he said the only thing he thought might be problematic might be that the "socket" area of the tool might be a bit too deep. But an easy fix by removing a bit of material from the tool and all would be well and also NOT compromise the tools integrity.
    Tool ME
  15. Rifledriver
    34,138
    Austin TX
    Factory tool was the same way. Because of casting irregularities of the heads fit was a little hit and miss until a little grinding is done.
  16. Beta Scorpion
    Beta Scorpion Formula 3
    Jun 22, 2006
    1,336
    This post and thread are worth a million useless 'timing belt' threads.
    Thanks for sharing your experience guys.
  17. Spasso
    Feb 16, 2003
    14,648
    Han Solo
    Ditto. Finally, first hand experience with contaminated belts.
  18. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    #118 jungathart, May 17, 2010
    Hi Kerry,
    As per our conversation yesterday, I am saddened to hear about the damage to your car.
    Sounds like with Rifledriver, et. al. on board; and along with your own talents, this story has a great chance for a happy ending.
    I have emotional and prayer support to offer, and they shall be ongoing until she's on the NY back roads once more.
    Godspeed
  19. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    Yeah sorry for the short attention span I demonstrated.......do the search concerning the O2 sensors or just post the question...........I shall hopefully have some new pix of the engine "flying" into it's temporary home later today and maybe even a possibility of pix of the damage....If I can figure out where I set my camera down in the garage!!!
    Blood, grease and bruised ME
  20. xtcgt
    xtcgt Karting
    Nov 20, 2009
    156
    Toms River NJ
    Robert Boynton
    i made my own head bolt tool by welding a boxed wrench to a 3 in extension and shaving the box wrench untill it fit around the nut.
  21. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    #121 kerrywittig, May 18, 2010
  22. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    Kerry, looks like you can park a tank on that engine stand.
  23. finnerty
    May 18, 2004
    10,406
    #123 finnerty, May 18, 2010
    Kerry, .....just curious.... looks like you've removed the cams from DS bank, but not the PS yet --- how are you "locking / holding" those PS cams in place??? Or, is that the bank you already know is toast, so you're not concerned about it???
  24. Rifledriver
    34,138
    Austin TX
    Why lock them?
    They are not going to move on their own.
  25. fatbillybob
    Aug 10, 2002
    26,437
    socal
    That's funny! Me too...I was too cheap and too much in a hurry to buy one.
