430 - I Hooked Up My Launch X431 And Now I Have | FerrariChat
430 I Hooked Up My Launch X431 And Now I Have
Discussion in '360/430' started by Extreme1, Jul 5, 2020.
  1. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,229
    Santa Clarita, CA
    After hooking up the Launch and clearing a couple codes I have a pic of the left side of the car, with arrows pointing to each left tire, on the dash.
    Is this the tire pressure sensor batterys going bad or something else?
  2. Jgivoo
    Jgivoo Formula Junior
    432
    New Jersey
    Sounds like suspension light. Mine throws this when battery is low
    brogenville likes this.
  3. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,229
    Santa Clarita, CA
    One of the fault codes I had, had something to do with the suspension. I just drove the car and the pic of the car with the arrows went away. Car ran fine, so idk???
  4. jag-oo-r
    jag-oo-r Formula Junior
    423
    I've noticed that with my autel AP20, when it runs the diagnostic check on each system, it seems to "trigger" the system. I get all sorts of lights and such. I simply cycle the key afterwards and they all go away.
    Sent from my SM-G970U using Tapatalk
    EastMemphis likes this.
  5. brogenville
    brogenville Formula 3
    2,020
    Robin
    Thats certainly normal with the ABS/traction system- accessing the diagnostic mode will always cause your ABS light to come on during the procedure.Not sure is the suspension module would do the same thing, but if the fault code hasn't come back after clearing, then I wouldn't worry.
  6. MKTViper
    MKTViper Karting
    205
    Swan Point MD
    Same experience with my AP20. I get the same graphic after running a diagnostics, not sure if triggered by the ABS or the dashboard indications BIT. I just clear all codes before disconnecting the AP20. Never comes back.
