HP per cubic inch question | FerrariChat
Discussion in 'Other Off Topic Forum' started by AnotherDunneDeal, Feb 12, 2004.
  1. AnotherDunneDeal
    AnotherDunneDeal F1 Veteran
    Jun 2, 2003
    6,109
    N.Richland Hills, Tx
    James Dunne
    I am not sure if this has been addressed on here before so here goes.
    Way back during the horsepower wars of the muscle car days we would say that if our car got 1 hp per cubic inch we had a killer car. 426 Hemi/425 hp, 409 Chevrolet/409 hp, 406 Ford/405 hp. We thought those were the real performers, and yes, I had a few.
    Fast forwarding to present. Which totally stock, real world use car, has the highest stock hp/cubic inch ratio. I know that the 1.8 liter(109 cubic inches) turbo Audi TT with a 6 speed manual gearbox produces 225 hp. This is better than 2 hp per cubic inch or 125 hp per liter. What other cars do you know of that produce this kind of power to displacement ratio that are actually used as daily drivers?
    The M5 is a 5 liter (302 cubic inches) producing 394 hp or 78.4 hp/liter.
    E55 AMG is a 5.4 liter (332 cubic inches) producing 469 hp or 86.8 hp/liter.
    What other street drivers produce over 100 hp per liter? Just curious......
  2. Skelter
    Skelter Rookie
    Nov 1, 2003
    48
    The M3: 3,2 litres 343 HP.
  3. Kds
    Kds F1 World Champ
    Mercedes-Benz SL65 and CL65.
    Twin Turbo 6.0 litre V12 producing 612 HP.
    102 HP per litre.
    Not enough IMHO...........
  4. bluekawala
    bluekawala Formula Junior
    Jan 22, 2004
    436
    Ormond Beach, FL
    I think the S2000 does, but I wouldn't want to have to rev the piss out of a daily driver just to find a hole in traffic. For everyday give me a luxo-tank Benz or Jag, the rev happy car would be for weekends.
  5. tvrfreak
    tvrfreak F1 Rookie
    3,879
    Arkansas
    F K
    Yeah, I believe the S2000 has the highest specific power output of any normally aspirated engine. If not, it is definitely among the highest.
    Is there a table anywhere that shows this for each engine?
    Other good figures to have would be weight and volume of entire engine (not engine capacity)--so you could find the power you wanted, the lightest, most efficient engine to make that power, and one that would take the least amount of "packaging" to keep your car's center of gravity and center of mass in the smallest, most optimal location.
    Interesting thread.
  6. Slim
    Slim Formula 3
    Oct 11, 2001
    1,735
    Pacifica, CA, USA
    richard
    Yeah, let's leave turbos out of it. Turbo usage is cheating, ha!
  7. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,237
    Austin, TX
    Randy
    Honda S2000: 2.0L - 240HP - 120HP per liter
    Ferrari 355: 3.5L - 380 HP - 1.08.5 HP per liter
    Acura Integra Type R: 1.8L - 195HP - 1.08.3 HP per liter
    Keep in mind, these are naturally aspirated numbers. I'm quite sure you can find a turbocharged motor out there with a greater rating.
    While it doesn't mean anything on the bottom line, it means a lot regarding motor engineering and squeezing out as much HP per liter that you can without increasing the displacement, which increases the size of the motor and the parts inside it (for the most part).
    As far as 'driving the piss out of it' to make a passing maneuver in a daily driven car - I could say, test drive it and you'll see what revving to 9K is about, but then it wouldn't be the same. It takes a while to get used to and a while to really feel what driving in the upper RPM ranges in the S2000 is like, as opposed to others. With the S, you'll take it up and peg it on the redline and the person next to you will think the motor is going to blow up. Quite funny, but not going to happen. But I will admit, it isn't for everyone.
  8. JaguarXJ6
    JaguarXJ6 F1 Veteran
    Feb 12, 2003
    5,533
    Black Hawk, CO
    Sunny
    XJR/XKR, 4.2 liter V8 (4196cc/256 cubic inches) producing 400bhp at 6100rpm or 95 hp/liter.
    The Trans-Am engine is a 4.5 liter V8 producing just over 650bhp at 9,000rpm, stock block modified 3.2 sec 0-60, 10.8 trap at 180mph. "While the race engine retains the AJ-V8's lightweight alloy cylinder block and heads, a new heavy-duty crankshaft is fitted along with lightweight racing pistons and connecting rods. A new fuel injection system has been developed by Rocketsports and Bosch."
    Sunny
  9. AnotherDunneDeal
    Jun 2, 2003
    6,109
    James Dunne
    Audi RS6-450hp 4.1 liter ////109 hp per liter.
  10. tvrfreak
    tvrfreak F1 Rookie
    3,879
    Arkansas
    F K
    TVR Speed 6: 367bhp (at the wheel) out of 3.6 l = 102 bhp/l (Six cylinders)
  11. 134282
    134282 Four Time F1 World Champ
    40,647
    California
    Carbon McCoy
    i'm sure a picture would really help this thread... :)
  12. tvrfreak
    tvrfreak F1 Rookie
    3,879
    Arkansas
    F K
    Here you go...this is with gearbox attached. I believe they use Borg-Warner T-5 transmissions.
    I think a canted, transverse mount would be great, but presently it's mounted longitudinally.
  13. Nibblesworth
    Nibblesworth Formula 3
    1,756
    Southern California
    BillyBoy
    2000 Cobra R - 323cu with 385 RWHP, 385 RWTQ. Flywheel numbers for this car were around 440hp or so.
    That's an N/A motor.
  14. bostonmini
    bostonmini Formula 3
    Nov 8, 2003
    1,890
    porsche GT3, realistically at least 400 HP...3.6 liters....about 11.5 hp/ltr
  15. Schatten
    Apr 3, 2001
    11,237
    Austin, TX
    Randy
  16. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,856
    MO
    Omar
    Today the highest is the RX8 for NA.
  17. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,634
    John Lingenfelter <may he rest in peace> wrote a book "On modifying Small Block Chevrolette Engines" in chapter 2 he indicates this metric is now 1.1 HP/CID and the engine can still meat emissions <sniffer not Government EPA stuff>.
    Natrually asperated: Honda S2000 2.0 litres <last year> 240 HP for 120 HP/litre or 2.0 HP/CID! And there are a bunch of engines nowadays between 100 HP/litre and 110 HP/litre {F355, 360,...} BUT nothing is approaching the motorcycle HP wars where the factories are getting 190 HP/litre 3.0 HP/CID! from naturally asperated engines. In addition, whereas cars have been at 110 HP/litre since 1994 (F355 europe), the 600 cc motorcycles of 1994 were at 91 HP and are how at 115 HP! Talk about forward progress!
    Porsche GT2 gets some 456? HP from 3.6 litres for 125 HP/litre.
  18. Kds
    Kds F1 World Champ
    131 hp per litre with the 2004 engine at 473 hp.
  19. Schatten
    Apr 3, 2001
    11,237
    Austin, TX
    Randy
    Mitch,
    CID = Cubic Inch Displacement ? or what are you calling it?
  20. Schatten
    Apr 3, 2001
    11,237
    Austin, TX
    Randy
    Not necessarily. The rotary doesn't really have a displacement figure. If it did, it would be on top, but it doesn't so it is left for the unique.
    Mind telling us what you are referring to?
  21. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    Why hasn't anyone mentioned the F40? 480hp from 2.8l is 170hp per litre. But like someone said, we should be sticking to NA engines...you can do just about anything with a turbo!
  22. Kds
    Kds F1 World Champ
    Schatten....
    Sorry....477 hp in the GT2 now.
  23. AnotherDunneDeal
    Jun 2, 2003
    6,109
    James Dunne
    Actually, my question to begin with was about totally stock, everyday driver cars that can be used in the real world. I know the twin turbo Porsche is a daily driver by an F40? Absolutely great driver, just not daily. Let's not go into the world of one-off or specialty built cars but production line, normal use vehicles. Yes CL 600, M5, RS6, S2000 all fit this category. I do not believe an Enzo, McLaren F1, Lingenfelter Vette, F50 or F40 quite meet this criteria.
    If we want to go to absolute power, the sky is the limit........................
  24. Schatten
    Apr 3, 2001
    11,237
    Austin, TX
    Randy
    sorry, that's twin-turbo which doesn't count.
    because it's turboed and that isn't really what this thread is looking for. it's merely to find out what kind of power was displaced per liter or cubic inch on a naturally aspirated motor. if you want to talk turbos, well that's an entirely different ballpark. but naturally aspirated and from the factory (so, no Ruf's or modded Skylines can compete).
    exactly! and I do agree about the super-supercars that as amazing as they are, they don't really qualify that well under this.
    and as far as bikes - amazing amazing stuff.
  25. JaguarXJ6
    Feb 12, 2003
    5,533
    Black Hawk, CO
    Sunny
    Schatten, which part of "Which totally stock, real world use car, has the highest stock hp/cubic inch ratio." didn't you understand? LOL hehe
    There's no turbo or supercharger or fuel exclusion. If its driveable daily, and STOCK, then it qualifies. Don't exclude answers because they don't fit your intepretation of the thread.
    Sunny
