How to remove Ferrari badge from engine cover. | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by Derek Trotter, Sep 1, 2007.
  1. Derek Trotter
    Derek Trotter Formula 3
    1,790
    Cambridge, UK
    #1 Derek Trotter, Sep 1, 2007
    I want to remove the Ferrari badge from the engine cover of my 360M for detail cleaning but am not sure how it is fixed to the car. I believe that these badges are the same for many tipos. I presume there are a couple of pins which protude from the badge and slot into pre-drilled holes on the cover. If so, can you tell me where these pins are and the best way to remove the badge without damaging it or the paintwork. Thanks in advance.
  2. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    I would use a soft toothbrush and not remove it IMVHO.
    Since you are in the UK, I would us a left handed toothbrush. :D
  3. sparky p-51
    sparky p-51 Formula 3
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
    There are 3 very small circular spring clips that hold it in place. It tales a special tool to unload those goofy umbrella cone shaped things. Take it to a local high end body shop and see if they are able to help you out.
  4. Ricambi America
    Sponsor Owner
    Don't futz with the emblem... work the clips off from underneath. The little doo-dads (p/n 60324506) and grab the post as they're inserted. They're cheap, don't worry about destroying them as you remove the emblem (you will)
    eyeman1234 likes this.
