How to mount 308 on engine stand. | FerrariChat
Discussion in 'Technical Q&A' started by DavidDriver, Dec 9, 2007.
  1. DavidDriver
    DavidDriver F1 Rookie
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    I'm preparing to re-attach my recently reconditioned gearbox to my motor and intend on detailing it all when I'm done.
    In preparation for that, I bought the heaviest duty stand I could find. I figured that the stand would make the detailing a lot easier when I'm done putting it all back together. What I settled on, was the heaviest duty one they stock at Harbor Freight. I have another stand, but it's not nearly as heavy-duty as this new one.
    In trying to figure out which studs to connect it to, I'm having a little difficulty. On the 308, there are 5 studs exposed on the side where the fiywheel goes. While looking at the engine, the place on the bottom left (near the starter) where it "looks like" there should be a stud, it's just hole that's no doubt for a plug in the bell-housing. If it were a stud, I would have no problem centering the mounting bracket to the position of the crank.
    I can attach the stand bracket to four of the exposed studs without a lot of difficulty. But the center of the mount is then not centered on the crank. The reason that I cannot center it, is that's the only studs I can attach to, include the two studs at the very top of the bell-housing. And because the top two studs that come out of the 308 motor are not symetrically alligned to the center of the motor, I cannot center the bracket if I use those two studs. So in that case, the bracket is off-set a little bit. This will make turning the engine while on the mount a little more difficult that it would be if it were centered. And things "out of balance" in my experience are more prone to having some sort of a mishap.
    So.... the question is:
    I can mount the plate so that it is centered. But I can only do that by mounting to 3 of the studs instead of 4.
    Has anyone else done this just using three of the studs instead of four? I mean, it's an aluminum enigne. It's not that heavy. But then again, I don't want to do it if someone else has tried, and in doing so has bent a stud or Heaven forbid (!) dropped an enigne.
    Thanks...
  2. Verell
    Verell F1 Veteran
    May 5, 2001
    7,020
    Groton, MA
    Verell Boaen
    I've always been a bit off-center towards the differential, but can't get far enough to actually get to the center of rotation due to the tranny input shaft.
    The transmission & differential are a big % or the drive train's weight. So the center of rotation is actually offset quite a bit from the crankshaft center. Be sure to put a washer between the engine stand arms & the Al engine surface. Otherwise the cylindrical ends of the arms will gouge up the surface around the studs.
    Another alternative is to mount the engine using the motor mount studs. That's how I mounted the tranny I'll be rebuilding.
    Suspect you got one of these HF stands:
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=47304
    or
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=4420
    They both have front & rear rollers that are far enough apart so that even with things off-center there's no danger of tipping.
    I chose this stand from Northern Tool for it's wide front & rear stance:
    http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200305217_200305217
    Not quite as heavy duty as your stand, but more than adequate to the job.
    You may find that the cylinders on the arm ends are too long. There are several alternatives:
    - Mount the cylinders to the stand's plate, & use washers to hold the studs thru the slots in the arms.
    - Get pieces of 1" square steel stock & drill holes where you need them. This lets you get around length problems with the arms.
    - Cut down the cylinders, but remember that they need to remain about 1/2" long so the bolt heads mounting the arms to the stand's plate don't hit the engine.
  3. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    David, i still got block on the stand. I got some shots of it, i'll post them in a little while.
    Having dinner. Some nice pasta with meat sause. Mmmm..... with a glass of wine to go with it.:)
  4. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
  5. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Thank you! Yes. I'd like to see that. And can you send some of that pasta over too? Al-dente please!
  6. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #6 Pizzaman Chris, Dec 9, 2007
  7. Verell
    Verell F1 Veteran
    May 5, 2001
    7,020
    Groton, MA
    Verell Boaen
    You can 'flip' it mounted this way, but only in 1 direction w/the tranny on as the input shaft hits the stand's upright as shown in the 1st picture.
    We were mounting Chris's engine on the stand as a preliminary to dropping the tranny.
  8. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Thank you guys!
    I see the off-set is the same on the two top lugs. Duh.... :rolleyes: Of course it is, is the same engine! :p But it looks like you have one arm attached to the lower-left. Is there a stud there on yours? It's just a blind hole on mine.
    Didn't think of trying to mount the bracket vertically either. My bracket has the slides, so it's a little more flexible.
    Thank you for the pictures. Somehow seeing is more reassuring. Now I'll just mount it the way I started with all for studs that "I" have exposed. From Chris' picture, that's the one on the middle left (the one you're not using), the two top ones and the one on the lower right.
    Thanks a bunch! Now I just need to get a bunch of washers, which should be very easy.
  9. Verell
    Verell F1 Veteran
    May 5, 2001
    7,020
    Groton, MA
    Verell Boaen
    Once we had the tranny off, we didn't plan on rotating engine upside down, so just made sure the boss around the blind hole was pressing firmly against the end of the arm. At this point the engine is amazingly light even with the heads on it.
    The stud at the bottom of the front bank head (ie: the left middle one) is so high that it won't add any support if the engine were rotated on the stand. If I needed to rotate the engine, I'd keep that 4th arm as close to it's current location as I could by making an L shaped bracket that picked up a couple of the tranny mounting studs & the end of the arm.
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The term "light" being relative. LOL
  11. Ed_Long
    Ed_Long Formula Junior
    Nov 11, 2003
    686
    Salem, Oregon USA
    Ed Long
    The engine stand we got from Harbor Freight had a wider plate and infinitely extrendable and adjustable arms to accomodate four bolts. It worked great, never dropped an engine and I could rotate it easily. Since I retired from racing, it sits in the tools room in the barn.
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,020
    Groton, MA
    Verell Boaen
    Well, I call it light when an over the hill 61 year old & a 45 year old w/o straining can lift an engine w/heads & cams out of a pickup & carry it over to a workbench. Not many V8s, or even V6s out there light enough for that.
    BTW, was flipping thru some FSBs & came across a picture of the recommended factory approved shop engine stand. The stand's mounting plate attaches to the triangular stud pattern on the side of the engine (always wondered what it was far & why all F* engines had them). There's another plate that goes from the stand's mount to the flywheel end of the engine, apparently to help steady it.
  13. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It seems that a lot of Ferrari and Lamborghini engine stands are designed to mount the engine "sideways" and support from each side without depending on what are frequently pretty small bellhousing bolts or studs. I've built a few over the years.
    The engine is well supported and there is free access to the rear seal/flywheel while mounted on the stand.
  14. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    #14 DavidDriver, Dec 15, 2007
  15. phrogs
    phrogs F1 Veteran
    7,312
    Michigan
    That is a pretty good idea
  16. enginefxr
    enginefxr Formula 3
    Aug 20, 2007
    1,753
    S&R Exotics
    Gary Sharpe
    You're kidding............ if you don't know how to even hang an engine on an engine stand, you sure don't need to be working on it! Tutorial 1.01, "this ***** will never run right after this."
  17. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Your kidding, right? I dont believe asking if anyone has a better idea or procedure is any sign of incompetance, quite the opposite in fact. Asking before plowing on aimlessly would be far worse IMHO as well as showing great ignorance. Really, why even have this forum if people cant ask intelligent questions of how to best repair these cars.
    Something I would add is that I dont believe the bellhousing studs are strong enough to hang the engine on except as a short block. Also, be careful of some of these engine stands, some really arent capable of handling any real weight. Mark had his bend down a bit when he hung that 400 V-12 on it. Even though its a longer engine, the 308 with a gearbox attached is a lot of weight. I dont know if a 308 would hang from either side with a dual mount setup as shown above with the gearbox attached, but that is probably a more correct and secure way. Just always be considerate of physics, leverage, and the weakest link, and NEVER get underneath a stand mounted engine.
    I found a hydraulic lift table/cart from one of those semitruck load sales, but I believe HF carries one simular. It has about a 2 X 3 foot table and maybe a 750 pound lift capacity. I put the engine/gearbox unit on it and jack it up so im not down on the floor to work on the lump. I think it lifts to about a 30 inch or so working height which is pretty handy. Certainly you can wheel it outside to wash it down on, and the wheels do have brakes. I left the gearbox on the table and put the shortblock sans heads on the engine stand.
  18. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Still a little bitter are we?
    Given what you do & the forum you are on (ie.. potential customers), I would think a more cordigal/helpfull response might be better in the long run for you and your business.
    JMWO
  19. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Exactly!!!!!!
    Unless you're comfortable with the thought of pulling studs, or buying someone, or yourself, a block...because you (or worse, someone "helping you") didn't take the time to look at the WSM's drawing on how Ferari intended these engines to be mounted to a stand, don't even contemplate hanging an engine/tranaxle assembly off one end! This is an (expensive) and avoidable accident just waiting to happen!
    Sorry for the rant, but the mere post, just suggesting hanging an aluminum engine off the studs is acceptable, just makes me cringe! DavidDriver, mount your engine as the factory intended...and you'll do just fine.
    Regards,
    David
  20. enginefxr
    enginefxr Formula 3
    Aug 20, 2007
    1,753
    S&R Exotics
    Gary Sharpe
    Sorry about my earlier post. I had to deal with a customer earlier in the week that wanted to adjust his valves himself, and after telling him 3 times the correct procedure, he still didn't grasp the concept. And I know d*mn well he will still attempt to adjust them himself. Anyway, that situation has nothing to do with this thread, but I let myself make a smart*** post.
    Yes, this is an excellent forum to find advice, and I have respect for the do-it-yourselfers that tackle tough jobs on their own and do excellent work. What I don't want to see is someone get in over their head and end up breaking a block. For safety's sake, use a 4 legged engine stand if you're even the slightest bit worried about how it mounts on it. I admit, I've have an engine flip over and hit the floor, from not being locked down and rotating over on a 3 legged stand. I'm sure the OP will take every precaution and do just fine, there are alot of knowledgeable people on here to help.
  21. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
  22. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    just a FYI the engine/trans lump weighs in at 550lbs. back to the scheduled program.....
