how much generally for PPI | FerrariChat
Discussion in '458 Italia/488/F8' started by kiryu, Sep 20, 2017.
Tags:
  1. kiryu
    kiryu Formula Junior
    Mar 28, 2016
    407
    Los Angeles
    hi guys, how much do you normally pay for a PPI on a ferrari?
    Personally from 2 cars I have done both locally and out of state, it ranges from $300-500, and maybe 800 including engine compression test.
    I was told by a professional that a "right PPI" cost about 2k. Is that right?
    Just wanted to see everyone's experience here to know what's the "norm"...Thanks!
    p.s. tried searching but it says too few keywords
  2. pfl
    pfl Karting
    Jan 7, 2013
    105
    I paid $350 last year but no compression test.
    I think there is some truth to the 2k in the way that the more comprehensive they look and take their time the better PPI it is. I'd pay 2k if the car I'm buying is over 400k imo
    kiryu likes this.
  3. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,401
    Dallas Texas
    If you know you know
    Here are a few examples of vehicle inspections that we can perform.
    Up to and including CPO level inspections ( 5-6 hour ) and/or Classiche Inspections ( 10hr + )
    1 HOUR INSPECTION
    ( $170 )
    INSPECTION TO INCLUDE ESTIMATES FOR THE FOLLOWING ITEMS:
    ACTUAL SERVICE NEEDS
    TREAD DEPTH ACROSS 3 POINTS ON EACH TIRE
    BATTERY AND CHARGING SYSTEM TEST
    VISUAL INSPECTION FOR FLUID LEAKS
    CLUTCH READING WHEN AVAILABLE
    3 MILE TEST DRIVE
    2 HOUR INSPECTION ( $340 )
    VISUAL WALK AROUND INSPECTION OF ENTIRE CAR
    VISUAL INSPECTION OF WHEELS AND TIRES WITH TREAD DEPTH NOTED
    VISUAL INSPECTION OF COSMETIC ITEMS NOTING CONDITION OF
    INTERIOR LEATHER SURFACES, ACTUAL CONDITION OF PAINT, AND
    GLASS. NOTATION OF DAMAGE TO LOWER SPOILER OR REAR DIFFUSER
    ACTUAL SERVICES NEEDED
    NOTATION OF ANY CURRENT WARNING OR MALFUNCTION MESSAGES
    3 MILE TEST DRIVE
    3 HOUR INSPECTION ( $510 )
    VISUAL MECHANICAL INSPECTION FOR FLUID LEAKS
    VISUAL INSPECTION OF UNDERBODY PANELS AND SUSPENSION
    PERFORM ELECTRONIC SYSTEMS TEST FOR STORED FAULTS / CODES
    PERFORM BATTERY AND CHARGING SYSTEMS TEST
    INSPECT WHEELS AND PROVIDE TREAD DEPTHS FOR EACH TIRE
    AND PROVIDE CURRENT CLUTCH READINGS WHEN POSSIBLE
    kiryu likes this.
  4. obbob
    obbob Formula Junior
    Aug 14, 2017
    774
    Quick question, upon competing a PPI, what kind of report do you send? How informational would it be?
  5. 3POINT8
    3POINT8 F1 Rookie
    4,431
    I've paid $300
  6. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,401
    Dallas Texas
    Each report would include the details that correlate to the level of inspection requested.
    For Example if you chose a 1 hour inspection, you would get this information with associated estimates :
    1 HOUR INSPECTION
    BATTERY AND CHARGING SYSTEM TEST - With printed results
    3 MILE TEST DRIVE
    Normally, when requested, photo documentation of the following:
    Tire condition
    Severity of fluid leak
    Condition of filters and fluids
    and so on.
    The more in-depth the inspection, the more we can do for you regarding level of documentation and such.
    S
