How and how long do you warm your car up | FerrariChat
Discussion in '360/430' started by saudio, Feb 25, 2020.
  1. saudio
    saudio Karting
    Jul 22, 2014
    169
    Western Virginia
    before driving? On my f430 I usually let it idle 2-3 minutes, then drive gently and shift before 4K until the oil temperature starts to come up. After that no red lining until full oil temperature.
    The transmission also takes a while to warm up and shift smoothly (6 speed). It's stiff and notchy until it gets warmed up.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,662
    Central NJ
    Dominick
    Your are doing it perfectly.. start ..warmup for a short time ..then drive very gingerly until 5 10 miles and oil is about 170f ..
    Then you are good to go
    The time and mileage to warm will depend on outside temp
    Sent from my moto g(7) using Tapatalk
    CarbonDan and saudio like this.
  3. BAD430BENZ
    BAD430BENZ Formula Junior
    May 13, 2014
    709
    EL PASO , TX
    JASON
    Did you just purchase the car ?
  4. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,159
    i remember my F430 took about 15-20 minutes to warm up by shifting before 4rpm. the 458 takes about 5 minutes. not sure why the difference
  5. saudio
    saudio Karting
    Jul 22, 2014
    169
    Western Virginia
    A few months ago. I've put about 500 miles on it with sporadic winter driving.
  6. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
    Start it up and then maintain 7000-8000 rpm for 5 minutes. Fastest way to warm up those fluids!
    (I'm kidding of course)
  7. tmvatlanta
    tmvatlanta Formula Junior
    Mar 26, 2017
    389
    Covington GA
    Tam V.
    1-2 minutes
  8. cpep
    cpep Formula Junior
    428
    new york
    CHARLIE
    I usually start it and back it out of the garage. Then get out and do a walk around and inspect everything is good . That's about 5min of warm up time and then I roll out. Keep shifts down until oil temp is up as others have said.
    whatheheck likes this.
  9. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    906
    Homosassa, FL USA
    Ian Joubert
    Start it and drive it, keep it under 4k until oil up to 150 or so.
    Blue360, Need4Spd, recoil and 7 others like this.
  10. efg2014
    efg2014 Formula Junior
    Sep 14, 2014
    645
    Northern California
    I use to warm up the car prior to driving it. Now I start and go however I keep the RPMs under 2k for about 5-10 min.
    Blue360 and EastMemphis like this.
  11. Penzinger
    Penzinger Karting
    Jul 13, 2019
    135
    Austria
    Heinz
    Not advisable for F1 cars. The clutch only closes completely at approx. 1900 rpm, so it is better to stay between 2200 and 3000 rpm.
  12. gatago
    gatago Karting
    Jun 28, 2019
    119
    Marco
    I start it and wait for all dash lights to go away (5 or six seconds) before I back out of garage. I keep it under 4k until at temp, which depends on outside temp. I only drive in above 35 deg because of summer tires.
    Blue360 likes this.
  13. Zed82
    Zed82 Formula Junior
    Sep 28, 2017
    513
    Sweden
    Just start and go like any other car. Keep it under 3-4k rpm and wait for the oil to warm up. I would never let it idle when cold. Surprised to see many Ferrari owners do that.
    Blue360 and Danedingerson like this.
  14. willfinch36
    willfinch36 Rookie
    Dec 16, 2014
    26
    United Kingdom
    Same here, thought it was something to do with low oil pressure when idling.
  15. CarAholic
    CarAholic Formula Junior
    May 10, 2016
    517
    I used to do the exact same thing and still do it for all my other cars. The one shop that works on my car recommend letting it idle a couple minutes before driving off for the F1 system. Now while I was skeptical at first it does make a big difference. Shifting is a lot smoother once she’s warmed up a little.
  16. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,930
    Melbourne Florida
    KGC
    Start up and idle as little as possible. Out the driveway and start driving. No revs above 4K until oil temp reaches at least 170 degrees. On cool and colder days may take as long as 15 to 20 minutes to reach a "safe" temperature to drive spiritedly. F1 car FWIW.
  17. Hypek9
    Hypek9 Karting
    Apr 9, 2012
    162
    Australia
    Usually let idle for 5 minutes before driving. Keep revs below 4K until oil temp is good, can take up to 15 minutes of driving.
    Evad likes this.
  18. becausephilchow
    becausephilchow Formula Junior
    Aug 26, 2016
    543
    Hong Kong
    Let it cold start until the revs drop to normal, then drive. Usually around 30 seconds to 1 minute, and then I'll drive gingerly until the operating temps get up to normal. Shift under 3K, I have an F1.
  19. Zanny1
    Zanny1 Formula 3
    1,107
    Arizona
    Lugging the motor, cold or hot, is not so good. I can't imagine keeping the revs under 2000 RPM when driving a cold motor.
    KC360 FL likes this.
  20. VAF84
    VAF84 Formula 3
    2,277
    Central Texas
    What's the issue with letting the car idle? If I know I'm headed out for my Sunday morning drive, I turn it on and let it sit while I go inside to do a few other things. Usually anywhere from 5 to 10 minutes at least. Mostly because I don't have a lot of time to drive it, and I have limited self control once I exit the garage :) .
    Hypek9 and Sky Hye like this.
  21. Sky Hye
    Sky Hye Formula Junior
    710
    SoCal
    I’ll idle for a minute or two. For the rest I’ll drive about 5-10 minutes before really shredding my tires. The transmission will let you know based on how it shifts. That is if you’re in tune with your car
    VAF84 and EastMemphis like this.
  22. Danedingerson
    Danedingerson Karting
    Dec 26, 2011
    236
    Maui
    Dane
    Look in your exhaust for black soot which fills your engine on cold idle.
  23. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,822
    Memphis, TN
    I'm lucky that I live at the top of a hill. After starting and cel out, I pop into reverse for a fraction of a second and let gravity do the rest. By the time I'm at the bottom of the hill, idle has dropped and ready to go. I recall the owners manual said something about under 3000 r's until 70c, which is what I do. Maybe it was Fonzie at J. Scuderia. After 70c, I let her rip.
  24. ColGraves
    ColGraves Karting
    Aug 1, 2017
    100
    Cos Cob, CT
    C.T. Graves
    I was always told by pretty high-end mechanics that idling causes build up of unburnt fuel in the oil. Was told by a long time Ferrari mechanic to drive it gently, but not to idle it after starting. The unburnt fuel breaks down the oil (apparently). Also heard this with a Porsche Mechanic I used who I think pretty highly of. Of course, not sure if this applies to synthetic oils, but that is what I was told...
    VAF84 likes this.
  25. JohnnyTS
    JohnnyTS Formula Junior
    Jun 3, 2012
    907
    Pretoria East, RSA
    #25 JohnnyTS, Feb 27, 2020
    how I understood it, it's the burned carbon and unburnt fuel laying on the valves when idling and switching off, the idling a bit for a few minutes is fine when going out on a drive and the fuel burns off properly but when you idle for example 2/5 or whatever minutes and just switch the car off it is very bad and will break down the oil quicker but this was opinions from car guys / engine mechanics.
