Hose clamp question | FerrariChat
Hose clamp question
Discussion in 'Technical Q&A' started by Challenge, Jan 21, 2025.
  1. Challenge
    Challenge Formula 3
    Sep 27, 2002
    1,997
    PA
    Kevin
    Years ago I thought I became a hose clamp expert when replacing 355 coolant and other hoses. I knew Oetiker/ear style, worm/screw drive, etc. My favorite brands were Norma and Zebra although I experimented with other brands. Toyota uses a windup style clamp for CV boots. But when I received these OEM clamps for 458 coolant hoses (VISA brand) I was stumped. How the heck do you tighten these....I assume a special tool? Image Unavailable, Please Login
  2. mikey64
    mikey64 Formula Junior
    526
    TN
    mikey
    They function kind of like zip ties and yes you need special pliers for them. Caillau is one brand that makes pliers for CLIC and VISA
  3. Challenge
    Challenge Formula 3
    Sep 27, 2002
    1,997
    PA
    Kevin
    Thanks - the Caillau website does not make it easy to find the proper pliers. Any ideas?
  4. Challenge
    Challenge Formula 3
    Sep 27, 2002
    1,997
    PA
    Kevin
  5. Challenge
    Challenge Formula 3
    Sep 27, 2002
    1,997
    PA
    Kevin
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,661
    Central NJ
    Dominick
    Sorry ..maybe the site has it too ?
  7. Challenge
    Challenge Formula 3
    Sep 27, 2002
    1,997
    PA
    Kevin
  8. mikey64
    526
    TN
    mikey
    Plenty of other clamp styles that work fine and don’t need special tools.
  9. Chindit
    Chindit Formula Junior
    Oct 18, 2008
    340
    Navarre, Florida
    Nick P.
    Challenge likes this.
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    Is that a better mouse trap or a more expensive one?
  11. mikey64
    526
    TN
    mikey
    I’ve had mixed results with Gates powergrip. Maybe operator error. Worked fine on my restomod for years until I had to replace one due to wanting to re-route hoses (it didn’t fail). New batch didn’t shrink up as needed. Maybe a supply chain issue.
  12. fatbillybob
    Aug 10, 2002
    28,545
    socal
    I would not use clamps that need special tools if there are alternatives because if you have to access the clamp away from home you are sol. For my racecar all clamps are simple screw clamps. On my streetcars they are all gates powergrip. The PG are the best I have ever used. They maintain grip over wide temp changes, have no tang to snag your arm when doing car work, look clean in my Ferrari engine bay.
    Challenge and Chindit like this.
