Homelink on the rear view mirror | FerrariChat
Discussion in 'FF/Lusso' started by jolieinc, Aug 24, 2016.
  1. jolieinc
    jolieinc Karting
    Aug 3, 2016
    74
    Sarasota, FL
    Allen
    Just got a new garage door opener and they tried to program the homelink on my 16 FF. No lights at all on the mirror. I think I saw something in regards to this before but tried searching the forum first and no luck.
    Anyone else with this issue and do you know what it could be?
  2. RickLederman
    RickLederman F1 Rookie
    2,836
    Swanton Ohio
    Rick Lederman
    From another thread of mine:
    HomeLink works great in my 2012 California ... now that I found instructions on a couple other websites, along with actually trusting the instructions. So, for those that get a new Cali with HomeLink (and you don't get instructions with the car) here you go.
    First, it worked quickly and very easily with my 16 year old garage door. It took a few extra steps on my 2 year old garage doors which I falsely interpreted as a problem.
    1. (Optional) Press two outside buttons on it and hold to clear the device on the car mirror, until the light blinks rapidly.j You can always clear a single mirror button by holding it about 30 seconds until it starts to blink rapidly if it had been programmed before.
    Now the old garage door:
    1. Press and hold a button on the mirror until the green light blinks slowly
    2. Press and hold your garage door button on the remote until the green light on the mirror blinks fast
    3. Let go of both buttons
    Try it, it should work just fine.
    I expected that to work for a new garage door but there is an extra step you probably will have to do.
    1. Press and hold a button on the mirror until the green light on the mirror blinks slowly
    2. Press and hold your garage door button on the remote until the green light on the mirror blinks fast then let go of both buttons (you MAY have to press the garage door button a couple times according to the manufacturer)
    3. Try the mirror button, if it doesn't work (as mine did not work) do the next instructions
    4. Press the LEARN button momentairly on your garage door opener mounted in the ceiling of your garage
    5. Within 30 seconds get in your car and press the appropriate button on your mirror that you just programmed, look for the light on the garage door opener in your garage ceiling to blink.
    6. Try your mirror button now ... like magic it works.
  3. jolieinc
    jolieinc Karting
    Aug 3, 2016
    74
    Sarasota, FL
    Allen
    Thank you for the instructions. We are getting no lights at all. Tried holding down the buttons to reset. Tried holding the one button. Homelink has good car model specif instructions on their site. I think the fuse is blown or mirror is a defect.
  4. SVCalifornia
    SVCalifornia F1 Rookie
    2,549
    Silicon Valley
    Keith
    Or there is no power to the mirror. You can pull the mirror mount off to see if it is connected...
    SV
  5. ttforcefed
    ttforcefed F1 World Champ
    19,216
    or do what a lot of do - just use the door opener that came with the garage doors - saves you some brain cells from being killed
  6. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    On my 458 the light was so small l had to do the setup in the dark to see the lights blink. Works fine.
  7. jolieinc
    jolieinc Karting
    Aug 3, 2016
    74
    Sarasota, FL
    Allen
    Maybe that is it. Homelink should be Homelink on most any car. Plus my wife was the one doing it. I will try at night. You could be right.
  8. RickLederman
    2,836
    Swanton Ohio
    Rick Lederman
    For $12.50 I won't tell your wife that you don't think she can handle it :D
  9. jolieinc
    jolieinc Karting
    Aug 3, 2016
    74
    Sarasota, FL
    Allen
    I told her myself and will save the $12.50 thank you!
