Hill Engineering Tensioner Bearing A/C | FerrariChat
Discussion in '360/430' started by collegeboy, Feb 1, 2024.
  1. collegeboy
    collegeboy Formula 3
    1,309
    Texas and Kaua’i
    Mikey
  2. andrejwolk1975
    andrejwolk1975 Karting
    Feb 28, 2020
    106
    Italy
    Andrea M
    I think ALL original Ferrari bearings are not so far from "junk" grade.
  3. RedNeck
    RedNeck F1 World Champ
    11,977
    The CSA
    Me
    HE parts are almost always superior, I didn't know this one existed but I just replaced my tensioners and had my bracket modified to accept the new style tensioner, I'll probably replace this too
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,916
    Isle of man- uk
    The oem Ferrari clutch release bearing was leaking grease after 15 k miles on my 430, the Hills replacement was a work of art and a lot cheaper than the oem part
    cavlino likes this.
  5. Ricambi America
    Sponsor Owner
    The Hill version of 179698 uses the identical SKF bearing on the inside as the Ferrari one. It is not a 'superior' part; it was manufactured about 5 years ago when there was a shortage of the original Ferrari version.
    I have already had four direct queries about this today.
  6. Ricambi America
    Sponsor Owner
    That is a blanket statement and simply not true. Ferrari doesn't 'manufacture' any bearings; they source them from SKF, NTN, NSK, etc. The 'junk' arises when original stocks are depleted and in the process of obtaining more, the buyer chooses a bearing based on size or generic specs alone --- not really giving enough care to loads, temperatures, and the 'use case' of that was carefully considered by the original engineer at Ferrari.
    BDubbs, cavlino, 67bmer and 3 others like this.
  7. collegeboy
    1,309
    Texas and Kaua’i
    Mikey
    I posted this here when I sent you that email last night. Thanks for the prompt email reply as well. I actually came here to let everybody know the good information you let me know, but looks like you went ahead and did that yourself. Thanks again. Money saved!
    RedNeck likes this.
  8. andrejwolk1975
    Feb 28, 2020
    106
    Italy
    Andrea M
    Right. Ferrari is worldwide known for having a long history of robust and fail free components. They break and keep breaking because are of a superior quality.
  9. Rifledriver
    36,760
    That part is incorrectly named. A result of Ferrari using language school students for translating their books. It is not a tensioner and only fails when used as one. It should not be contacting the belt. Its only purpose in life is at high RPM when the belts "Whip" this pulley should prevent the belt from over riding the pulley and coming off. If correctly adjusted should outlast the car but too many actually use them to tighten the belt.
    cavlino, 67bmer and anotherred360 like this.
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,916
    Isle of man- uk
    Interesting when my clutch release bearing was changed, the bearing it self was fine but the seals had failed and it was leaking grease into the housing, they picked it up on a service as the space should have been dry and not oily.
  11. CoreyNJ
    CoreyNJ Formula 3
    2,364
    New Jersey Shore
    This may be true for the tensioner bearing but the release bearing is not... Here is a quote from their website;
    Hill Engineering's Clutch Release bearing for 360F1 & 430 F1 & Scuderia (#234953) - Pre fitted with OEM Seals.
    Also fits: 599 F1, Enzo & Maserati 4200 Cambiocorsa & Granturismo ( F1 Only)
    (Superseded from #201024)
    All Hill Engineering clutch release bearings utilise a much improved bearing that is specifically manufactured for Hill Engineering by RHP-NSK. This bearing has been designed with many improvements including uprated seals and grease over the OEM SKF bearing that has a tendency of failing prematurely.
    So when given a choice between the OEM bearing and a Hill Engineering one, I will always choose Hill Engineering. Ferrari are great engine designers, but they aren't perfect and like all automobile manufacturers they do have to deal with the idea of cost and availability across the entire manufacturing lifecycle of a model, whereas Hill has a different set of priorities.
  12. Ricambi America
    Sponsor Owner
    I do understand that. I've been selling Hill Engineering items for 20 years. My point was simply that item uses the same SKF bearing as the Ferrari version.
    collegeboy and RedNeck like this.
  13. vrsurgeon
    vrsurgeon F1 World Champ
    16,439
    Charleston, SC
    Curt
    I've found since they use the same components as many other manufacturers. Mine is as reliable as my Porsche. It's not about the parts as it is about having a competent mechanic and not abusing the car.
    Rifledriver and 67bmer like this.
