355 - High milage worries? | FerrariChat
355 High milage worries?
Discussion in '348/355' started by Klas, Feb 19, 2021.
  1. Klas
    Klas Formula Junior
    Mar 17, 2014
    329
    Gothenburg, Sweden
    Klas Nilsson
    Interesting to know if there are any high milage 355:s still running without a total engine rebuilt, just ordinary maintenance done regularly. My F355 -97 has now 96K KM (61K mi) on the clock and still running fine. I bought the car to be used not a garage queen, but should I be worried of a total engine break down soon or not? What´s your experience - high milage 355 drivers?
  2. FLORIDAsnakeEyes
    FLORIDAsnakeEyes Formula 3
    Jul 7, 2015
    1,146
    Sarasota, Florida
    OC
    There was a guy here in Florida with 150k on his. He never did any maintenance other than the belts every 5 years (yes not 3..) and oil changes/spark. It was a 97 so probably did not have the valve issues either like 96 and pre.
    Sent from my SM-F900U using Tapatalk
  3. Klas
    Klas Formula Junior
    Mar 17, 2014
    329
    Gothenburg, Sweden
    Klas Nilsson
    Good to read. The more I read like this the less worried I'll be.
  4. tres55
    tres55 F1 Rookie
    3,495
    Canada
    I don't think the bottom end of these motors are the problem as much as potential top end issues.
    They're race motors built for the street so all the components will be almost over-engineered for the way most of us drive them.
    Mine had around 110,000km when I sold it and it ran like a champ. Had great compression across the board still also.
    Natkingcolebasket69 likes this.
  5. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    I thought topics like this were put to bed years ago. It used to be a reoccurring subject over a decade ago.
    355s can take very high mileage.
  6. Ferrarium
    Ferrarium F1 Veteran
    5,631
    Central NJ
    Eric
    Plenty of threads too. It's not the mileage it's the car. Plenty of low mileage train wreck's out there.
    Sent using FerrariChat.com mobile app
    Beetle and tres55 like this.
  7. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    13,891
    Robb
    You should not be worried. Congrats on your milestone. Enjoy the car and take care of it along the way. Get back to us once you cross 100k miles.
    Robb
    Natkingcolebasket69 and Klas like this.
  8. Joshman0531
    Joshman0531 Formula Junior
    839
    Tennessee
    Joshua Seidenberg
    I do my majors every 5 years. I have 42k miles on mine. I drive every weekend barring snow or ice [I lived in CO for 23 years :) ]. Mine is a '98 F1.
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    I know of a 355F1 with close to 100K miles and it really is a bad sample of a 355. It needed multiple towings, lots of things don't work well especially the F1, the cosmetics are worn out, the spider roof no longer functions, and the heat in the engine bay has killed a tons of components in and around the engine.
    That is the only high mileage 355 I know around here and that is very troublesome.
  10. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    532
    Fountain Hills
    Jon
    One aspect I have yet to hear on the 355/360 engine is regarding the titanium connecting rods.
    At least on the Ducati side (revs up to ~11k), the titanium connecting rods are known to fail (rods ends expand) when the engine spends majority of its life at those higher rpms (track events).
    Maintenance and moderation is key to prolong life.
  11. A348W
    A348W Formula 3
    Jun 28, 2017
    1,748
    North Wiltshire, UK
    Not sure comparing cars to bikes is valid!?!?!
    Besides, loads of examples of high mileage Ferraris about; and 60k miles is not high mileage from a technical perspective. One of our group members has a 360 with over 160k miles on it, no engine rebuild yet and still going strong!
    Next thread....please!
    Challenge and Klas like this.
  12. zstyle
    Jun 28, 2007
    532
    Fountain Hills
    Jon
    Was simply stating from a technical point of view, Ducati and Ferrari both used Ti conrods in the 90s and in the future. All depends on how the engine has run + maintenance over the course of its life. Majority of Ferrari engines do not spend their life at higher rpms.
    Even at 160k miles, one would suspect the performance is down compared to a fresh rebuild or lower mileage vehicle. Everything wears out eventually, from piston rings, to journal/conrod bearings.
  13. GTUnit
    GTUnit Karting
    May 25, 2014
    143
    Socal
    Jack
    The Engine internals on these cars are built very well. Aside from the valve guide issue the rotating assembly is solid and I wouldn't worry 1 bit about high mileage. The cylinders on my 40k mile one have the best leak down I have ever seen. The Nikasil cylinder coating and the build quality make for a damn good motor with pretty low wear. All this assuming that any drivability issues are not ignored and left to snowball. I don't think this car need white glove babying treatment and majors every few years BUT one must be vigilant in noticing any potential problems and addressing them in a timely manner. That is just my opinion.
  14. Beetle
    Beetle Formula Junior
    Apr 10, 2013
    776
    Still cant work out why the old valve guide story keeps coming up? It wasn't that big a problem, some had issues some didn't A lot of the ones I've heard about were pulled because of LD test and then found to have carbon build up on the valves and seats was the issue, guides were fine. machine shops love LD tests because its like a speed camera. It makes $$$$$$$ and then add Ferrari badge to the issue then its even more $$$$$$$
