Help with INNOVA 3100 OBDll | FerrariChat
Discussion in '348/355' started by Extreme, Aug 14, 2012.
  1. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    #1 Extreme, Aug 14, 2012
    I have an INNOVA 3100 scan tool and the only thing it will do on my 99 355 is retrieve malfunction codes and clear them.
    It's supposed to be able to read ecu data live from the car while it's running, however it can only establish a link with the car when the key is in the acc position and is unable to link with the car once started.
    Anyone have experience with this scanner and Ferrari?
    "Edit" Maybe I'm wrong after reading the scanner manual I can't find anything about viewing live ecu data. :(
  2. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    After doing a little internet reading it seems as though the Innova 3100 is only good for retrieving and erasing codes. I guess for the money I spent it was worth it. I wish I would have gotten a scanner that could read live data.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    I had the same issue with Innova. It does not work in real time. I bought a cheapy USB software that reads the data quite well on the fly.
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
    You should have bought an Actron. :D :p
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    SoCal LA/OC/New Mexico
    Tim Dee
    Grab yourself a cheapy bluetooth OBD reader and grab the app "torque" It does quite a lot. I use it for logging of all kinds.
  6. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
  7. f355spider
    f355spider F1 World Champ
    18,026
    You can buy a OBDII scanner that works with a laptop for $12 on Ebay.
    Search for "ELM 327". It will come with some freeware, but there are other freeware available as well that will work and offer more capabilities.
    This is the one I have been using for the past 7 or so years:
    http://www.ebay.com/itm/ELM327-V1-5-OBDII-OBD2-CAN-BUS-USB-Auto-Diagnostic-Interface-Scanner-/150802253413?pt=LH_DefaultDomain_0&hash=item231c83c665
    Read pending and set codes, and clears them. Can display live sensor data too with the freeware included. Other freeware available online can allow for freeze frame, graphing, etc.
