Help with Error Code P0412!!!! | FerrariChat
Discussion in '458 Italia/488/F8' started by 3POINT8, Dec 3, 2020.
  1. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,159
    Hi -
    I am getting error code P0412 - secondary air pump. My mechanics can clear the code but it just comes back. The secondary air pump is working fine. They believe its just a software issue. They cannot fix it and recommended I contact my dealer. I contacted the local dealer but they have not responded (which is par for the course). Please help!!!!
    Jesse
  2. Tarek307
    Tarek307 Formula 3
    1,346
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    tried to search the forum a bit for you, but man oh man, so many people here start threads asking questions, then fix their issue and never update with their fix..people like that shouldn't get any help since they don't have common decency to update on their situation.
    usually P0412 on Porsche's (classic aircooled) mean secondary air injection issues that have to do with carbon build up, not saying its the same thing with this newer modern ferrari. (carb build up can be manually cleaned up, i know i had it done on my car and it wasn't alot of $$
  3. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,159
    thanks for searching. and thanks for the reply. my dealer indicated they believe they can clear it so i am going in to find out. i will be a gentlemen and update the post!
    Tarek307 likes this.
  4. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,159
    Ok dealership was very helpful. At first they thought it was a pinched wire in the wiring harness. But then it turned out the connectors for the solenoid valve and PCV valve had been incorrectly installed. So they swapped those and we are good to go.
