Hi All Doing a bumper tuck on my 1975 308 GT4 and ran into a problem with the front, passenger side blinker. The housing hits the body and won’t let us push the bumper in unless the housing is removed. Driver’s side is fine. I see a lot of people have done this job on here but don’t see any reference to the blinker housing. Anyone have any ideas? Also the side pieces don’t fit right now that the thicker part of the bumper is pushed back. Any suggestions re what to do about this? Rear bumper is done and seems to be as far as it will go in. A few pictures if that helps. Thanks! Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Can you not loosen the nuts on the back of the bumper and raise it up on that side to get the clearance you need for the turn signal? Maybe slot the holes in the bumper shock if you need more movement. Sent from my iPhone using FerrariChat
