help with 355 torque specs | FerrariChat
Discussion in '348/355' started by SeattleM5, Feb 2, 2016.
  1. SeattleM5
    SeattleM5 Formula 3
    1,259
    Kirkland, Washington
    Ettore Palazzo
    #1 SeattleM5, Feb 2, 2016
    Sorry, I know there are a lot these types of posts on the forum. I did my best to search for the answer as well as review the workshop manual without finding a definitive answer. I hope my friends here can lend a helping hand.
    Question #1: 355 Rear axle shaft nut torque. No mention of it in the WSM torque specifications. I found one post from Ernie that mentioned 250 Nm (184 ft/lb) for this nut, however, it wasn't clear to me if this was specific to the 348. According to Ricambi the 355 rear axle nut (part# 209184) crosses to the 348 so I presume it carries the same diameter/thread pitch and perhaps the same torque spec?
    Question #2: In the WSM there are two different torque spec listings for the bolt connecting the axle shaft to the differential shaft. The first listing states 78 Nm (57.5 ft/lb) while the second listing states 95 Nm (70 ft/lb). The same thread pitch for the fastener (10 x 1.25) is listed for both (see attached screen shot of WSM). Anyone know which is the proper torque setting?
    Many thanks for the help
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Axle nut: 275 NM
    Axle bolts: 78 NM
    Both require Molykote 1000
    Get yourself the 360 WSM, much better than 355 and much of the same info applies.
  3. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    Thank you MCJoe, you are the best!
