Help - TR Tire pressure | FerrariChat
Discussion in 'Technical Q&A' started by pdavis, May 24, 2004.
  1. pdavis
    pdavis Rookie
    Oct 31, 2003
    37
    Morristown New Jersey
    Preston
    I just put a set of 18" Michelin Pilot sport low profile tires and rims on my 1988.5 TR. I would appreciate some advice on what tire pressure to run in them. Can someone tell me the factory recommended tire pressure on the 512TR? Thanks. pd
  2. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,032
    Summerfield, NC
    Tom Jones
    If I remember correctly it's 35 front and 34 rear.
  3. steve f
    steve f F1 World Champ
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    hi its 35 front 34 rear in my handbook for f512m
  4. pdavis
    pdavis Rookie
    Oct 31, 2003
    37
    Preston
    Thanks guys. I was running 38 all the way around and I thought that the ride was a little to stiff. I will use the 35F/34rear. pd
  5. TR Mark
    TR Mark Rookie
    May 8, 2004
    28
    Orange Beach, Al
    Mark G.
    I am think about doing a wheel/tire change on My 88.5 T/R. Would love to see pic of what you did.
    Mark
  6. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,600
    Pacific NW
    Anthony C.
    I just spoke to someone at Tire Rack about the issues of proper pressure for going plus 1 or plus 0 on tires/wheels packages. He had inform me that if the overall diameter, width and load of the car has not changed, regardless of the wheel size or tire profile, you should stay and use whatever the manugacture recommended pressure is, which is 38psi all around. If not, uneven tire wear could occur.
  7. pdavis
    pdavis Rookie
    Oct 31, 2003
    37
    Preston
    Anthony, I appreciate the response but this does not sound right to me. It also begs the question as to why the 512TR would use the 35F/34R pressures even though I understand that the suspensions are different between the two cars. A lower profile tire has more sidewall stiffness than a normal (high profile) tire so logic would suggest that the reommended tire pressure would be lower --- I think ???
    TR Mark, I will post some pictures as soon as I have a chance. pd
  8. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,600
    Pacific NW
    Anthony C.
    That's what I was told and explained. It is from someone that works at Tire Rack, and someone who has a pretty good reputation in another Auto-Forum that I visit often. If you think about it, it is actually not that off the wall. As many has pointed out on other posts, the 512TR is a completely different car than the TR. The overall weight and the weight distrubution are different, the supsension setup/geometry is completely different, the chasis is about as different as it can be as one has a sub-frame and the other does not. And I think the tracks may also be different as well, not sure about this one. Anyway, my point is, because they are two different models. Think of it this way, if the 512TR weights 3600lbs vs. TR at 3800lbs, by putting the same amount of air in the TR as you would in a 512TR, wouldn't you be under-inflating the tires if the overall dimension of the tires/wheels has not changed? Anyway, I have heard this from more than one person in the past and this is where I got it from most recently as I (Tifosi) asked the question on the Audi forum: http://www.audiworld.com/forum/wheel.html Just scroll down to the post regarding upgrading to 17" wheels/tires for an A6.
  9. pdavis
    pdavis Rookie
    Oct 31, 2003
    37
    Preston
    Thanks for the reply Anthony but now I am officially confused. Here are some pictures of the wheel/tire combination. The wheels are titanium and made by Ronal. They have a web site for anyone interested. pd
  10. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,600
    Pacific NW
    Anthony C.
    Sorry!! I was just trying to help and pass along what I have been told and explained, that's all. Also, remember your first post, you stated that you car's ride was stiff, don't forget that you have gone up 2 sizes on the wheels, and they are suppose to make the ride more stiff as that is the whole point as when someone wants to improve handling on their cars by going with larger rims.
    The car looks really nice with those wheels on.
  11. pdavis
    pdavis Rookie
    Oct 31, 2003
    37
    Preston
    Anothony, I take your point and will give it a try at the old pressures. pd
  12. pdavis
    pdavis Rookie
    Oct 31, 2003
    37
    Preston
    Anthony, I just read the Audi world thread and it does support what you are saying. Thanks for the follow up. pd
