Help please: difference between "idler bearing" & "tensioners" & "tensioner bearings" | FerrariChat
Discussion in 'Technical Q&A' started by arizonaitalian, Mar 2, 2012.
  1. arizonaitalian
    arizonaitalian Two Time F1 World Champ
    Oct 29, 2010
    20,446
    Wyoming
    I am about to get a "belt job" done on my CS as part of the "major".
    I want to do it "right/safe" and have no interest in taking any risk in return for saving dollars on service. So, please no debate here about whether or not to do these things...(i've read those threads in my search/research).
    But, I could use some help as to terminology and what things are:
    I asked the mechanic for a "full belt job with tensioners" and the mechanic came back and said:
    "Belts with idler bearings" is one price (its buried in the "major" price, but I am guessing its $2200).
    Adding "tensioners" was another $1200 (parts and labor).
    Can anyone explain if "tensioners" is a slang/shorthand word for "tensioner bearings" or are they two different things?
    What are idler bearings and why different from tensioner bearings?
    Is $2200 for a belt and idler bearing job about right? ($145 per hour labor rate)
    Is $1200 more for "tensioners" parts and labor in the right ballpark ($145 per hour labor rate).
    Thanks in advance!
  2. DGS
    DGS Six Time F1 World Champ
    69,596
    MidTN
    DGS
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #3 2NA, Mar 2, 2012
    It's a good idea to make sure everyone is on the same page.
    What we typically refer to here as "tensioners" are in fact usually an idler pulley that has an integral bearing that is known to be problematic on a few cars. On the CS it is part #15 on this drawing. The 360 also has a hydraulic gizmo that applies pressure on these pulleys that is known as a tensioner or "tightener" (part #24). I recall that on some early 360s there was a problem with these parts breaking that led to engine failures (Rifledriver posted a picture). I'm not sure that it's anything to worry about now but it would be a good conversation to have before the work gets done.
  4. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #4 Crowndog, Mar 2, 2012
    See below in the diagram parts 18,22,26,27,25,21 make up the "tensioner"
    parts 23 is the bearing
    So you are really talking about two things here the tensioner device made up of 7 or 8 parts
    and the bearing itself. So to replace the tensioner would be expensive for both sides. Usually unless a part is broken maybe just the spring part 25 is replaced. But the unit is usually cleaned up.
  5. arizonaitalian
    Oct 29, 2010
    20,446
    Wyoming
    You guys are GREAT! Thank you.
    Ok, at the risk of being pedantic...but, so I'm clear:
    What "often if not always" are referred to here as the "tensioner bearing" is *officially* called an Idler pulley "bearing" or?
    (Fwiw, that looks like the thingy I had seen pics of here someplace...in fact, IIRC, they were from Hill Engineering?)
    As a follow-up (and again for claryity), is the officially named "idler pulley" the thing that gets all the debate here about whether it should or should not be changed "each and every time you do the belts"?
    Or is the thing that gets the debate the officially named hydraulic gizmo "tightener" the thing that folks debate changing?
    I am beginning to think the "confusion" here is because of using the word "tension(er)" to descibe one or more parts of a whole system of parts that in fact provides "tension" to the entire belt. I could use help breaking down (no pun intended) which parts to replace when doing a belt job...
  6. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    In my own dictionary in my head if the pulley doesn't run any device it is "idle" and therefore serves another purpose to maybe redirect the belt or put tension on the belt. That is not official just my way of defining it. It can take the form of a bearing or a pulley. Depends on what is to be accomplished i guess. Others here may elaborate no doubt.
  7. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    My version........
    Belts - self explanatory.
    Tensioners - this is the term used by most people to describe the idler pulley/bearing (which is the item many people replace with the Hill unit). The vast majority of people seem to feel that replacement of these is appropriate with each and every belt change. I understand that a number of belt failures are believed to have been caused by one of these bearings seizing or at least getting sufficiently stiff that they don't rotate at the correct speed and cause friction and heat which causes the belt to break. Some people simply check the bearings for smooth operation and lack of any play and will use them a second time. Personally I'd be inclined to replace each time the belts are done. The pulleys are mounted in a concentric (off centre) fashion and depending on where you set them they increase or decrease the tension applied to the belt. I guess in that respect they are in fact "tensioners"!
    The other items (comprising of several separate components) are actually hydraulic dampers. They don't actually apply much by way of tension but what they do is prevent the belts from "flapping" at various frequencies by taking up and releasing any slap in the belts. As I understand it most people do not replace these each and every time they change the belts as it's considered over-kill. That said, I'm sure your mechanic will inspect them to ensure there is no obvious sign of wear or fatigue and recommend replacement if needed so I'd be inclined not to request replacement at this stage but ask them to to simply check them.
    Hope this is of some assistance.
  8. MD355
    MD355 Formula Junior
    Mar 8, 2004
    802
    Athens, Greece
    MD
    I am about to perform a belt change on my 2002 Ferrari 360 modena and I remember during the last belt change that my mechanic noticed that L.H. HYDRAULIC TIGHTENER was a little loose... He said that maybe on the next belt change we should replace it...
    What do you guys think ?
    I understand that it is a hydraulic damper (not a spring) so do these go bad over the years...
    He noticed that the R.H. HYDRAULIC TIGHTENER was tighter... Could it be that our cars are prove to failure of the L.H. tightener...
    My mechanic made a remark that on certain parts on-line retailer they charge more for the L.H. tightener than the R.H. tightener as they are more prone to failure...
    Is this true ?
    Thanks !
