Help needed -- ran 2 days ago, now won't start | Page 2 | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by El Viejo Loco, Nov 23, 2017.
  1. El Viejo Loco
    El Viejo Loco Rookie
    Feb 5, 2015
    18
    Middle TN
    Michael D
    Yup, already done most of that since I posted. I was able to suck fuel from tanks to engine via suction at engine fuel line; loaded filter-to-pump line with fuel; still no effect from energizing pumps. Based on sound/feel, I think only 1 pump was working and thus fuel was short-circuiting. I'm ordered 2 new Facet 476087 silver-tops and am in the midst of dropping the old pumps (original to car, so not gonna just replace one) and will bench-test when I've got them out.
    Remaining hopeful....
  2. El Viejo Loco
    Feb 5, 2015
    18
    Middle TN
    Michael D
  3. samsaprunoff
    samsaprunoff F1 Rookie
    4,160
    Edmonton, AB Canada
    Sam Saprunoff
    #28 samsaprunoff, Dec 15, 2017
    Good day Michael,
    If you are not getting fuel at the engine side of the fuel line, then what not simply remove the other end of the line at the fuel pump and blow some air through it to ensure that the line is not plugged, collapsed, or kinked (before removing the hose at the pump, ensure to have a small section of plugged hose, etc to stop any fuel that may flow from the pump even when off)? Doing this will determine if the fuel flow problem is from the pump backwards or forward. If forward... then a hose issue... if backward, then the you will need to dig deeper into the pump, filter, and or feed from the fuel tank.
    Cheers,
    Sam
  4. El Viejo Loco
    Feb 5, 2015
    18
    Middle TN
    Michael D
    Suction at the engine fuel delivery hose pulls fuel all the way from the tank, which I interpret as leaving only one reasonable possibility: fuel pump failure.
  5. El Viejo Loco
    Feb 5, 2015
    18
    Middle TN
    Michael D
    Pulled both pumps, tested: one pumped exuberantly, the other not at all. I'll replace both; pumps arriving Tuesday (ojala) from Pegasus Racing, $98 apiece.
  6. larryg
    larryg Karting
    Jun 30, 2004
    232
    Louisville, KY
    Larryg
    Just installed those on ours as we also only had one pump working. I highly suggest replacing the fuel lines if you haven't done so already. It wasn't as hard to do as I expected and the rubber was in terrible shape.
  7. El Viejo Loco
    Feb 5, 2015
    18
    Middle TN
    Michael D
    Good point. I'm looking carefully at the fuel lines but mine were replaced after I bought the car and still look/feel good, except the little jumpers between the pumps.
  8. El Viejo Loco
    Feb 5, 2015
    18
    Middle TN
    Michael D
    Final (?) update to this thread: after replacing both pumps and energizing, I found some under-hood fuel lines seeping so replaced the hoses from the t-junction to the carb fuel rails. Everything stayed dry, and she started right up and ran great. Whew! Just in time for delivery to my daughter as a Christmas present.
    Thanks to all for the help and advice, and happy holidays!
    Jasonberkeley likes this.
  9. roger21
    roger21 Formula Junior
    Aug 13, 2015
    262
    France
    Stéphane
  10. Jasonberkeley
    Jasonberkeley Formula 3
    Apr 23, 2017
    1,321
    NW Corner, CT
    Jason Berkeley
    Nice Christmas present! Hope she appreciates the car and your many years of dedicated ownership!
