Help finding a wire crimping tool. | FerrariChat
Discussion in 'Technical Q&A' started by Air_Cooled_Nut, Mar 26, 2008.
  1. Air_Cooled_Nut
    Air_Cooled_Nut Formula Junior
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    I'm looking for a decent wire crimper tool that can accept various dies for different types of crimping. I would like to make OEM-type of wire connections like double-crimps as well as barrel crimps like what's found on quick-disconnect terminals (i.e. spade connectors we all love and use :) ). So what I want is a step up from the inexpensive crimpers typically found at a FLAPS but below the $200 mark. A ratcheting crimper would be ideal from what I've seen so far. Recommendations?
  2. Pranucci
    Pranucci Formula 3
    1,108
    Carpinteria, CA
    Klein or AMP from an electrical supply house. I have an AMP ratcheting crimper that does 22-24 gauge for audio multipin connectors. One point is that the tool is designed for a certain connector and doesn't do any other types. If you want interchangeable dies, I'd call AMP. They used to have sales reps that would meet you and get you the right tool/crimps, the catalogs are confusing.
  3. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
  4. Air_Cooled_Nut
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
  5. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    You can do the double crimps with a pretty cheap tool. I have one that probably cost under $10. Looks just like the ones for doing the barrel crimps only has sort of an upside down "m" in one side of the jaws.
  6. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    LOL
    I didn't understand that you didn't understand...... I was just trying to help
    Truthfully I own many crimp tools for different needs and I'm not totally sure I understand what you are looking for. As KKRace said, i think all you need is a pretty cheap crimp tool.
    Then again I would contact and ask them http://www.mouser.com/
  7. Blue@Heart
    Blue@Heart F1 Rookie
    Jun 20, 2006
    3,889
    Yellowknife, NWT
    David
    +1
    I'd get in touch with AMP and they should be able to point you in the right direction. I wouldn't go talking to mouser first, you might get solid advice from them or you might not....it's a tossup
  8. Air_Cooled_Nut
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Oh, I didn't understand that you didn't understand that I understood...my eyes are now crossed LOL :D It sounds like you're an expert as you have specific tools for specific needs whereas I'm an amatuer -- although a detail-oriented, anal-retentive one ;) -- and am looking for a nice, multi-purpose tool.
    For example, the recommendations of using the AMP brand is what I'm looking for. Brand recommendation. People who have used a particular tool and like it enough to recommend it. I do my own automotive/motorcycle/PWC wiring, stereo and alarm work. I know I'm doing a good enough job where everything is lasting for decades. I want to move up in the presentation and security of my wiring and that requires wire connection crimps similar to OEM, the double-barrel crimp (at least that's what's used on my German cars...don't rightly know about Italian cars). I've had requests from other people to perform wiring in their vehicles so I want to provide a factory-look crimp but without going over-board (in terms of tool costs) as it's not my profession.
    Some day I'd like to buy a label printer for heat-shrink tubing...I'd be in wiring nerd heaven!
  9. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,252
    Black Forest Germany
    Martin N.
    #9 Martin308GTB, Mar 27, 2008
    Hello from Germany,
    since costs for a decent crimping tool over here are crazy, two years ago I asked a fellow FChatter to buy me one in the US and send it to me.
    I have chosen this product:
    http://accel.carshopinc.com/product_info.php/products_id/59603/170036
    It is truly a heavy duty tool, 100% comparable with the pro tools here but 1/3 the cost and has the benefit of interchangeable inserts. It comes with three sets of inserts for crimping isolated connectors, non-isolated connectors and 8mm plug wire terminals.
    I use it all the time and it's perfect.
    Picture shows an example performed with this Accel crimp tool.
    Best Regards
    Martin
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    Even in the US, $63 for a crimping tool is still crazy.
  11. Wingnut
    Wingnut Karting
    Feb 11, 2005
    151
    Corolla, NC
    I usually put a solder dab on the exposed copper wire at the top of the crimp using a small solder gun and silver solder. This will hold and make good electrical conduction even if the crimp isn't picture perfect! Some practice is needed before going to the car's electrical wiring.
  12. Motob
    Motob Formula 3
    Nov 11, 2003
    2,338
    Frederick, Maryland
    Brian Brown
    That racheting crimp tool is cheap, and is one of the tools that I use. Before that tool came out, I paid over $300 for a factory BMW crimp tool in 1985.
    The factory AMP crimp tools are in the same price range.
    Brian Brown
    Patrick Ottis CO.
  13. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    I definitely do NOT like the "Amp" brand crimper, It squishes more than it crimps.
    If you are doing any wiring, you need to ask for a free Waytek catalog. Their selection and quality is great.
    I like the 3M crimper on this page, but I most often use a manual Snap-on crimper, the one with the red and black handles.
    http://order.waytekwire.com/IMAGES/M37/catalog/220_029.pdf
    Jay
  14. Air_Cooled_Nut
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Nice! Thanks for the link and picture :)
  15. Air_Cooled_Nut
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Ooh, didn't think about Snap-On...then again, their stuff is a tad pricey. I'll look into that as well as AMP. Thanks guys!
  16. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Hi Martin,
    I just ordered the tool and am looking for some of the double crimp style connectors that grab both the wire and the insulation.
    thanks,
    chris
  17. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    +1
    I'm ASTONISHED by the prices of those tools in the US...last summer I fabricated a wiring harness for a racing car, we used a tool that looked exactly like the one here: http://www.starkelectronic.com/300-055.gif . Difference: We didn't buy it for the 30 bucks it costs in the US, we rented it for that amount, buying it would have cost a friggin 600€... I see a HUGE market in importing cheap crimping tools :D
  18. Martin308GTB
    Jan 22, 2003
    4,252
    Martin N.
    Hi Chris,
    is it kind of a problem to find those double crimp non insulated connectors in the US ? Over here they are getting rare within the automotive business. Rarely anyone demands those old-fashioned connectors. But in the electronical environment you still get them easily. If you have problems, I would gladly help, because I have hundreds of these connectors here.
    I always prefer them over the colorful insulated connectors. For additional protection I just use some shrink tubing over the crimp on ground connections and over the whole connector on +-connections. Furthermore, for best reliability on important connections I perform the same what 'wingnut' suggested. A slight solder dab on the tip of the wire. But never too much, because no solder should creep into the insulation. This makes the connection prone to failing / breaking just behind the crimp.
    BTW, what's correct while talking about wires ? 'isolated' or 'insulated' ?
    Best Regards from Germany
    Martin
  19. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    McmasterCarr
  20. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Insulated.
    Isolated is separated from others, alone, etc.
    Insulated is protected from others by a barrier.
    The difference can be subtle sometimes.
  21. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    The one I have is very similar to #419 in the above link. Works fine for repairs the couple times a year and I doubt I paid too much more than $20. If I was doing more of them I'd probably get something better like one of the ratcheting type. You could always check Ebay for a used one.
  22. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    It's what we use for the plane and the race bikes. You need to order all the various accessories with it though, to make sure you've got the right die for the wiring size.
    Art
  23. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    This crimper is available on Amazon for around $49. HTH.
