Help! Advice needed on Leather repair for Vantage passenger seat... photo | FerrariChat
Discussion in 'British' started by FerrariCognoscenti, Jan 31, 2021.
  1. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    My 200 pound friend rode in the passenger seat of my 2007 Aston Martin Vantage with the heat seater on and the coil from the heat seater left a pronounced indentation after sitting on the seat for a 2 hour drive. Before this the leather was pristine and perfect. What can I do to fix this leather and get rid of the creases? Any advice is greatly appreciated.
  2. Jeff328
    Jeff328 Formula 3
    2,293
    WI
    That's weird, I have a 2007 Vantage and weigh 200 pounds and my seat doesn't get any lines in it even after 5+ hours in the seat. I suspect that those lines will eventually disappear on their own. If it really bugged me I would try massaging them out using my hands and if that didn't work I would try it again this time using a little heat from a hair dryer or heat gun on very low heat. Not too hot to touch, just enough to make the leather more pliable.
    flash32 likes this.
  3. luvair
    luvair Formula 3
    1,497
    #3 luvair, Feb 1, 2021
    I had wrinkles on my Italian leather sofa. 200 pounds should not create wrinkles, IMO.
    Clean your seats with a leather cleaner, ideally in a warm environment.
    Let the cleaner stay on the seats for about 1 plus hours. Use a heat gun at the lowest setting a safe distance from the leather. Can also use a hairdryer. Make sure you keep moving the heat gun/hairdryer with a longer extension cord and don't focus on one area. Use damp cotton towel/microfiber every 20 or so seconds. Repeat if necessary. It all should remove all wrinkles. When done, use a leather conditioner. Good luck.
  4. Rbwiii
    Rbwiii Formula Junior
    Aug 9, 2014
    606
    Cali
    BW
    Steam should work. Take it to an upolster shop and see what he can do with the steam
