Help! '08 Scud mis-shifting to neutral | FerrariChat
Discussion in '360/430' started by schunmd, Nov 3, 2014.
  1. schunmd
    schunmd Karting
    Oct 18, 2010
    203
    Peninsula, CA
    My '08 Scud started to mis-shift into neutral while trying to shift gear, only at occasion. I shift again, and it goes back into proper gear normally, and then it shift normally again. F1 gearbox warning light also came on few times.
    Took it into my mechanic, and SD3 showed two codes:
    P1742 Selection Potentiometer
    P1770 Gear engagements with wrong shifts
    Clutch wear was showing 49.84% worn.
    I had an actuator fluid flushed and bled; there was no leak. I drove afterward, and it is still doing mis-shifts with F1 gearbox warning light coming on again. Took it back to the mechanic, and it shows same two codes as above. In addition, this time Clutch wear is showing 100%; checked it twice.
    If the clutch wear was still 49.84%, I would have thought changing an actuator to a rebuilt one would solve the problem, but this clutch wear of 100% within last 70 miles is confusing me.
    My clutch wear a year ago (2500 mi ago) was at 43%, so I thought 49.84% was an expected number. I have no idea why 100% wear is showing now; can't imagine it being correct, but we checked it twice more with same readings.
    Any thoughts on what may be going on, and whether I should try changing the actuator first or the clutch first? I hate to do both if only replacing one can solve the problem; it's very costly.
    Thanks in advance for your input!
    p.s. time like this I wonder if I should trade it in for a new GT3 that's sitting in the show room at a local Porsche dealer right now... But then, I can't imagine anything else replacing what my Scud can do when it's behaving...
  2. margarita
    margarita Formula 3
    Mar 20, 2011
    1,618
    usa
    You should check the clutch
  3. schunmd
    schunmd Karting
    Oct 18, 2010
    203
    Peninsula, CA
    How can I explain clutch wear going from 49% to 100% in 2 weeks?
  4. Rifledriver
    36,750
    Who suggested an actuator rebuild???
    Did the guy look at the clutch??? It can be seen and it is more accurate a measurement by eye than the machine.
    If your guy has not done or suggested any of this fire him and find someone who has just a little idea how to fix these cars. Your current guy doesn't seem to know **** all.
    Next. We have a shifting problem and the SD3 has on at least 2 occasions tried to tell you what is possibly wrong but yet we are ignoring it. Why???
  5. Financialman
    Financialman Formula 3
    Sep 8, 2005
    1,841
    San Jose CA
    Dan Carpenter
    My 430 did this, it was a worn out clutch, car had 20K miles on it.
  6. schunmd
    schunmd Karting
    Oct 18, 2010
    203
    Peninsula, CA
    Thank you for your inputs. He did suggest looking at the clutch from below and try to actually measure it directly.
    Sounds like it's most likely my clutch? It has almost 16,000 miles.
    Maybe I should get a second opinion?
  7. schunmd
    schunmd Karting
    Oct 18, 2010
    203
    Peninsula, CA
    Did you get it done at a dealer or an independent shop?
  8. windsock
    windsock Formula 3
    1,129
    You have errors stored twice for a potentiometer which is what provides the shift actuator position to the TCU. If the potentiometer is failing and providing inaccurate information it will default to neutral. Either take an acquisition with the SD unit or better yet monitor with a Lab scope and confirm the sensor is accurate and consistent. Unless there is an external leak with the actuator it likely does not need rebuilding. Erratic clutch numbers can be due to a failing clutch position sensor.
    What is the new clutch position reading in parameters? What was the clutch position reading key on engine off on the visit that resulted in a 49% clutch wear reading and what is the current clutch position now that it reads 100%. Note that using the wrong software in the SD unit F131E VS F131ELP will result in incorrect clutch readings.
  9. Finitele
    Finitele Formula 3
    Sep 26, 2007
    1,379
    DBC
    DIR
    Yes, you should trade this for the Porsche, you seem to be throwing cash into a hole with this issue. Find a proper mechanic to zoom in on this rather than shotgunning the edges of the problem
  10. Financialman
    Sep 8, 2005
    1,841
    San Jose CA
    Dan Carpenter
    Independent shop.
  11. schunmd
    schunmd Karting
    Oct 18, 2010
    203
    Peninsula, CA
    Definitely getting a new mechanic. I only ended up with him this time because the problem occurred on Sat, and he was the only local guy available to trouble-shoot. Fortunately, only spent money on changing the actuator fluid so far, but he was leading me down the path of changing the actuator + clutch, not guaranteeing the problem would be solved. That's why I posted this thread; didn't feel comfortable he was diagnosing this properly.
    Thanks for all your inputs, and will post final resolution once I get it fixed properly.
  12. schunmd
    schunmd Karting
    Oct 18, 2010
    203
    Peninsula, CA
    New clutch took care of the problem!
  13. sunir
    sunir Formula Junior
    Oct 30, 2014
    758
    MD
    Sunir
    Sounds like could be an expensive bill no?
  14. Hardistyfezza
    Hardistyfezza Formula Junior
    Clutch - where have we heard that one before!! Happy driving.
  15. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
    Glad to hear the problem is resolved. Happy driving!
  16. schunmd
    schunmd Karting
    Oct 18, 2010
    203
    Peninsula, CA
    Thanks!
    New clutch feels so much crispier shifting!
    Yup, was an expensive bill, but hopefully will last a while.
