Heater Hose Replacement Made Simple | FerrariChat
Discussion in '308/328' started by tr0768, May 12, 2009.
  1. tr0768
    tr0768 Formula Junior
    Oct 28, 2008
    735
    Lake Stevens Washington
    Howard Musolf
    I was Sleepless in Seattle worrying about replacing my 308's heater hoses. I was mindful they were over 25 years old and harder than a dead carp. I read other posts and they did not make me warm and fuzzy. As we are in the automotive service business I know hose and belt manufactures reccomend that hoses and belts be replaced in 18 month to 2 year intervals, and the 308 was long overdue. I had to previously removed the drivers side fuel tank to repair a leak, so with that tank out I decided to take the bull by the horns and replace the heater hoses. I have found a couple of tricks that will make the job easier, so with that in mind, here goes.
    1st the drivers fuel tank is removed, with that in mind, you can see the heater hose and the brake booster line coming thru the rear bulkhead. They make a sharp bend upwards around a frame bracket. You need to remove the hose from where it connects to the cylinder block and then pull the heater hose straight thru the bulkhead so it runs parrollel to the door sill. The heater hose is the smoother of the 2. The braded hose is for the brake booster and should not need to be repalced. Next you need to open the drivers door and pull back the carpeting around the rear of the door sill ajacent to the serial number plate. You will see a formed aluminum plate pop rivited to the body. you need to snap the heads off the rivits and remove this plate as it coveres the access hole for the heater and booster hose. This is where these hoses bend thru the rear bulkhead and begin their run thru the door sill. Next remove the drivers seat 4 allen head cap screws 6mm cap size. I will explain why the seat should be removed a little later on.
    Next go to the front wheel well and remove the inner wheel opening panel at the rear of the opening 5 phillips head machine screws. Carefully pry this panel out and down, its aluminum don't bend it. This will expose the hoses as they travel from the horizontal door sill up into the spare tire compartment. There is a metal band about 1/2 way up the hoses and you need to unbend this from around the hoses.
    Open the hood and on the drivers side you will have to look between the defroster plastic bend and the aluminum pedal base and you will see the heater hose comming up from behind and connecting to the base of the "Y" fitting at the back side of the heater control valves. Soak this hose with spray penetrating oil be fore trying to remove the hose. The heater control valves are held to the bulkhead with 2 10mm nuts remove them and gently pull the assembly forward, this will allow better access to the hose being replaced. After the clamp is removed you can (after soak time) begain to move the hose around and break the hose loose. Once this hose is off the "Y" you can now move the heater vales off to the side out of the way.
    The easiest way to replace this nearly 7 foot long hose is to connect a new hose to the end of the old one and pull the old hose out from the rear!!!!! Here is a trick that worked well for me. I purchased a double ended barbed brass hose fitting ( like you would repair a garden hose with). I sprayed the inside of the old dry hose with penetrate oil and pushed the barbed fitting into it. I then took the new hose and sprayed it too and pushed it onto the other end of the barbed fitting. With help at the front end of the car of a friend pushing the hose, I was at the rear wheel well pulling at the same time, the hose moved easily from front to back. We watched for the fitting to reach the access hole at the rear of the door opening. Once there I took a long punch and and hammer and bent the back edge of the access hole down to allow a more gentle bend for the hose as it passed through this area. I pulled the hose thru and had excess hose at both in the front and in the engine compartment.
    Now at his point I decided to add a couple of parts that would solve a potential problem with the hoses along the road. I added a shut off valve at the cylinder block where the heater hose connects. A valve here allows me to turn the heater water off should the hose burst along the road. To me this is an addtional safety factor should a hose failure occur.
    I had earlier decided that I wanted to replace all the heater hoses behind the dash and running to both heater cores. There is another long heater hose from the lower main aluminum water pipe up and "Teeing" behind the power brake booster. Its damn near impossible to see and no way in hell are you able to remove the clamps. At this point it was bier time, cold cold bier. after much bier consumed and lots of head scratching I formed a plan. If I could get some extra room behind the power unit I might be able to actually see the end of the hose and get to the clamps.
    I decided to remove the booster unit and master cylinder but I could not get to all the bolts so that was out. I then figured that if removed the bolts that hold the aluminum pedal base and then the booster hose maybe i could get enough room to get my hand behind and remove the clamps. There are 2 17 mm bolts on the spare tire side of the pedal base and then(remember why we removed the seat) under the dash there are 2 13mm bolts. While I was there I removed the clevis pin for the clutch cable. I was laying on my back under the dash with my feet over the targa bar, an interesting position. One of my managers saw me and told one of the techs that I looked like Mork from Mork and Mindy.
    I was able to move the booster away from the bulkhead and off to the right hand side of the car, allowing the much needed access to the hose and the "T". Now this main hose that comes from the lower aluminum radiator pipe up to the "T" and then 2 smaller hoses, one of these hoses go to the left heater core and the other goes to the right side heater core. I removed the hoses from both heater cores and on the rhs hose I installed my hose barb and pushed on a length of hose for that heater core. This hose also runs behind the booster so I had the hose longer to pull thru and then pull it all back in place when I installed the long hose from the aluminum radiator pipe. It is much easier to acces the hose for the drivers side heater core. With the hoses , "T", and clamps in place I pulled all the hoses back in place and then cut the excess off and reconnected the hoses to the heater cores. Before I reinstalled the heater cores I backflushed both and removed a lot of sediment. On the large hose, I also added a shut off valve, so I can shut off the heater water supply at the pressure and return sides. I replaced the short hoses on the heater control valves as well. All heater hoses have now been replaced as well as all new stainless clamps. I used vasoline on the inside of the hoses so they won't sieze on the nipples.
    I used NAPA black 1/2" hose for the run from the motor to the heater control valve. I used 5/8" black NAPA heater hose for the long run in the spare tire well. The reason I used 1/2" thru the body was to get a little more clearance. It will expand enough to fit the nipples without a problem. Be sure and use the black hose it is much more flexible and slippery. I did not use any silicone because this car is going in for a bare metal respray next week and I did not want silicone on or around the body. That my story, and I'm sticking to it!!!!! I forgot to mention that I had also removed the spare tire well insert. This makes the hose replacement much easier. Any questions or thoughts just pm me.
    Howard Musolf
    1981 308gtsi
    Maserati Spyder
    2 many brass era cars
  2. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Only one shutoff valve? If a heater hose blows you need to isolate the heater circuit at both ends. The heaters are connected at the engine block for the hot supply and at the radiator output for the "cold" return. If a heater hose blows and you turned your valve off it would still leak from the water coming in through the radiator side. The valve would turn off the heat if the heater valave stuck on, though.
    I've done the hose replacement on the GT4 very much like you did. It wasn't fun, but wasn't truly awful either.
  3. tr0768
    Oct 28, 2008
    735
    Howard Musolf
    I did add valves at both the engine/pressure side of the system and at the return side of the system. The second valve was placed by the heater control valve. I can shut off all water flow through the heater system. If I should have a hose failure I can isolate and shut off all coolant throught the heating system and not loose critical coolant for the motor.
    Howard Musolf
    1981 Ferrari 308 gtsi
    Maserati Spyder
  4. bill brooks
    bill brooks F1 Veteran
    BANNED Silver Subscribed
    Jul 30, 2007
    5,961
    waynesburg,pa
    bill brooks
    howard,
    sorry you didn't see my hose replacement from back in february.
    i moved all 3 heater return lines from behind the dash to in front of
    the heater supply hoses just behind the spare tire cover.
    there were pictures also. oh well.
  5. CarreraScott
    CarreraScott Formula Junior
    Jan 30, 2004
    592
    Charlottesville, VA
    #5 CarreraScott, Mar 18, 2011
    For my 1980 308gtsi, I need to replace the heater hose going from the heater core to the water valve (Danial # Ricambi was nice enough to look this up as part # 110277). While I'm in there I may also want to replace the other hoses in this general area.
    Does anyone know the source and size for these? Are they just 5/8" standard NAPA heater hoses as above?
    My hose at the passenger side heater core has split and is spewing coolant.
    In the diagram attached I need to replace the red one on the passenger side.
    Thanks for any help. I've done many searches and found lots about it but haven't found a specific source for these hoses.
  6. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    #6 ramosel, Mar 18, 2011
    Wow, the picture I cleaned up and colorized is really making the rounds.
    If you want correct looking hoses and are concerned for points, you should get the hosing from Dave Helms. His stuff looks correct and is great hose.
    Or you can do all the large hose with 5/8 and all the small in 1/2 from any supplier. Its a pain in the a$$ to do the long hose and I didn't want to have to mess with it for a long time so I bought the 2 part silicone from NAPA. In that picture, I color isolated that drawing by circuits, not hose size. The smaller hoses attached to the heater cores (both feed and return) can be done with 1/2 inch. The larger hose pieces into and out of the valves would be 5/8". The hose from the T down to the main return line would be 5/8". The primary feed from the motor to the Y at the valves would also be 5/8"
    My best advise - If you have to change that one because of a failure... replace the rest. They are probably not too far behind in the failure schedule.
    Rick
  7. CarreraScott
    Jan 30, 2004
    592
    Charlottesville, VA
    Thanks, and thanks for the pic. I have the pic in my book but its sure nice to have them colorized!
    I definitely plan on at least replacing everything I can reach. Not sure about the long one going to the back. May have to wait till fall/winter to do that. I don't want the car on blocks for too long while Spring weather is around!
  8. stephenofkanza
    stephenofkanza Formula Junior
    Mar 5, 2005
    542
    Kansas
    Stephen LeRoy Sherma
    From what I see the 2nd valve would have to be on the return line that goes to the 1 1/2
    return line.
    If you put it on any of the lines in the heater control system you would 2 (or more ) to isolate the heater.
    I had a TR3 that just had 1 shut off to the heater under the bonnet, of course it was origional equipment.
    Stephen
  9. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    "As we are in the automotive service business I know hose and belt manufactures reccomend that hoses and belts be replaced in 18 month to 2 year intervals"
    The people that make/sell hoses might want to sell more hose but I'd be surprised if you could find a single passenger car in the world that had it's hoses regularly replaced as often as even 3 or 4 times that interval...and with no ill effect. ;)
  10. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    At least on an 82 spyder it is not necessary to remove the left side fuel tank. There is an inspection hole at the bottom of the B pillar. Lost
  11. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Steve (85 308 Owner)
    According to Bill B there isn't a need on 308's. I'm going to be attempting his method in a few weeks.
    http://www.ferrarichat.com/forum/showthread.php?t=229311
  12. Scudjockey
    Scudjockey Karting
    Aug 28, 2010
    81
    Suffolk, UK
    John Marshall
    A big thank you to the originator of the picture. I'm on that job now.
    When I bought the car it was described as needing attention to brakes and carbs. When I pulled the vacuum hose out it had a scorched patch about half way along and leaks badly.
    I guess someone did a small repair to the door cill and the hose got burnt. It leaks a lot. No wonder the brakes and carbs needed attention.
    A proffessional friend of mine said he always does a vacuum leak test on that hose. FWIW.
  13. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    I did ours last year and on our 82 we were able to snake the new greenstripe through until the bend at the bottom of the b pillar. under the carpet there is a trianglular sheetmetal panel and you have to drill a few rivets out. Unless ours is a freak it's not a bad job.
    lost
  14. BNSC100
    BNSC100 Karting
    May 28, 2009
    127
    SC
    Michael
    Do the 328s have the same trap door under the carpet... 1986 328... Assume so...
  15. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    Sorry, we have a 2V. Can't answer but would not be surprised if it is same. Lost
  16. bill brooks
    Jul 30, 2007
    5,961
    waynesburg,pa
    bill brooks
  17. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Can you or somone take a photo of the location of that plate? I jsut tried to replace my hose the bill brooks way and it aint gonna work. That coolant hose wont budge. I really don;t want to take the tank out so maybe this access panel will do the trick.
  18. Badman
    Badman Formula 3
    Mar 4, 2007
    1,116
    Gotham City
    Bruce Wayne
    You did remove the rear access panel in the driver's side wheel well and take the hoses out of the clamp they're in, right?
  19. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    #19 stevel48, Apr 16, 2011
    Oh yeah. it's disconnected at both ends J. it's hung up in the bend by the fuel tank. My wire snake won't even make it through that bend inside the hose. I need to try that access plate.
    I don't think i have the paitence to deal with taking out the fuel tank.
  20. Badman
    Badman Formula 3
    Mar 4, 2007
    1,116
    Gotham City
    Bruce Wayne
    Well, I'm sure none of these cars were put together identically, but my hoses did two 90 degree bends on different axises behind the fuel tank. I don't think even that access panel would have helped me.
  21. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Maybe if I combine that with pulling the tank back as far i can w/o removing it would do it. I think that's my next move.
