heater hose removal | FerrariChat
heater hose removal
Discussion in 'Boxers/TR/M' started by JIMBO, Dec 16, 2019.
  1. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    Greetings,
    Has anyone ever removed/ replaced the two coolant hoses that go from the firewall to the heater core? Specifically, will I have to remove the entire center console or merely the passenger side foot rest? The engine and fuel tanks are out right now. Can I tape the new hose to the old and pull both back out through the firewall?
    Any help would be appreciated before I jump into this project.
  2. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    Sorry, 1994 512 TR
  3. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    1,844
    If you are working on a Boxer, you can tape the hoses together and VERY CAREFULLY pull the new hose through. Make sure you have somebody pushing on one end as you pull slowly on the other end. I am sure others here will have additional methods.
    turbo-joe likes this.
  4. Rifledriver
    34,103
    Austin TX
    Have not done it since the cars were new but it wasn't hard to do. They run through the center frame tube. As I recall the console needed to come out but in a TR512 that isn't a hard job. The run isn't very long on them but as opposed to Dwight I stitch the new to the old together with safety wire. If for some reason a good pull is needed they won't come apart like tape can.
  5. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,931
    romano schwabel
    you also may you some silicone spray
  6. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    1,844
    Brian: You are absolutely correct. I had forgot I have also used safety wire successfully! It is a better way to go. Thanks for reminding me.
  7. turbo-joe
    Apr 6, 2008
    8,931
    romano schwabel
    sorry, misstyping :(
    wanted to write:
    you also may use some silicone spray
  8. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    I have used a plastic connector for my sprinklers that is barbed on both ends. Just push in and both will be locked forever. You can get them in any home improvement store. Maybe 1/2" or 3/4" fitting? I will take a piece of hose with me.
  9. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    I went to Lowe's and found several double-barbed "splicers" in the plumbing section, both in plastic and brass. I went with the $2.64 plastic piece. Once it is pushed into the hose, it is VERY difficult to get out. I would make sure you have a clean (non-stretched) cut end.
    Unfortunately my hose (silicone coolant hose) will not be here until Friday. This should work. I may just put a piece of duct tape over the connection just to be sure.
  10. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    Check out the interior of one of the old hoses. It looks like the original Ferrari hose. Silicone hose is more expensive, but this will never happen.
  11. samsaprunoff
    samsaprunoff F1 Rookie
    4,184
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Jim,
    Just a heads up and perhaps others may comment... When I used silicone coolant hoses in my Boxer I found that clamps would loosen over time and so I had to re-tighten them a couple times a season. After my last engine out I removed the silicone hoses and went back to non silicone high quality hoses and I have never had to retighten the clamps (I still check them though). Others may have different experiences and/or use different clamps (I used ABA clamps) and so it may be worth digging into this further.
    Cheers,
    Sam
  12. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    One of my old coolant hoses was silicone and it lasted 36000 miles with no problems.
