Heat Exchanger (Transmission Gear Oil to Coolant) | FerrariChat
Discussion in '360/430' started by Keith360, Aug 29, 2019.
  1. Keith360
    Keith360 Formula Junior
    Feb 6, 2015
    570
    Santa Barbara County
    Keith Williams
    Hello everyone, I’m looking for a old leaking Heat Exchanger (Transmission Gear Oil to Coolant), Part Number 180846. My plans are to design and evaluate the costs to fabricate replacements at a cheaper price than the factory units. I need the old unit to reverse engineer. I also don’t know what the exact failures are. I’ll look at both stainless steel and aluminum. Those that don’t drive there car hard may benefit from a less complex version with fewer internal tubes.
  2. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,189
    CA & DC
    I suggest Ferrparts in Sacramento.
    Good luck, that’s a worthy project !!
  3. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    Eurospares better price and faster next day delivery too
  4. Keith360
    Feb 6, 2015
    570
    Keith Williams
    Ahh, i’m looking for a trashed unit for free since they are useless to anyone. I have a good one in my car but done really don’t want to take it out as an example. I also want one that is failed to do a root cause analysis of the failure.
  5. Keith360
    Feb 6, 2015
    570
    Keith Williams
    Thanks, I’ll call them.
  6. Keith360
    Feb 6, 2015
    570
    Keith Williams
  7. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,189
    CA & DC
    It’s usually a corrosion failure exacerbated by infrequent fluid changes.
    tifosi101 likes this.
  8. Keith360
    Feb 6, 2015
    570
    Keith Williams
    I agree, I just wanted to dissect it after recording the outside dimensions and look where improvements could be made.
  9. mello
    mello F1 Veteran
    5,042
    CA Bay Area
    Steve
    Do a search and you'll get hits of forum members that have changed it out.
  10. Keith360
    Feb 6, 2015
    570
    Keith Williams
    Great idea, I should have thought about that. Thanks mello
  11. RSR993
    RSR993 Rookie
    Jul 6, 2019
    13
    Jay J
    You're in luck. I have one
    Need4Spd likes this.
  12. hessank
    hessank Formula 3
    1,742
    Canada, Florida
    Fred
    A Company in Canada already did it for its customers (Daytona in Woodbridge). Used different metals than OE.
    Same price though.
    Good luck. I'm in.
  13. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    I just threw one out last week ...
  14. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Where does it actually fail
  15. yelcab
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    Cut open one lengthwise and you will see
  16. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    If i had a 360 and an old one i might just have a look- what is actually failing ?
  17. hessank
    hessank Formula 3
    1,742
    Canada, Florida
    Fred
  18. Keith360
    Feb 6, 2015
    570
    Keith Williams
    That’s great, i’ll PM you for details. Thank you!
  19. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,342
    On the Limit
    Dino
    Every time I hear "Trans heat exchanger", I have to check in with my therapist! I did mine a year or so ago. I'll check and see if I kept the old one. It was a frighteningly annoying experience!
    LorenzoR, tifosi101 and E60 M5 like this.
  20. Keith360
    Feb 6, 2015
    570
    Keith Williams
    I can imagine, and it is in the back of my mind. All I think of is a transmission overhaul or replacement. Yikes!
    It would be great if you had the old one. The other thought was why do I need one, or one with as much heat exchanger surface area? Maybe only need a single spiral loop. I’ve built those before on an aerospace project.
    PM me so we can talk getting it to me.
  21. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,538
    what do they cost new?
  22. Keith360
    Feb 6, 2015
    570
    Keith Williams
    #22 Keith360, Sep 2, 2019
    I know the cost is not outrageous, $600 to $900. I was thinking more to lower the potential failure. I was also looking into designing and kitting water in oil sensor system. Cost was pricey on that.
  23. sparetireless
    Nov 2, 2003
    1,538
    What could work is another cooler that is oil to oil so that the water fail would only put oil in the water
  24. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    What would be the best fix is a plate heat exchanger but the cost would scare the life out of you- advantage with a plate type is that it is not possible to mix the 2 fluids
  25. wbt
    wbt Karting
    Nov 28, 2014
    231
    New Zealand
    Wayne
    I was thinking the same thing and thought about developing a version of this a few years ago, however my now strong belief is that the factory oil/water heat exchanger has a main function of heating the gearbox up quickly rather than providing cooling effect (cooling is a function, but secondary). We all know how poorly ferrari boxes shift when cold, add to this an F1 system which just crashes it through the gears regardless of "feel" I can see why the engineers wanted the gearbox to heat up quickly. Coolant heats up far quicker than engine oil.
    In the end I replaced my exchanger with the factory version in less than one days work. Some fiddly nuts and bolts but nothing too scary involved and it also gave opportunity to replace the plenum gaskets. Seeing the amount of these things which are currently failing (almost daily posts on this forum) everyone should be replacing as preventative maintenance.
