head / head gasket question / hydrocarbons in coolant
Discussion in 'Technical Q&A' started by Martin308GTB, Jul 7, 2007.
  1. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,252
    Black Forest Germany
    Martin N.
    Hello from Germany,
    some problems are really homemade. Today I had the chance to do a check for exhaust gases in the coolant system. Just out of curiosity, because someone could lend me such a block tester. I wish I didn't perform it.
    I have no problems with overheating or coolant losses, but the tester showed tiny traces of combustion gases in the coolant system. Title of this thread is probably wrong. The tester detects CO or CO2.
    The block tester is a highly accurate two-chamber device and the fluid in the lower chamber remained blue, but the fluid in the upper chamber showed a slight change from blue to bluish green.
    Any of you have experience with such a test ?
    What do you think ? Should I tear my engine apart ?
    Best Regards and thank you in advance for your thoughts.
    Martin
  2. boxer frank
    boxer frank Karting
    Sep 30, 2004
    165
    toronto canada
    FRANK
    ZERO COOLANT LOSS AND NO OVERHEATING MEANS HEAD GASKET IS MOST LIKELY OK
    WHAT BRAND AND MODEL IS THE TESTER?
    TRY ANOTHER ONE OR TYPE
  3. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,766
    Atlanta
    John!
    I concur with the above statement. If the engine runs well, does not lose coolant, and has good compression I would not worry about it. Do not get yourself caught up in constantly looking for something wrong.
  4. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I concur as well. Without any visable outward signs of anything wrong, I would sleep easy. But just out of curiosity, when was last time the heads were torqued? Is it possible some oil got into the system via a funnel or container that was contaminated? Keep an eye on it and party on. :)
  5. Martin308GTB
    Jan 22, 2003
    4,252
    Martin N.
    Hello all,
    thank you for your statements.
    Paul; the last time I re-torqued the heads was just 5000 kms ago during my last big service with valves checking and cambelts.
    Frank; the brand of the tester is 'Wuerth' and is identical to the Hazet model.
    Best Regards from Germany
    Martin
  6. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    When the testers first came out some 25 yrs ago I got one. It was quickly found to give numerous false positive readings depending on the type and age of coolant used in the engine. Do not tear the heads off based on results of that test!
    Dave
  7. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    This topic puts me in mind of a similar question ----
    Does anyone know of a reliable (and easy) method to check for the presence of coolant in the engine oil?? Obviously, large amounts of coolant can be identified by a simple visual inspection of the drained oil --- but, I would like to check for minor amounts of coolant.
    My 308 spent the winter in a cold storage space, and I'm not confident whether I had a high enough anti-freeze concentration and system volume to provide adequate freeze protection (got down to minus single digits, fahrenheit, at times). I'm getting ready to pull the sump cover plate, drain, and examine the oil --- and I'm very nervous about what I may find!!!
    I don't suspect that anything could of actually cracked, but I'm concerned that joints, gaskets, or o-rings may have leaked with excessive expansion from local pockets of freezing in the block or heads.
    Any thoughts???
  8. Glassman
    Glassman F1 World Champ
    Living in Montana, freeze up is pretty regular. I have been told that any amount of coolant will not allow the system to freeze hard. Also I am told that you will loose the hoses and the radiator long before engine damage occurs. I have had many cars (not Ferrari) freeze pretty well without any noticable damage. I believe that if you have enough seepage to cause any kind of problem there wil be visible fluid mixed.
  9. Martin308GTB
    Jan 22, 2003
    4,252
    Martin N.
    Hello from Germany,
    long before coolant mixes with the oil you can find small, isolated coolant droplets on the interior part of the oil filler cap.
    This is my experience made with my Alfa. These engines are prone to head gasket failure between the oil lines and water jacket.
    Best Regards
    Martin
  10. fmaderi
    fmaderi Formula Junior
    May 8, 2005
    258
    clearwater Fla/NY
    frank maderi
    there are tests for oil .i agree withthe others dont pull the car apart . the block tester solution does get old . try a co/hc machine . and i have seen them leak before. funny thing is , like ive been taught , they dont blow head gaskets that often. forza frank
  11. ParadiseRoad
    ParadiseRoad Formula Junior
    Mar 26, 2006
    538
    Colorado
    ...mechanical hypochondria...if she has good power...doesn't use eccessive oil...and the fluids look good to the naked eye...run her!...and quit worrying.
