Hardwiring a radar detector on a 360 - help | FerrariChat
Discussion in '360/430' started by kenny1022, Mar 28, 2008.
  1. kenny1022
    kenny1022 Formula Junior
    Feb 10, 2008
    261
    Kenny
    Hello:
    I plan on hardwiring my Escort Passport 8500 radar detector in my Modena. It has a telephone-type cord which was previously wired to the fuse box on my Porsche. Does anyone know how difficult this will be to do on a 360? Any tips/recommendations where I should wire it to? If I choose to go to a mechanic, how much should I expect to pay?
    Thanks!
    ken
  2. ramvfin2003
    ramvfin2003 Formula Junior
    Feb 19, 2007
    330
    Bergen County, NJ
    Rocco
    Ken you have a PM
  3. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    #3 mrpcar, Mar 28, 2008
    Ken,
    Depends on your own personal comfort level about wokring on the cars. The radar detector just needs 1 positive, and 1 negative 12 volt feed to make it work.
    There is a very nice switched (by ignition key) power source that feeds the clock, just need to splice the two wires from the radar detector into the two wires in there.
    First you will need to pop the light off from the left side, a small flat screw driver will do.
    Underneath the light there are two torx type of screws you will need to remove in order to remove the entire clock/light module
    In the bundle of wire hook the positive from the radar detector to the yellow wire, and ground to the black wire.
  4. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    Having a radar detector visible through the windshield is the same as telling a policeman, "I'm guilty!" Is there a two piece detector with the sensor mounted behind the front grill and the display mounted in a more hidden location?
  5. fredf355
    fredf355 Karting
    Nov 1, 2005
    72
    Dallas Texas
    guilty -1
    instructions 1+ :)
  6. G Rides
    G Rides Karting
    Nov 5, 2007
    83
    SLO, CA
    Gary T King
    Have a look at these, the new 9500ci should be very nice:
    http://www.escortradar.com/custom-installed.htm
    Gary
  7. achilles99
    achilles99 Karting
    Sep 26, 2004
    239
    Atlanta
    LT
    Driving a bright red Ferrari gives me away :)
    I thought the same as you at first, but in the end I'd rather have the protection. Saved me just the other day. I got hit with a laser... fortunately, it must have been the laser bouncing off the car in front of me, because he was pulled over instead. At that point, I had already hit the brakes and went through the speed trap at a reasonable speed.
  8. arcticsilver997
    arcticsilver997 Karting
    Oct 27, 2007
    203
    Northern California
    Nice instructions, does this apply for the F430 as well?
  9. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    Fantastic instructions. How did you know that the yellow wire is + and the black is - ?
  10. G Rides
    G Rides Karting
    Nov 5, 2007
    83
    SLO, CA
    Gary T King
    Use one of these: http://www.powerprobe.com/
    If you plan to do any electrical work on your car this is a great tool for finding which wire is hot and when it's hot. Also finds ground and can do a few other things too. Or you can just buy a basic electrical probe to test wires. Basically you pierce the insulation of the wire with the probe to achieve continuity with the copper, just be careful not to slip off the wire and poke your finger cause that hurts, the tip of the probe is sharp.
    Gary
  11. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    Many thanks Gary. I was sticking a pin in the wire and then using my basic tester. Powerprobe looks like the business and I think I "need" one!
  12. G Rides
    G Rides Karting
    Nov 5, 2007
    83
    SLO, CA
    Gary T King
    Hey you're welcome, I have the Power Probe III and it's a great tool, you'll love it.
    Gary
  13. Whitby
    Whitby Rookie
    Jul 12, 2015
    5
    Florida
    This information helped a lot. My 2002 Modena was a little different.
    My light fitting was slightly different to the spyder but popped out easily - the place to pry open was easy to identify. I had 3 hex screws rather than 2 but same two wires worked and I am ready to go. Very pleased with how easy it was and how good it looks. Will take pictures later in daylight.
  14. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,430
    On the Limit
    Dino
    On a slightly different note..... are you guys finding an increase in false alarms from all the cars with lane change sensors, accident avoidance sensors, and all the other idiot sensors, etc?
  15. dwe8922
    dwe8922 Formula Junior
    Feb 27, 2004
    398
    FL
    David
    I'm seeing more false alarms. It was mentioned in an article somewhere that that could happen.
  16. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,430
    On the Limit
    Dino
    When mine goes off now (K band), I find myself looking at the arrows and trying to pick out which car it's coming from.
  17. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,721
    Just East of Weird
    Bob
  18. dwe8922
    Feb 27, 2004
    398
    FL
    David
    430 FYI....
    I read another how to thread that tapped into the fuse box behind the drivers seat because I'd read that there wasn't a swithcable power source from the overhead light on a 430. This didn't work for me because the window was replaced somewhere along the line and the glue was in the way of tucking my wire. I finally got around that, but the long phone cable I bought ended up being defective, so I was burnt out on the project at that point.
    The 430 doesn't have a clock in the overhead light like the 360, but the airbag light is does have a 12v switchable source. The dome light is not switchable. Beware if you have a scud, the microphone power source is switchable, but is only 3v! The snap on man sold me a fancy test light that has voltage. I drove away thinking I'd never need it, but glad I bought it!
    Thanks Robin for the write up and pictures.
    David
