GUNK engine clean... | FerrariChat
Discussion in 'Technical Q&A' started by bpu699, Oct 23, 2007.
  1. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,427
    wisconsin/chicago
    bo
    Well...cleaned my motor further. This stuff states it is "not corrosive, will not damage paint." When applied to the testarossa, it really did do a fantastic job cleaning the aluminum, with minimal work. I was so happy with the first can, I was going to get 2-3 more...
    Then, I looked at my driveway. I had just sealed the concrete for the winter to prevent spalling. Used Behr concrete sealer, which is latex/water based...
    Well...everywhere that the cleaner had dripped, and flowed down the entire lenght of driveway...it stripped the sealer... Drive way looks like crap now...
    The can did say not to use on asphalt, which I do not have...I am fairly pissed here...
    So, if you use this stuff, park the car in the middle of a public street, near a sewer. Then hose the car off...
    I reviewed some old threads, and apparantly Simple Green may be corrosive. Other products with "citrus juice" may eat away at your plating. WD40 just attracts dust...
    What should I was my motor with? Johnson and Johnson baby shampoo?!
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,761
    Cerritos, CA.
    I've been using gunk engine cleaner for 20 years and never failed to amaze me.
  3. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,418
    Alabama (was Mich.)
    Jeff
    I've used about everything out there. For a really dirty engine bay gunk is good. But once and engine is cleaned really good, it doesn't take a lot of harsh chemicals to keep it that way. I use WD-40 and am very happy with it....you do have to wipe until things are DRY though. But once clean and dry things look great.
  4. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    I do believe that Gunk is petro based & latex won't be able to stand up to it., nor will macadam. Mechanics hate servicing engines that had that stuff used on cause of the stench.
    By the way, what type of clear sealer are/will you be using after bead blasting your components?
  5. bpu699
    Dec 9, 2003
    17,427
    wisconsin/chicago
    bo
    I used Dupont 500 degree engine enamel...in clear. Autozone sells it. I know that Eastwood sells something similar, and perhaps better, but I used what was on hand and it seems to work fine. Seems somewhat flexible too.
  6. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
    +1
  7. MaleficVTwin
    MaleficVTwin F1 Rookie
    Jun 5, 2006
    4,312
    Reno NV
    Matt
    I've had Gunk trash a painted floor. The next time I used it I got one of those drip pans that you put under the car to catch oil leaks and such.
  8. BAD360
    BAD360 Formula Junior
    Sep 5, 2004
    383
    Albany/Colonie NY
    Brett
  9. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    A Big Thank-you for the info!
  10. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    I've used Gunk engine degreaser for years with great success on Mustangs, Corvettes etc(but not on my Ferrari yet-just simple green so far) but here's how I do it. Spray it on the greasy spots with the car in the street , then drive to the nearest "do it yourself" carwash and hose it off there, the grease and oil will have time to dissolve, by the time you get there. Then the hot carwash water will rinse it off. This is something I'd only do on a seriously greasy engine, Ferraris rarely get that bad.
    Gunk is great on unsealed driveway oil and grease spots too but keep it away from paint of any kind, including driveways.
  11. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    I have used petroleum-based Gunk--it smells a little, but it works great. Have also used the non-petroleum based Gunk and it works (not quite as good as the petrol based Gunk). The Costco driveway degreaser works good too, but I thought it might of "etched" the bare Alum a little. The alum was clean, but it went from being naturally shinny to having a faint glass beaded look? If a cleaner is a strong "basic" Ph it could etch the Alum a little; after all a strong caustic dip is what they use to chem-mill aircraft parts.
    Prior to doing my 60K on my 328 I used Petrol based and a 25 cent car wash. After cleaning the engine I drove it for about a n hour, but when I took the cams out, there was a very faint ring of "black Oxide type of corrosion on one of the cams where the seal rides. I presume the high pressure water from the car wash seeped in past the seal. After this experience I changed my engine cleaning tact.
    Currently, I put plastic down and use a Harbor Freight engine cleaning sprayer and Stoddard Solvent (Mineral Spirits). This works really well and won't corrode anything. If a tray is held under where the spraying is being done; hardly any solvent makes it to the plastic. What does get to the plastic can be wiped-up with rags.
    Mark
  12. yank05
    yank05 Formula Junior
    Nov 8, 2003
    272
    New England
    Anthony
    Believe it or not, unless extreme grime exists, I use very a mild dish detergent (such as Palmolive) and water on aluminum engine parts (cam covers etc..) for most cleaning and to keep things bright. Let it sit - massage with a soft brush (not a steel or brass brush!) and most dirt/grease will come right off.
    Anthony
  13. wingfeather
    wingfeather F1 Rookie
    Feb 1, 2007
    3,653
    rock bottom
    Some of you are spraying water on hot engines? I would think that might crack or deform the block...
    Or do you sit at the car wash for hours while the engine cools?
  14. yank05
    Nov 8, 2003
    272
    New England
    Anthony
    cool engine
  15. bwassam
    bwassam Formula Junior
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    Most of those do it yourself car washes use high pressure water that is heated. I've use those places for decades for engine and parts cleaning and have never had a problem except when I screwed up and sprayed something I didn't want to spray. I still think it's the best place to clean your engine, even though there's usually signs around that say "no engine cleaning" I have a power washer at home but I don't like the the mess to clean up afterwards. Also, where I live, the drain goes right into the bay. So I have to be extra cautious about where the mess goes.
    Bob Wassam
