GTC4Lusso Tire Spec 20" v 21" v 22" Advice | FerrariChat
Discussion in 'FF/Lusso' started by hamiltonseth, Dec 7, 2022.
  1. hamiltonseth
    hamiltonseth Rookie
    Dec 1, 2022
    4
    Hello everyone,
    First time Ferrari owner here coming over from Porsche and Lamborghini. I am picking up a v12 Lusso tomorrow and want to immediately swap out the wheels. I don't mind a slight sacrifice in ride quality but I also don't want it to be jarring. I see plenty of aftermarket wheels run 21" front 22" rear which seems a bit aggressive to me. Does anyone run 21" front and rear, or 20" front and 21" rear? I live in sunny southern California with pretty good roads, although there is the inevitable pothole here or there if you aren't paying attention. I am likely going with Novitec springs, and I do have axle lift. Full Kline inconel exhaust has already been ordered. Looking forward to some fun days taking the kids to school
    Thank you all for your help!
    Seth
  2. Jason Frye
    Jason Frye Rookie
    Oct 12, 2020
    34
    Parker, CO
    Jason Frye
  3. hamiltonseth
    hamiltonseth Rookie
    Dec 1, 2022
    4
    What tire specs are you running?
  4. Jason Frye
    Jason Frye Rookie
    Oct 12, 2020
    34
    Parker, CO
    Jason Frye
    255/30/21 || 335/25/22.
  5. hamiltonseth
    hamiltonseth Rookie
    Dec 1, 2022
    4
    thank you. Since I will be going satin black HRE 935 wheels I don’t think there will be a big aesthetic difference between 21 v 22” rears or 20 v 21” fronts. I’m most interested in running 21” all four or 20” front and 21” rear to save some space for comfort. Anyone running such a setup?
  6. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,172
    Denmark
    Max
    Im on stock wheels so cant comment on the tire sizes, but keep in mind it is important to keep the overall wheel diameter the same, so as not to create issues with the 4RM. At least the ratio of change needs to be the same if there is one (and that would give you erroneous speed readings but I guess it's acceptable to most)
  7. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,328
    The Netherlands
  8. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,328
    The Netherlands
  9. Elferink
    Elferink Karting
    May 16, 2018
    66
    the Netherlands
    Mark Elferink
    Dear Reg, your reference to the thread regarding your search for suitable wheels and tires was reason for me to read this entire thread (I had not done so yet, because I was only active on this forum later).
    What a great explanation .
    Apart from the fact that I still like my standard wheels very much, your thread has a lot of extra information for possible future adjustments!
    Regards, Mark
    ANOpax and hamiltonseth like this.
  10. hamiltonseth
    hamiltonseth Rookie
    Dec 1, 2022
    4
    I can’t agree more. I just read through it and this is exactly the info I have been looking for. Thanks so much for your help!
    ANOpax likes this.
  11. Bond55
    Bond55 Rookie
    Jan 8, 2023
    4
    New York
    M Perez
    Same; wanting to know if there is someone doing 21” in all 4 corners. I’ve seen a few with 20” winter set ups. Meaty, but the car dwarfs them.
