430 - GruppeM Carbon Fiber Ram Air Intake System | FerrariChat
430 GruppeM Carbon Fiber Ram Air Intake System
Discussion in '360/430' started by Kent Adams, Oct 21, 2020.
Tags:
  1. Kent Adams
    Kent Adams Formula 3
    1,930
  2. Bill ochrane
    Bill ochrane Karting
    Oct 26, 2018
    202
    Galveston, Texas
    William Cochrane
    Something is strange about this.
    Here's how the ad describes it:
    "The GruppeM Ferrari F430 carbon fiber ram air intake system was designed with K&N to dramatically improve airflow across the entire rpm range while also reducing induction temperatures. Every intake system comes with a proprietary filter element made exclusively for GruppeM by K&N. The result is a tremendous improvement in horsepower and torque throughout the entire powerband of the engine by utilizing the "ram air effect" which forces a greater volume of air into the engine and increases the density of the intake charge. Each intake application is custom engineered for your vehicle using the highest quality carbon fiber weave and is designed to fit perfectly with minimal installation difficulty. The result is a carbon fiber ram air intake system that looks as good as it performs."
    This leaves much to the unknown.
    "proprietary filter element " - means that you must purchase filter elements from them. Probably has an outrageous COST.
    "The result is a tremendous improvement in horsepower and torque throughout the entire powerband of the engine" - Okay where is the Dyno sheet showing the Before and AFTER?
  3. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,419
    Toronto / SoCal
    Rob C.
    Spider and coupe have identical intake systems with the exception of the colour of the OEM airboxes. There is no reason it should not fit
  4. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,650
    England
    Mark
    I'd say no: the 16M has a modified engine bay lid to clear the Scuderia airboxes, and they sit what looks to be 1" lower than the GruppeM.
  5. Kent Adams
    1,930
    The engine cover angle is different and if you look at the GruppeM intake boxes, they sit higher than stock.
  6. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,419
    Toronto / SoCal
    Rob C.
    I suspect you may be correct.
  7. ttforcefed
    ttforcefed F1 World Champ
    18,876
    those boxes have always looked funky to me - do the HP gains justify the price?
    Eric C likes this.
  8. one4torque
    one4torque F1 Veteran
    5,123
    Houston
    One4torque
    I’ll be selling my near new 360 gruppe. M intake.
  9. ttforcefed
    18,876
    did you feel a difference in the seat of the pants dyno?
  10. imahorse
    imahorse F1 Rookie
    2,774
    WI
    Dustin
    I think these look really cool, but I can't help but question their gains.
  11. Scottslaw
    Scottslaw Formula Junior
    My very strong suspicion (just gut feeling here) is that there are in fact gains, but they come from the included heat shield rather than improved airflow characteristics. Imho.
  12. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,650
    England
    Mark
    Carbon airboxes normally sound better but, yes, there's little in the way of optimisation to be had upstream of the MAFs.
  13. 02360spider
    02360spider Formula 3
    1,730
    Dartmouth
    Richard oliveira
  14. one4torque
    5,123
    Houston
    One4torque
    Buy mine and find out for yourself :)!!!
    honestly not much difference but it looks sweet!
  15. mathewr
    mathewr F1 Rookie
    Sponsor Rossa Subscribed
    Dec 7, 2011
    2,803
    Deep in the Heart of Texas
    Ferrari Wheel Guru
    I would be interested in one for a 430 if anyone has a brand new one for sale.
  16. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,646
    Silicon Valley
  17. ShineKen
    ShineKen F1 World Champ
    16,673
    Southern California
    Nostradamus
    #17 ShineKen, Oct 22, 2020
    The best version as far as performance goes is actually the Novitec version, which might be discontinued. The main reason is because it has a velocity tube right behind filters to speed up air flow, particularly at higher RPMs.
    https://dirtyoldcars.com/novitec/
    If I recall correctly, someone did a back to back dyno on a 2.7 F355 with stock intake vs GruppeM and found 10-20 hp bump in low to mid range but lost about 10-15 hp on the high range. He decided to put a velocity tube behind the filter and found gains top to bottom.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  18. ShineKen
    16,673
    Southern California
    Nostradamus
