Granturismo trunk release not working | FerrariChat
Discussion in 'Maserati' started by deangpsx8, Mar 31, 2018.
  1. deangpsx8
    deangpsx8 Formula Junior
    May 2, 2008
    477
    Melbourne-Australia
    Dean C
    Hi Guys, today I decided to put the battery on the GT on charge as it hadn't been driven for a while.
    I tried opening the trunk from the trunk lid and also from the dash button and nothing happened.
    I tried starting the car, it barely cranked.
    I used the pull loop under the rear seat to open the trunk. I charged the battery.
    Problem..trunk release not working.
    I checked fuse F38 and all OK.
    I dismantled the lock assembly and the actuator checks fine.
    It seems like there is no power getting to the actuator.
    Any ideas?
    Anyone have a wiring diagram?
    Is the actuator controlled by an electronic module or is it directly controlled from the switch?
    Thanks in advance.
    Dean from the land down under
  2. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,026
    Dean: Your problem is better addressed at the "Maserati Life" forum. They have a very active group with the newer cars.
  3. deangpsx8
    May 2, 2008
    477
    Melbourne-Australia
    Dean C
    Thanks. Got it working. It seems like after the battery runs flat, you need to use the remote control to lock and unlock the doors, after which the trunk release mysteriously starts working again.
    I discovered all of this after pulling the thing apart to test the actuator, and testing all fuses and relays.
    Maserati Life - A little like my Italian trophy wife, who is the driver of this car.
  4. italiancars
    italiancars F1 Rookie
    Apr 18, 2004
    3,431
    Hershey, PA
    FYI there is an emergency cable pull driver’s side rear between the bottom seat cushion and the side trim
  5. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yeah. After having the battery disconnected, I cycle the door locks via the FOB a few times then stuff like this works. The same happens with the window drop and auto door open with the touch of the door open buttons.
  6. Hightower
    Hightower Karting
    Sep 27, 2016
    149
    Utah
    Jay
    I had the same thing happen. If you follow the owner's manual or get advice on ************, they all recommend charging the battery remotely (not hooked up to car), then reinstalling battery, then putting key in ignition and barely turning it--just so the lights and sensors come on--not engine cranking. Let key sit in this position (with lights and sensors on) for a minute or so. The electronic system seems to need that time to get rebooted.
    After that, I started the car and all was good. I try to drive the car every 7-10 days, seeing as it's in a parking garage (dirt roads at my house...). Takes commitment to keep driving it, but that's what they're made for! Good luck.
    deangpsx8 likes this.
