Got a weird one | Page 2 | FerrariChat
Got a weird one
Discussion in '348/355' started by cactussed, Mar 29, 2021.
  1. Qavion
    Qavion F1 World Champ
    11,484
    Ian Riddell
  2. cactussed
    cactussed Karting
    Mar 12, 2008
    232
    Qavion
    You don't have that diagram labelled for the whole connector by any chance? It'd be hugely helpful!
  3. Qavion
    11,484
    Ian Riddell
    #28 Qavion, Apr 26, 2021
    Not labelled, but you can follow the coloured lines...
    https://www.dropbox.com/t/LBZ5tAaVDal2lKpv
    (Assuming you're from the USA and have a non-F1 car).
    For the injectors, the green/black wires are power. The other colours are signals from the ECU to fire the injectors. By the way, the mini graphic in my previous post is the connector, not the ECU (as viewed from the pin side).
    Link expires in 6 days
  4. cactussed
    cactussed Karting
    Mar 12, 2008
    232
    I'm actually UK based, so European car, but non-F1.
    Thanks for the link, that's hugely helpful. Just need to figure out how to read it now!
  5. Qavion
    11,484
    Ian Riddell
    #30 Qavion, Apr 27, 2021
    If you're just checking the wiring between the injectors and the ECU, then that diagram is all you need. The pin numbers are actually marked on the side of the ECU plug (They're hard to see, so that's why I provided the graphic)
    If you're chasing power for the injectors (in general) you'll also need this diagram:
    https://www.dropbox.com/t/f2nr8CE6nO9DMQFa
    Injector power is on the green wire (black stripe)*. All the green/black wires on the injectors are spliced together at splice "30013" (first diagram). Power is fed to that splice from plug 41090 (near the ECU). Power goes to that plug from "M" in the footwell. For info, relay M also powers the exhaust bypass valve and the fuel pump relay solenoid, so it's unlikely to be a power problem, more an ECU control or other problem.
    * colour code VN
    If you hit the preview button on the link provided, and then hit "print" once or twice, the file is converted to a pdf file. Some prefer this type of file. However, the "purest" image is created if you preview the dropbox link at 100% magnification.
  6. cactussed
    cactussed Karting
    Mar 12, 2008
    232
    Its about this time I start googling auto electricians....
    Going to start testing pinouts / continuity to all the engine plugs
  7. cactussed
    cactussed Karting
    Mar 12, 2008
    232
    Oh, and a big thank you for the help thus far.
    Qavion likes this.
