Good fuel injector cleaner? | FerrariChat
Discussion in '360/430' started by collegeboy, Jun 5, 2023.
  1. collegeboy
    collegeboy Formula 3
    1,305
    Texas and Kaua’i
    Mikey
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,659
    Central NJ
    Dominick
    #2 flash32, Jun 5, 2023
    BG44 or Chevron you mentioned ..BG is more for once in a while to address maybe some dirt whereas Chevron more of maintenance
    I feel if you use top tier gas like Shell etc and use the car often .. no need for any additives
  3. rizzo308
    rizzo308 F1 Rookie
    2,748
    Perth, Australia
    riggio
    Don't think it would hurt to wak a bottle in tank every couple of months.
    collegeboy likes this.
  4. collegeboy
    1,305
    Texas and Kaua’i
    Mikey
    I figured. I always use good gas too, and drive every day almost, but I guess it’s just practice I’ve been doing for 21 years of driving. Plus it sat so much before I got it. Thanks again. I just put a bottle of the Chevron Techron in the tank and filled her up.
  5. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,097
    Calif
    Brett
    I use the redline injector cleaner. Every oil change for all my cars and 2x a year for the 360.
  6. Edward 96GTS
    Edward 96GTS F1 World Champ
    10,819
    swepco 503 fuel additive
  7. 67bmer
    67bmer F1 Rookie
    2,668
    MD
    I have just recently had to replace the coolant pipes on my Cayenne (2006, 114k miles) and am in the process of replacing a rear seal on my Spyder(1989, 50k miles). In both cases, the valves look immaculate! I typically buy Costco (a Top Tier fuel) premium. These valve "cleaner" additives seem like a complete waste of money after what I have seen. Modern fuel-injected engines are so clean.
    Almost impossible to get a good picture of them, but you can see where the spray hits the ports and all is clean (Cayenne).
    CoreyNJ, collegeboy and GogglesPisano like this.
  8. CoreyNJ
    CoreyNJ Formula 3
    2,356
    New Jersey Shore
    FYI: There was a class action suite on those pipes, they were plastic and the replacements are metal. You may be able to get some money back, not sure how the whole thing works as I replaced my wife's Cayenne before the class action was settled and my repair was done under warranty.
    tfos750 and peterp like this.
  9. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,097
    Calif
    Brett
    Using fuel injector cleaner is like religion....you gotta have faith! Whats $10-$15 bucks....
  10. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,065
    Josh @jtcarprojects
    I rather run some race gas a gal here or there makes me feel better then a bottle of snake oil that you put in a gas tank
  11. collegeboy
    1,305
    Texas and Kaua’i
    Mikey
    Race gas cleans?
    peterp likes this.
  12. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,631
    NJ
    Peter
    #12 peterp, Jun 6, 2023
    For clarity, while there are certainly "snake oil" oil additives, there aren't really "snake oil" fuel cleaners (unless they are making some crazy claim, like it will fix a failed engine, which I've never seen in a fuel additive claim). Probably all of the quality fuel cleaners can clean the fuel system. The only question is whether a given fuel system needs it given that quality ("Top Tier" rated) fuels already contain fuel system cleaning additives. Of course, adding a quality cleaner to gas will have a much higher concentration than the additives in the Top Tier Fuel alone, so they certainly can clean better than Top Tier fuel alone.
    My experience is that I've always run top tier premium fuel in all of my cars, and I've still found that fuel cleaners like Techron or SeaFoam (added to gas, not sucking it into the engine) do help the car run better. Costco has Techron 6-packs reasonably priced, so I give out bottles to others in the family to run once a year or so and I've always heard positive comments back. Quality fuel cleaners are not "snake oil", the only question is whether your car actually need additional cleaning. Used once a year (the tankful before an oil change is a good time to use them), I think most will find some benefit, with virtually zero risk of harm when used as directed.
    It's a different story regarding oil additives, where they can be "snake oil" either intentionally (e.g. Slick 50) or unintentionally (where the additive has ingredients that can be beneficial in the abstract, but that might screw up the balance of the additives in the oil you happen to be using). Oil additives stay in the oil until the next oil change, so if a particular oil additive makes the oil you happen to use less effective, there can be some degree of increased wear over the 3k/5k/10k miles between oil changes.
  13. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,065
    Josh @jtcarprojects
    I feel a full tank of 100 unleaded will maximize more then a bottle of cleaner
  14. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,631
    NJ
    Peter
    Octane has nothing to do with cleaning the fuel system. Higher octane only means that the fuel is more difficult to ignite than a low octane fuel. Whether a given 100 octane fuel cleans better or worse than normal Top Tier gas will depend on what additives are in that individual fuel. Race fuels/oils often don’t include the additives that are needed for long-term/daily use, but whether a given 100 octane fuel cleans will depend on how that specific fuel was formulated.
  15. Edward 96GTS
    10,819
    how is 20 gals at $20 per gal?
  16. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,065
    Josh @jtcarprojects
    Yes I understand that 100%
  17. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,065
    Josh @jtcarprojects
    Not 20 here
  18. Snapshift
    Snapshift Formula Junior
    897
    Centralia IL
    Lyle D. Pahnke
  19. collegeboy
    1,305
    Texas and Kaua’i
    Mikey
    Thanks for all the information everyone. I will use the Techron bottle every 6 months just cause it can’t hurt and does clean injectors at a minimum. Would love to get some race gas too! Haha. Thanks again.
    flash32 and peterp like this.
  20. Ivan Drago
    Ivan Drago Formula 3
    Jul 14, 2021
    1,192
    Midwest
    Ivan Drago
    What’s the benefit or disadvantage of getting the Techron “complete fuel system cleaner” over the “fuel injector cleaner”? The complete fuel system cleaner is a few bucks more but is it as good for fuel injectors?
  21. Rifledriver
    36,744
    I had a 360 engine in the shop that lost a rod bearing at 120,000 miles. It was a daily driver and always used top tier gas. I used its injectors for diagnostic purposes. He had never used fuel additives. We tested them and after 120,000 daily miles they worked perfectly.
    Use good gas. Dont let the car sit.
    Real race gas and race oil has no detergents.
    Need4Spd, KC360 FL and Edward 96GTS like this.
  22. Ivan Drago
    Jul 14, 2021
    1,192
    Midwest
    Ivan Drago
    I agree with you. However, I am not the first owner and I don’t know what kind of gas the previous owner used. I don’t let my cars sit either, partly because the rain and snow don’t bother me and neither do miles. I get it detailed professionally after and no salt sits.
    In any case, I want to run a cleaner through to just get anything off that may be built up
  23. jerbear27
    jerbear27 Formula Junior
    289
    CT
    Jeremy
  24. kestrou
    kestrou Formula 3
    1,410
    Danville, IL
    Kevin E. Stroud
  25. enzoferrari
    enzoferrari Rookie
    Jun 7, 2006
    49
    anyone know what they use at the Ferrari dealership? I was looking through an old service record and along with my annual service there was a line item for: Fuel Injector Flush Kit: $190.01 and Fuel System Treatment: $38.33
