Gearbox sump plug debris | FerrariChat
Discussion in 'Mondial' started by belfry, Mar 15, 2019.
  1. belfry
    belfry Formula Junior
    May 14, 2015
    496
    Robert Batt
    My wife noticed a slight grumble/ whine from the gearbox on my Mondial t. I changed the fluid this morning and there wasn’t much on the sump plug except the normal small flakes. I test drove the car just now and there was a distinct whine (sounded a little like an old-fashioned supercharger), so I drained the new redline fluid and found all this debris on my sump plug.
    Is there a chance that I might have saved it in time??
  2. alexion
    alexion Formula 3
    May 20, 2013
    1,379
    New York
    I hope so! Do not drive it any further. What year and mileage is your T?
    There are some similar threads on this topic in the 348 section if memory serves me correctly.
  3. alexion
    alexion Formula 3
    May 20, 2013
    1,379
    New York
    One notable person that I recall experienced a problem with their 348 gearbox is Daniel of Ricambi. He might be the right person to ask/discuss with and point you in the right direction for parts.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,001
    Isle of man- uk
    It needs to come out before you do more damage, the big bits sounds alarm bells with me
    Rifledriver likes this.
  5. belfry
    May 14, 2015
    496
    Robert Batt
    The car is 66,000 miles.
    There is a 348 gearbox thread that talks about "finger nail clippings" size fragments, which perfectly describes the fragments on my sump plug magnet. I think they pointed to the oil pump bearing.
    I have strained the oil that I drained from the gearbox and there are no more fragments in there.
  6. srephwed
    srephwed F1 Veteran
    7,127
    street,md
    fred brown
    The long slivers look like gear teeth. Push, pull or drag it for repairs. do not drive anymore. When you have two gears and something tries to go between them it is like trying to compress a liquid. Something has to give.
    thorn likes this.
  7. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Needs an internal visual inspection, asap. Don't drive it.
  8. JLF
    JLF Formula 3
    Sep 8, 2009
    1,709
    Please let us know what happened and possible cause.
  9. JimboMondial
    JimboMondial Karting
    Dec 26, 2005
    73
    Portsmouth UK
    Jim
    Looks like a bits from a pin bearing.
    Jim
    Sent from my Lenovo YT3-X50F using Tapatalk
  10. jknight
    jknight F1 Veteran
    Oct 30, 2004
    7,821
    Central Texas
    #10 jknight, Mar 17, 2019
    This sounds identical to the situation I had with my T coupe several years ago. The transmission was steadily "eating" itself.due to what turned out to be an old unresolved manufacturing defect. The end result was a transmission rebuild. Expensive but necessary and it completely resolved the problem. Do not drive it and have a competent mechanic take a good look at it. Good luck.
  11. JLF
    JLF Formula 3
    Sep 8, 2009
    1,709
    How much did it cost Jknight and who did it?
  12. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    It needs a rebuilt, like I had to do for my 100,000km Mondial T too. The internal bearings are worn, give a whining sound and have to be replaced. Prepare for a big budget job, especially finding the bearings is very difficult and will be expensive.
  13. jknight
    jknight F1 Veteran
    Oct 30, 2004
    7,821
    Central Texas
  14. JLF
    JLF Formula 3
    Sep 8, 2009
    1,709
    Thanks J. I have dealt a little with Norwood a little and got a good vibe from them.
  15. jknight
    jknight F1 Veteran
    Oct 30, 2004
    7,821
    Central Texas
    Best of luck.
  16. JLF
    JLF Formula 3
    Sep 8, 2009
    1,709
    I don’t need any work done. I’m just getting a feel for a “what if” situation.
  17. 350HPMondial
    350HPMondial F1 Veteran
    5,336
    Edwardo
    Long pieces, if made of Aluminum,,, are Aluminum threads.
    The other contaminants are iron filings. From.......?
    Could be normal wear ......?
    Good luck.
    Eduardo
  18. alexion
    alexion Formula 3
    May 20, 2013
    1,379
    New York
    Any updates on this?
  19. belfry
    May 14, 2015
    496
    Robert Batt
    The back of the gearbox was taken off today and the input shaft ring nut had become loose and is causing the whine. It will be a day or two until we know if this has caused any damage internally. We will also inspect the clutch for wear.
  20. JLF
    JLF Formula 3
    Sep 8, 2009
    1,709
    Hopefully they can tighten it back up and it will be good.
  21. belfry
    May 14, 2015
    496
    Robert Batt
    When we opened the gearbox we found that the play in the shaft was not coming from a loose ringnut, but instead a clip has come off the shaft. There is no sign of internal damage to the gearbox. I guess this accounts for the debris on the magnetic sump plug.
  22. Rifledriver
    37,288
    I fail to see how the missing circlip caused a symptom in any way like a loose ringnut. That shaft is splined at each end and excessive end float, while bad, shouldn't cause your symptoms. Additionally your debris looks nothing like the remains of a circlip.
    It is apart, I fear you have not yet found all of the problems. Keep looking.
    alexion likes this.
  23. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    I fear the same as Rifledriver. The last time I saw such debris in a T transmission the pinion gear was chipped. If the debris is metal you will need to make sure it has not mixed up in all your bearings. In the pinion gear story it was a complete transmission overhaul of bearings.
  24. belfry
    May 14, 2015
    496
    Robert Batt
    This photo just in... I was told that the bearing had 'collapsed' and that we should replace all on the bearings. The gears have been carefully checked and are all fine. I'm not sure how lucky/unlucky I've been?
  25. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    An engine/transmission have only one mission and that is to selfdestruct. I would say you are Lucky :) All the brass that is in there could have been very well damaged too.
    Like I mentioned, replacing all the bearings is unfortunately a must in these cases. But all will be good I see and when it is put together it will sound/drive like new. the transmission that is. :cool:
