Gearbox DSG Maintenance | FerrariChat
Discussion in '458 Italia/488/F8' started by Robb, Aug 14, 2017.
  1. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,196
    Robb
    What is the typical lifespan of the Dsg and gearbox in miles (estimated)? I have heard some disheartening numbers from our mechanic on some he has had to replace in a cali and 458. Wanting to know more about typical expectations of dsg vs a typical manual or F1 clutch.
    How is it serviced and what parts are replaceable?
    What costs are involved in this process? Is it similar to Porsche PDk and Audi S-tronic in wear / costs?
    Thanks for the help.
    Robb
  2. TheMayor
    104,767
    Vegas baby
    #2 TheMayor, Aug 14, 2017
    So, what is supposed to happen is this.
    The gearbox and wet clutches are supposed to last "the lifetime" of the car (whatever that means). The clutch does not have any friction aside from fluid, which is sealed and as far as I know, never supposed to be changed. The 458 has actual coolers to let the fluid dissipate the heat.
    What has happened in the past is there have been some problems with "cable" or other electronic issues inside the early boxes that made the unreliable. My understanding is these were 2009-10 Cals and 458's. Some of them were replaced under warranty already with upgraded internal parts.
    Dealers are not supposed to fix them. They replace them with a rebuilt unit from the factory. I understand it's about 12-15 grand for this if needed. Now, 12K might seem like a lot but hell, a lot of major repairs on a 458 can reach that amount pretty easily.
    The good news is if the gearbox lasts you never need a clutch replacement.
    The Dual Clutch gearbox is just like any other gearbox but it has -- two clutches (duh). This way one clutch handles 1, 3, 5, and 7 while the other handles 2, 4, 6, and R. The idea is that it actually is much faster and less wear and tear on the moving parts as the gears either up or down of the one you are in are already moving and ready to engage at anytime.
    To try to answer your question -- it's probably better lasting with lower maintenance costs than a robotized F1 or manual. On the downside, it's more "digital" and less "analogue" than the others.
    Personally, I would have no problems in getting the DCT. It's not going to cost you more in the long run and by in large, are pretty reliable. You really don't see many threads here anymore "My gearbox broke" but you would if you go back to 2011.
    F485, AlfistaPortoghese and docf like this.
  3. Robb
    Robb Moderator
    Feb 28, 2004
    14,196
    Robb
    Great info. Thank you for taking me through the process and expectations.
    Robb
  4. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,299
    Bournemouth, UK
    Using german nomenclature when speaking about a Ferrari is insulting! :p
  5. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,243
    Mel
    Hi Robb, I think the DCT is not serviced, other than CPU read-outs and oil change.
    If they fail, they are snt to the factory which have a special department to handle all gb problems.
    You get your own gb back, mended and (maybe) upgraded. Sometimes only mended/repaired. F.I. not all (Cali and) 458 gbs are exactly the same ... there seem to be differences in the internals.
    One more Q we should think of here: Who will repait the gb's after the guarantee period.
    The factory (at immense costs) or gb shops who now also/already repair the (allmost the same) dct's of Mercedes etc ... ?
    Are we aware of any of these repair shops ? Did we talk about that with them ... the answer will be "NO" imo.
    We dont want to think about it imo (yet) :D ..... -> It's not going to happen to me (we hope) :)
  6. 100badboy100
    100badboy100 Formula Junior
    Sep 15, 2016
    825
    Devon- U.K.
    Michael
    There are places here in the UK that will repair these gearboxes
    Regards
    Michael
    Sent from my SM-G935F using Tapatalk
    Baitschev and Pocty like this.
  7. Motob
    Motob Formula 3
    Nov 11, 2003
    2,338
    Frederick, Maryland
    Brian Brown
    Umm, the DTC gearboxes used in Ferrari's are made in Germany by Getrag.
    carnutdallas likes this.
  8. tekaefixe
    tekaefixe Formula 3
    May 10, 2012
    1,201
    CH
    Paulo
    Genau ;)
  9. F60SA
    F60SA Karting
    Nov 15, 2014
    82
    Fluid flushes on the hydraulic side of the gearbox aren't a bad idea along with the "valve cleaning" with the DEIS ... If you have hard hitting shifts that aren't smooth try this first
  10. Pocty
    Pocty Rookie
    Mar 5, 2017
    46
    London
    Philip Octave
    Great...Please tell more.
    Pocty
  11. AlfistaPortoghese
    AlfistaPortoghese Moderator
    Mar 18, 2014
    3,778
    Europe, but not by much.
    Nuno
    True, but I'm not sure dealers do that. Has anyone asked for a gearbox fluid change on his 458 at the official dealer?
    Kind regards,
    Nuno.
  12. 100badboy100
    Sep 15, 2016
    825
    Devon- U.K.
    Michael
    Try signature transmissions they may be able to help depending on how knackered your box is!!
    Sent from my SM-G935F using FerrariChat.com mobile app
  13. Solid State
    Solid State F1 World Champ
    10,427
    Maximus Decimus Meridius
    Hi Numo. I have a wonderful F12 that I desired to keep from purchase. Yes I have changed the fluid in the DCT at the dealership. Did this at the last annual along with every other fluid in the car from the coolant to the steering fluid, brakes, engine, etc, including all filters. There is no such thing as permanent fluid or lifetime fluid in a car you intend to keep. All fluids age, lose their properties and get contaminated. All fluids.
    You will notice the difference in a DCT fluid change and it's done by the dealer using their diagnostic tools and it's a pretty reasonable price. We spend so much time, effort and money keeping the paint and leather new yet the systems you demand be reliable and functional are assumed to never need a second thought. Think about it.
  14. Caeruleus11
    Caeruleus11 F1 World Champ
    11,413
    Excellent point and Ive done the same thing.
    AlfistaPortoghese likes this.
  15. eric355
    eric355 Formula 3
    1,210
    Toulouse (France)
    Eric DECOUX
    I did, at my last annual visit, one month ago.
    Dealer said that gearbox fluids change is not part of routine maintenance but they do it upon customer request.
    I decided to go for it and they changed both the gearbox and the clutch/hydraulic oils.
    flash32 and AlfistaPortoghese like this.
  16. AlfistaPortoghese
    Mar 18, 2014
    3,778
    Nuno
    Absolutely right. I go by the same philosophy.
    Excellent post and advice. I will certainly ask for a fluid change at my next annual service in April.
    I'd also like to take the opportunity to wish you all the happiness in the world and that you keep enjoying your F12 in good health!
    Thanks for the first hand feedback, Eric. Once the procedure isn't part of the scheduled and routine maintenance program, I thought maybe the official dealer wasn't equipped to do a gearbox oil change. Perhaps not because the procedure is difficult (not being an engineer nor a mechanic, I don't know exactly how hard/easy it is), but because the gearbox is made by Getrag and not Ferrari. Nevertheless, it's great news for the zealous owner in with his Ferrari for the long run.
    Kind regards,
    Nuno.
    Solid State likes this.
  17. Greygt3
    Greygt3 Karting
    May 12, 2013
    56
    Houston Tx.
    My 458 went in for the annual service and the dealer changed the gearbox fluid, told me it was due.
  18. 338Lapua
    338Lapua Formula Junior
    Sep 5, 2015
    829
    Michigan
    Tony
    How many miles were on your car at the time?
  19. Barry P.
    Barry P. Karting
    Nov 22, 2016
    94
    Milton Keynes
    Barry
    Interesting discussion on the gearbox fluid changes, I also own an R35 GTR, the DCT box in that car, also made by Getrag, has the fluid change service interval at every 18 months or 18,000 miles. Some tuners recommend more frequent changes as the small metal particles found in the contaminated oil stick to the solenoids in the box. Several owners fit larger magnets to collect these particles and regularly remove the gearbox sump to clean out the filter tray and any particles sticking to the megnetised solenoids.
  20. F60SA
    F60SA Karting
    Nov 15, 2014
    82
    No because as per maintenance its a sealed unit. But if a transmission concern comes in usually they take a sample and change it.
  21. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,794
    Dallas Texas
    If you know you know
    Um, we do DCT gearbox services every week, multiple times a week.
    Its not uncommon, though not part of the GMS program, for it to be completed.
    S
  22. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,794
    Dallas Texas
    #22 SAFE4NOW, Dec 13, 2017
    Mostly accurate, but not completely.
    A " Rebuilt " DCT gearbox from Ferrari will run over $28,500 +/-
    SSP/CCP internal componants will run sub $15,000 installed if/when needed ( rare anymore )
    And most if not all Dealerships ( should ) have at least one technician that has been trained to completely rebuild all current DCT gearboxs... which is way simple compared to sending it back to Italy.... ask me how I know ... LOL
    S
  23. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,794
    Dallas Texas
    To answer you initial question... we have several early California's and Italia's with over 60,000 miles ... with no gearbox concerns at all, and at least one Italia with over 100k miles...
    There have been some internal failures of speed sensors and or SSP/CCP units going south... the repairs being covered under the New Power Warranty available these days.
    A few clients have self-insured and have paid $9,500 +/- parts and labor.
    I can tell you that I have not personally seen a worn out clutch kit on a DCT
    s
  24. TheMayor
    104,767
    Vegas baby
    That's really interesting. In the beginning the dealers were told not to crack them open but times I'm sure have changed. Thank's for the clarification. Let's hope on the 488's replacement they have dealt with the boxes reliability and replacement costs.
    SAFE4NOW likes this.
  25. SVCalifornia
    SVCalifornia F1 Rookie
    2,549
    Silicon Valley
    Keith
    Just had the thermal sensors get replaced on the clutch in a 2013 FF. Had to take out the whole box. Last of my extended warranty so it cost me nothing.
    Did get the new power warranty tho...
    SV
