Gear Oil Type
Discussion in '456/550/575' started by scowman, Mar 21, 2018.
  1. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    This may be a stupid question but I seem to be reading conflicting threads on the proper manual gear oil. The 456 is a limited slip differential correct? Then shouldn't the gear oil be limited slip too? Probably too stoopid for words but hey, it's a Ferrari and nothing ever seems normal.
  2. asgor
    asgor Formula Junior
    Sep 8, 2016
    713
    Virginia, USA
    Mobil 1 75W-90 LS (LS = limited slip)
  3. tazandjan
    39,021
    Most transaxle oils have a limited slip additive. Some GL-5 oils, however, can harm brass synchro rings. Check the specs on the oil.
    Incidentally, this is from the Mobil 1data sheet for the 75W-90 LS:
    Not recommended for automatic, manual or semiautomatic transmissions...
    So it is not recommended for our transaxles, just for hypoid gears.
  4. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    So... We need one oil for transmission and different one for hypoid gears but we can only use one oil? Got it. So we make a compromise and use GL-5 with LS additive and call it a day?
  5. Themaven
    Themaven F1 Rookie
    Nov 2, 2014
    4,359
    Eastdown
    Darius
    This is a dumb question but - do all our cars have LS diffs as standard? I’m sometimes amazed about cars that don’t (911s for example).
  6. asgor
    Sep 8, 2016
    713
    Virginia, USA
    Well... to be precise the Mobil 1 75W-90 LS Data Sheet says: "[...] Not recommended for automatic, manual or semiautomatic transmissions for which engine oil or automatic transmission fluids are recommended"
  7. tazandjan
    39,021
    Stu- Yup, a quandary. There are transaxle oils out there that are GL5, but do not eat brass. Shell makes one. Nulon makes on too. The others, including the Valvoline I use, have warning not to use in manual transmissions. Slowly eats your synchro rings.
    Darius- Affirmative, all our V12s have limited slip differentials.
  8. tazandjan
    39,021
    Asgor- Yup, but it still eats synchro rings.
  9. asgor
    Sep 8, 2016
    713
    Virginia, USA
    I admit I have lots to learn in this field (and many others) but... may I ask how/ why?
    The Mobil 1 75W-90 LS Data Sheet specifically states: "Features: Excellent rust, staining and corrosion protection of copper and its alloys" - "Advantages and potential benefits: Helps to reduce wear; long component life".
    Brass is a copper alloy, so what am I missing?
  10. Canuck550
    Canuck550 Formula Junior
    Sep 8, 2015
    462
    Incognito
    RJA
    #10 Canuck550, Mar 22, 2018
    I would just go to my Ferrari dealer and get what they use.... Image Unavailable, Please Login
    That is what I did
    You will need the additive as well, which happens to be a GM additive...Yes you read that right! GM
    I bought them both from Ferrari of Ontario...
  11. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    The limited slip additive? How much did you add?
  12. tazandjan
    39,021
    Asgor- May work, then, but I would want one that says it is ok for transaxles.
  13. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    Can’t win can we?
  14. tazandjan
    39,021
    Stu- Yup, the specs on the Shell oil above state it is designed for transaxles. Before they renamed it as one of the Shell Spirax family, the same oil was called Shell Transaxle Oil.
  15. Canuck550
    Sep 8, 2015
    462
    Incognito
    RJA
    They sold me a Delco bottle and told me to put it all in!
    Considering the fluids came from Ferrari, I am pretty sure they know what they are doing, and is followed up by this note from the Pennzoil web site:
    SAE 75W-90, API GL-5 is the primary service fill rear axle oil for many passenger cars and trucks. SUVs and Trucks in particular may be equipped with limited slip differentials. Pennzoil Platinum® Axle 75W-90 contains sufficient limited slip friction modifier for many applications. Newer applications however may require an additional limited slip friction modifier. Pennzoil Platinum® Axle 75W-90 is fully compatible with additional friction modifiers.
  16. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    How big was the bottle?
  17. Canuck550
    Sep 8, 2015
    462
    Incognito
    RJA
    it was a small bottle, estimated a cup worth.
    Call your ferrari dealer ask them what they use!
  18. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
  19. Canuck550
    Sep 8, 2015
    462
    Incognito
    RJA
    Anytime!
