Gear lever bushings - 5 speed | Page 2 | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Arvid, Jan 18, 2016.
  1. dstacy
    dstacy F1 World Champ
    11,998
    GMT -5 & GMT +1
    Dave
    Huh, so then how does the outer (#22) on the 365 stay attached? There isn't a clip, retainer, or anything shown in the parts book. There has to be something or you'd be pulling it and the knob off each time you went to 2nd, 4th, & reverse.
    Interesting.
  2. Arvid
    Arvid Formula Junior
    May 28, 2012
    668
    Norway
    Arvid Andersson
    I will try to remember that.
    I think the same parts,or an equivalent,is inside that lever too. It's just not posted as single parts. If you would to order part nr. 22 it comes complete,push on,drive :)
  3. Bill26
    Bill26 Formula Junior
    Jun 19, 2005
    258
    Australia
    Bill Murdoch
    #28 Bill26, Jan 23, 2016
    Arvid,
    The key to this puzzle is the nylon piece that looks like a crown. This is the retainer - the conical end faces down and the upper gear lever assembly is retained by the rounded castellations locating in the rounded ring at the base of the upper (chrome) gear lever.
    The upper lever can be removed by axial upwards force using a hammer puller screwed on to the gear knob thread or prising the retainer out using a home made tool that will fit in the gaps of the castellations. There is a lot of clearance between the nylon retainer and the lower shaft so it is not too much trouble to twist it out with the right sized prising tool. The picture below should give you an idea of what is needed.
    My choice is the second method - Good luck!
    Regards
    WM
  4. Arvid
    May 28, 2012
    668
    Norway
    Arvid Andersson
    Bill, this is great information and just what I was hoping to hear. I thought that sooner or later somebody would turn up that actually had done this repair.
  5. dstacy
    11,998
    GMT -5 & GMT +1
    Dave
    Ok, its been a while.....what is the verdict? Can this be done without pulling the console, tranny, etc?
  6. Arvid
    May 28, 2012
    668
    Norway
    Arvid Andersson
    Dave, it's been a long while but nothing regarding gear bushings has happened at this end. My car is fresh back from the shop so now the time is spent on detailing.
    When I do get around I'll sure report back and I'll put my money on the puller tool,Bill's second method.
  7. STEVO6667
    STEVO6667 Rookie
    Mar 15, 2015
    2
    Same parts as Fiat 131!
  8. willrace
    willrace Three Time F1 World Champ
    34,797
    North Tay-has
    Kurt
    Resurrecting this thread, checking to see if anyone has found a better method of removing that #@%^ing sleeve (part #22 in post 6)
    We've tried pulling from the top, levering from the bottom, combinations of both while trying to insert a pick to compress the little fingers inside, and no luck.
  9. willrace
    34,797
    North Tay-has
    Kurt
    Weekend bump, hoping for someone who has serviced/replaced this area during a restoration or rebuild will chime-in.
    Can't replace the deteriorated boot (part #38) with that sleeve in-place.
  10. Ak Jim
    Ak Jim F1 Veteran
    9,559
    North Pole AK
    Not really much help but what's easier, removing center console or pulling engine and trans? :)
  11. willrace
    34,797
    North Tay-has
    Kurt
    Interior is already fully out, so the whole shifter mechanism is exposed. Replacing the original, dried-out, and cracked #38 and #39 boots is one of those "while it's exposed, and right there...." opportunities. Just can't get that sleeve to cooperate!!!
  12. Ak Jim
    Ak Jim F1 Veteran
    9,559
    North Pole AK
    Where did you get the boots? At some point I'm going to pull the dash and center consol and would like to replace the boots along with other things.
  13. willrace
    34,797
    North Tay-has
    Kurt
    FerrParts. You have to be specific about #39, so it's not confused with the one for the automatic. Ask for Punu - he already knows, though we can't confirm on this end, since #38 goes on first........... and well.......
    Il Tifoso and Ak Jim like this.
