Gates 11M875 Belt Alternative | FerrariChat
Discussion in '308/328' started by Imatk, Mar 19, 2024.
  1. Imatk
    Imatk Formula Junior
    May 6, 2007
    661
    Trying to finish up this AC conversion and need a shorter belt for the smaller compressor.
    On other threads they mention using the Gates 11m875 which would be great if anyone had the thing in stock.
    Anyone know of a source for that belt?
    I have one on special order but it's not getting here until April. So if anyone knows of a supplier or an alternative belt that is 11mm x 875 mm I'd appreciate it.
  2. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,129
    SanFrancisco BayArea
    1983 US 308 GTS QV
    Bridgestone makes good belts too. Try Texas Belting and Supply.
  3. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    bitsobrits likes this.
  4. Imatk
    May 6, 2007
    661
    Thanks guys!
  5. Steve Magnusson
    26,516
    The tricky bit is the V-angle of the belt itself. Most automotive V-belts have a very small V-angle like 6~10 deg which "wedges" them into the V of the pulley groove and aids in preventing them from slipping, but eats up more hp as the belt has to be "pulled out" of the pulley groove as it exits. The Gates Industrial Polyflex belts have a very (unusually) large V-angle of 60 deg which minimizes hp losses (and why Ferrari select them for 308) and best for high speed application. You won't be able to read this:
    but go to page 30 in this catalog:
    https://www.gates.com/content/dam/gates/home/knowledge-center/resource-library/catalogs/power-transmission-catalog.pdf
    Please do let us know if you find any other manufacturer cross-reference for these oddball V-belts.
  6. Imatk
    May 6, 2007
    661
    I ordered one from Biedlers, but they are out of stock... apparently EVERYONE is out of stock on this friggin belt.
  7. bl10
    bl10 Formula Junior
    Jun 8, 2011
    437
    Chatsworth, CA
    Barry Leavengood
    I used a Gates 7340 XL as recommended by classic air. Its not a "skinny" belt but works fine. Got it on Amazon for $13 next day. Only potential problem is I have idler pully at full adjustment so if it stretches' it may slip. Had in on for 6 months and lots of hard driving with AC on with no problem.
    Barry
  8. Imatk
    May 6, 2007
    661
    Thanks for the info guys. I ordered the 7340... will be here tomorrow so fingers crossed it fits.
  9. Niklasbraun
    Niklasbraun Karting
    Nov 30, 2023
    54
    Nuremberg
    Niklas Braun
    I've also been using the Gates 7340 for a while now, and it's been great. I'm sure you'll be pleased with your choice too.
  10. Imatk
    May 6, 2007
    661
    For mine, the belt wouldn't fit into the groove on the pulley :/
    So I'm back to waiting for the other belt... supposed to be here April 2nd... sigh
  11. Steve Magnusson
    26,516
    Tried to tell you in post #5...
    Imatk likes this.
  12. Harry
    Harry Karting
    Nov 1, 2003
    101
    Germany
    The wide angle polyurethane belts (60 deg) are designed for industrial drive applications - high load, high speed, limited space. There are more manufacturers which produce these 7Mxxx belts, e.g. Bando (Banflex).
  13. BigTex
    79,321
    Houston, Texas
    Bubba
    The Gates Poly belts are not automotive...a deep search here may find my vendor.
    It's an A/C drive belt for electric fan motors.
    HTH
  14. Imatk
    May 6, 2007
    661
    The belt I took off was a Gates poly and I'm guessing had been on there for a VERY long time. The only "Ferrari" belt is nearly 200 bucks so if the belt snaps I'll just put another on at 35 bucks a piece.
  15. Ricambi America
    Sponsor Owner
    I don't understand this thread at all. These belts are in stock at nearly every Ferrari parts seller - and have been since post #1. Seems like a lot of work to potentially save a (in the scheme of things) not much money.
    When I'm working on my own cars (an old Alfa, a Cooper, or even my dull-as-dirt Subaru) I just buy the original part and get the job done. For me, I just don't have the patience or free time in my life to hunt around anymore. I frankly don't care what the part costs if it's the right piece. I only need to get my hands dirty once. Again, just my personal worldview.
    mike996 likes this.
  16. Imatk
    May 6, 2007
    661
    Well the belt is for a modified AC system that isn't the original. So that's the first reason. The second is... yeah over 100 bucks for a belt is hard to swallow.
  17. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    385
    Herts, UK
    Richard
    11m 875 is a standard A/C belt for Euro spec 328's.
    As mentioned before, you can buy exactly the same belt as a Ferrari dealer will sell you for 10% of the price, from Ali express...
    Just type in Gates 11m875 and look for the Funan official store. $22, delivered!
  18. Imatk
    May 6, 2007
    661
    Ahh didn't know that. I have one coming... will be here next week.
