Gasket sealer for oil sump covers? | FerrariChat
Discussion in 'Technical Q&A' started by Cadillacbart, Oct 5, 2016.
  1. Cadillacbart
    Cadillacbart Formula Junior
    Nov 26, 2013
    436
    Denver, CO
    1988 Mondial 3.2
    I'll be finishing up my shift shaft seal replacement this coming weekend. Recommendations on sealant to use (if any) with the new pan gaskets?
    Thanks,
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,905
    Isle of man- uk
    Why use any if its a new joint.
  3. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    A couple of us were discussing this the other day with a tech from Maranello Concessionaires, the main UK official agent and they use CAF4 which is specified by Ferrari.
    I have previously used Loctite 518 on there but with not 100% success. Maranellos use CAF4 where there is a gasket and 518 for direct metal-metal.
    The factory didnt use anything originally and they leaked.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,905
    Isle of man- uk
    If u do decide to use something, try loctite flange sealant- i dont have the number but we occasionally use it on the diesel rebuilds. You dont want anything too strong or you will never get it off next time.
    Use very little sealant or the excess will end up in the sump and then get deposited in the suction filter.
    Avoid Hylomar as it goes off before you have chance to fit it.
  5. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    #5 NW328GTS, Oct 12, 2016
    Hondabond or Permatex is commonly used in automotive and motorcycle shops...
    Get a tube of either Hondabond HT 08718-0004 or the Permatex Ultra Grey, which should cover almost everything with a gasket, and a can of Honda Ultra Flange 2 08718-0009 for gasketless oil pans.
    A line of silk thread in the sealer around the perimeter on gasketless pans will stop seeping
  6. Cadillacbart
    Nov 26, 2013
    436
    Denver, CO
    Hondabond is what I ended up using. I've had success with it on my 928 over the years and thought it should work here as well.
    That said, still very interested in different options- keep 'em coming!
  7. JCR
    JCR F1 World Champ
    10,763
    H-Town, Tejas
    Silk thread? I've heard dental floss used on engine cases (motorcycle & VW/Porsche)
  8. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,316
    Palos Verdes
    Vince V
    Another vote for Hondabond here. Great stuff.
  9. DANCER308
    DANCER308 Formula Junior
    Oct 24, 2009
    935
    KY
    Dan
  10. vinuneuro
    vinuneuro F1 Rookie
    May 6, 2007
    2,574
    Chicago
    Vig
    Are Hondabond and Permatex Ultra Grey the exact same product? I've never come across a definitive answer. I've used both with success.
  11. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    Leak proof?, A weld bead ��
  12. chris marsh
    chris marsh F1 Veteran
    5,742
    Detroit
    Chris Marsh
    Hylomar, nothing else. (I think Hondabond is just RTV. Maybe Hi-temp RTV but RTV non the less.) Hylomar is non-hardening, you put it on, it dries to a rubber like consistency then you assemble.
    Hylomar
    Hylomar was recommended to me by an old German guy that built racing engine for my Porsche. When I went to pick up the motor I was looking around his office; apparently he had a lot of success building Rolls Royce Merlin engines for racing aircraft in addition to auto racing. He said he will not use anything but Hylomar.
  13. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    The trouble with the pans (motor and gear) is that the oil seeps out from around the studs. Several members in this site have chamfered the stud holes in the covers then put 6mm ID O'rings on all of the studs. I did that years ago on my 328 and I can attest that it does not leak. I chamfered so the o-ring went about half of its thickness down.
  14. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,323
    Honolulu
    Kevin
    I don't think Hondabond dries hard but I never taken anything apart after I fixed with it!
  15. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,381
    San Carlos, CA
    Mitchell Le
    I was a fan of Hylomar until they changed their formula. It is much too hard to apply evenly and also very hard to find
  16. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    You are correct. It dries harder than silicone but it's still flexible. Great stuff.
    sturrisi likes this.
  17. fatbillybob
    Aug 10, 2002
    28,549
    socal
    30 years and I have been all over the map and around again. I used to love hondabond but ran out when honda was closed. I quickly sourced some hightack (like aviation no.3). Then i started using hightack again. What I liked is sealing is perfect resists oils, easy clean up with acetone, almost never hardens but the longer it sits and hotter it cycles the harder it gets. Aviation hardens more then hightack. Both are messy. Neither will clog an oil gallery like an rtv. Hondabond is like an rtv with sawdust so it dries less stringy than rtv but had 90% of rtv sealing. Critical things about sealers to me are ease of clean up, fouling ability, ease of part disassembly, and operating temperature range. There is no 1 size fits all.
  18. Prugna
    Prugna Formula 3
    2,005
    Northern California
    Yamabond is an alternative, but I use the GM oil pan sealant that is now used by GM instead of oil pan gaskets themselves.
  19. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
    Hondabond is good stuff
  20. patknapp14
    patknapp14 Karting
    Aug 24, 2016
    226
    Menasha, Wisconsin
    Patrick Knapp
    While were on the topic of sealer, I haven't seen much mention of anaerobic sealer. I source it from my local Napa. I've used it on a number of applications from sealing washers to drain plugs etc. It's worked great on several of the vintage cars here when I was wrenching. I loved it so much that I keep it at home for use on my vintage Harley Davidsons. (If you thing a vintage Ferrari leaks, try owning a early Harley!)
    Some great info in this thread guys!
