Gas tank vacuum | FerrariChat
Gas tank vacuum
Discussion in '308/328' started by santon, Jul 26, 2017.
  1. santon
    santon Rookie
    Hi, new to the group and i can say i have found many helpful threads here. I have a 1987 328 GTS and the issue i am having is that everytime i go to refill the car and remove the cap there is a incredible amount of vacuum in the tank. Is this normal on these cars or is there something i should be checking. All the fuel lines seem to be in good shape.
  2. SaratogaCA
    SaratogaCA Formula Junior
    Sep 11, 2016
    319
    Saratoga, CA
    Sam T.
    I have an '83 308 GTS QV and I get that, too. So I wondered about this as well.
    Let's see if other people chime in.
  3. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    No vacuum in my '87. I do not recall ever hearing it hiss (original owner) but have heard it in other vehicles of mine. So I do not know whether a vacuum should be present with this vehicle or not.
  4. Aus_yz
    Aus_yz Karting
    Sep 5, 2015
    51
    Australia
    Mika
    No vacuum in my 84 GTS QV fuel tank either
  5. ModenaInv
    ModenaInv Karting
    154
    South West Michigan
    Dave
    No vacuum on my 84 308. But it is a slow process filling the car up with fuel. I don't think they vent well while refueling. Wondering if it's related to the vacuum issue?
  6. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Guys check your emission system. The tanks should vent when you turn the engine off . That's part of the charcoal canister system. The gas cap is non-venting unlike the earlier carb cars.
  7. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Depends if its a US or Euro car. Euro have a vent pipe open to air.
  8. Steve Magnusson
    26,507
    What version/status is your 328? US, CH, Euro, Euro correctly modified for US importation, Euro originally converted for US importation then remodified, etc.?
    Euro are always vented to atmosphere as Andy indicated (via an open tube on the filler neck) so they should never have pressure nor vacuum in the fuel tanks. On the US version, the charcoal canister both lets fresh air in if a small vacuum develops or lets air out thru the charcoal bed if a small pressure develops, but the valving doesn't operate with no pressure differences so a little vacuum or a little pressure is normal. Since you say "incredible amount of vacuum" have you looked at the walls of the fuel tanks to see if any have buckled inward?
  9. santon
    santon Rookie
    I did take a look at the tank walls and they seem to be fine. I will have to check the charcoal canister system. It is a U.S. spec vehicle. I just got the vehicle so i do not know if this is normal or not. One thing i have noticed is that if i leave the cap loose a bit (experimenting) it does seem to run better than if i have the gas cap tight.
  10. santon
    santon Rookie
    The car is a u.s. spec 87 328 GTS. I didnt know if the cap was vented or not. I did check the tanks and neither one shows signs of buckling. I did take a look at the venting / charcoal canister layout (parts diagram) and the way it is laid out i dont even see what could fail in the system. One thing i did notice is that if i leave the gas cap loose it seems like the car runs better than if i keep it tight.
  11. DGS
    DGS Six Time F1 World Champ
    69,596
    MidTN
    DGS
    I haven't been over that part of my 328 (either on the car or the parts list), but I had the tank vacuum issue on my '79 Alfa Spider.
    On the (SPICA) Alfa, tank pressure would be vented through the charcoal cannister, but vacuum would draw air through a one-way vent in the fuel lines in the trunk area. When the little plastic vent failed, the tank developed vacuum. But the SPICA Alfa has a weird fuel system, as it constantly circulates fuel to the injector pump and back, a bit like an aircraft fuel system.
    I'd expect there to be a similar one-way valve somewhere in the US 328's fuel system, to let air in without letting gas vapors out.
    I have seen there's a cannister assembly above the right hand tank, on the parts diagram, but I haven't delved into the functions of it.
  12. santon
    santon Rookie
    this upcoming weekend i will go over the entire vent system to see if anything is wrong. The only mechanical part is called a two-way valve on the parts listing ("two way valve?" Thats a thread all on its own!), and go over every inch of vacuum tubing.
  13. Dr Tommy Cosgrove
    36,228
    Birmingham, AL
    Tommy
    Wonder if that is tough on the fuel pump?
  14. mwr4440
    57,708
    Bavaria, The 'Other' Germany
    Mark W.R.
    I have a vacuum situation on my 1981 NA GTSi.
  15. jlc308
    jlc308 Karting
    Jul 11, 2009
    121
    Irvine CA
    Any updates on this? I also have a vacuum build up
  16. ZOOOOMZ
    ZOOOOMZ Karting
    Aug 14, 2013
    248
    Austin, Texas, USA
    Tim Cronin
    FWIW: I can report that I have neither vacuum nor pressure in the fuel tanks on my September 1988 US Spec 328 GTS. It would have shown up on the 1700 mile eclipse watching trip I just drove. :)
  17. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
  18. jazaroo
    jazaroo Rookie
    Nov 22, 2006
    10
    Yeah, I have a US spec 1988 328GTB and I get the vacuum as well, never caused an issue with my car, that I can tell, I've had it since new.
  19. johnk...
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    If you guys are actually getting vacuum in the tanks you have a problem. The valve I pointed to in post 17 does not allow vacuum. It allows the tank to suck air into the tank through the charcoal canister. And it only allows pressure to build to 0.05 bar. So, if you actually have vacuum you have a problems somewhere in the system.
  20. mello
    mello F1 Veteran
    5,432
    CA Bay Area
    Steve
    try removing the charcoal canister and whack it a few times. The charcoal settles and pack like sand given time. This will loosen the charcoal to allow better ventilation.
  21. jlc308
    jlc308 Karting
    Jul 11, 2009
    121
    Irvine CA
    Thanks for the info and diagram. My car is 85QV and cannister appears to be the same. I notice on the diagram that there is a line that connects to the intake plenum which I assume would be drawing air from the cannister thru the fuel tanks. Therefore is this causing a buildup in the tanks?
    Would it be ok if I disconnect the vacuum line to the plenum and plug the plenum connection or am I creating more problems?
    Other option can the cannister be eliminated and just reconnect the vacuum lines?
  22. Archer911
    Archer911 Formula Junior
    Sep 26, 2016
    907
    New England
    Tim
    I have a related problem. When I bought my 84 308GTS almost a year ago it wouldn't take fuel-kept chucking it back. I replaced the fuel lines (had to drain the tanks) and the problem went away. Now it's back and the car is running poorly.
    I have determined that fuel is not flowing between the tanks. I have a feeling it's must be in the vent lines as referenced in previous responses.
  23. johnk...
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    The canister is vented to the atmosphere. Plenum sucks air through the canister from atmosphere, thus purging the vapors stored in the canister. Tank also draws air through the canister and should never have a vacuum in it if the vent line, valves and canister are in proper working order. The tank may pressurize slightly and will vent over pressure out through the canister as well, provided the check valve is working properly.
  24. Archer911
    Sep 26, 2016
    907
    New England
    Tim
    Right, so if there is any obstruction in those lines or the check vale has failed it could result in a problem with the fuel delivery system.
    Assumptions:
    In order to put fuel into the tanks air must escape.
    In order to pull fuel out of the tanks air must enter the tanks.
    If these assumptions are valid I think my situation involves both those scenarios.
    Will start in on inspections tomorrow.
    Thanks Johnk
  25. johnk...
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    The problem with filling is common and not related to those valves. It's simply that with some pumps you can fill the left hand tank faster than fuel can be transferred to the right hand tank, especially as the tanks get fuller. The problem can be mitigated to some extent by not inserting nozzle into the filler neck too far, angling it in a different orientation and not trying to fill at the fastest nozzle setting. I've experienced the same problem, over my 32 years of ownership, since the car was new.
    If you have a problem with the way the car is running, I'd look elsewhere. Once there is fuel in the tanks, the fuel pump is going to determine the pressure in the supply line to the injectors unless there is something preventing fuel from getting to the pump.
