360 - Gas Struts for Front Hood/Boot Lid | FerrariChat
360 Gas Struts for Front Hood/Boot Lid
Discussion in '360/430' started by Need4Spd, Feb 25, 2019.
  1. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    The gas struts on my car (‘03) are having difficulty keeping the front hood/boot lid open. See part number 7 in this diagram. I know it’s not a lot of money in the scheme of things but since they’re $121 each, anyone have alternatives to OEM replacements?
  2. Fort Worth 360
    Fort Worth 360 Formula Junior
    Jan 3, 2008
    409
    Fort worth Texas
    search amazon - measure them and search
  3. Dicecal
    Dicecal Formula 3
    1,844
    Phoenix, AZ
    Rob
    Found them a lot cheaper from eurospares..take a look there.
  4. sierra055
    sierra055 Formula Junior
    359
    Melbourne, AU
    Marshall
    The actual manufacturer is a company called Stabilus. I was able to buy the front hood in an identical size locally. Cost was around $40AUD.
  5. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Im not sure if its the same as F430 but mine is going dead too so I replaced mine a year ago now.
    I believe I paid $52.00 each at Scuderia Car Parts USA.
    Very easy to replace. No need to remove the nut holding the strut. Just pull the clip to release the dead strut, then snap the new one in.
    Hope that helps.
    Dan
  6. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Lots of good advice. Thanks!
    one4torque likes this.
  7. hessank
    hessank Formula 3
    1,866
    Canada, Florida
    Fred
    If you know your spec (type of ends i.e. ball or socket, compressed and extended lengths and Force) you can get them at
    www.liftsupportsdepot.com(no affiliation). Also allows for stronger or weaker units e.g if you added a spoiler to the back.
    I have used them for several times in the past
    cavlino and whatheheck like this.
  8. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    So hopefully someone has a part number for a suitable non-OEM replacement. Ricambi no longer has any, and alternative suppliers now charge a fortune for remaining stock.
  9. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Aha! Same part number is listed by Ricambi for both 430 coupe and 360 spider. So this part listed for 430 should work.
    kes7u likes this.
