Gas Cap Stuck Shut | FerrariChat
Gas Cap Stuck Shut
Discussion in '348/355' started by RossoCorsaItaly, Mar 28, 2009.
  1. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,676
    LA & OKC
    Kevin
    Haven't driven the F355 in 2 days, it was abnormally cold today (29 f) and we saw a little bit of snow (car is parked in garage). When the snow cleared up, I went to get gas and my gas cap is stuck shut. I had some of my stronger friends try to open it and the thing will not budge.
    Anyone have any tips to try to get this thing open?
  2. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Does the 355 have an emergency release cable in the engine compartment, like the 348 has?
  3. RossoCorsaItaly
    4,676
    LA & OKC
    Kevin
    For the fuel door yes, but the gas cap itself is stuck shut.
  4. zero
    zero Guest
    Apr 24, 2007
    776
    #4 zero, Mar 28, 2009
    Mmm i used to have this, screw on cap right;). How i undid mine and top tip, was to put on a leather pair of motorcycle gloves so i could get a good grip on the cap. Be sure to dry the cap first. The gloves also help gain leverage. Try that with biker gloves or thick gauntlets.
    From that moment on i always smeared a little grease on the threads of both screw on lids of the fuel cap and the oil cap which can also get stuck. Never had the problem sinCe.
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Spray some WD-40 behind the cap, trying to aim the little straw tube at the threads/back-of-cap.
    Tap on the cap.
    First, attempt to tighten the cap just a smidge, then see if she'll loosen (best done with leather gloves).
  6. Intheflesh
    Intheflesh Formula 3
    Jun 2, 2006
    1,180
    Salem NH
    John T
    When this happens, I use a plumbers wrench
  7. zero
    zero Guest
    Apr 24, 2007
    776
    #7 zero, Mar 28, 2009
    Huh! How does that work with a sunken cap, without damaging the paint work? What plumers wrench are you using that will fit the tight space effectively?
  8. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    I also had this problem - find the stickiest gloves you can... it will come off.
  9. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,948
    MD and NE
    Robbie
    Get a blow torch and heat it.....Oops, my fault....:D
    Seriously, seems the way it is designed only a good grip and muscle will get it off. You may be able to get a large set of pliers on it or a Vise-grip at an angle, but will probably scrape up the cap...
  10. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    There may just be a very thin film of ice in the cap threads. Get a hair dryer (which every F355 owner has along with hair gel) and set it on high. It it doesn't work then resort to more drastic methods. I apply a very, very thin coating of copper-based anti-seize to all my threaded caps. Good luck, Kevin.
  11. milby1
    milby1 Karting
    May 26, 2008
    191
    lol at the hair dryer reference!
  12. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,424
    CT
    Jay
    I learned this too...don't over-tighten. Makes for an embarrassing scene at the gas station...
  13. yellow 355
    yellow 355 Formula Junior
    Mar 25, 2005
    503
    ocean city,nj
    Ben Murphy
    Heat the cap up with the dryer...Then spray wd40 around the seal then heat again..with gloves it will come off...
  14. Dohangs
    Dohangs F1 Rookie
    Oct 31, 2008
    3,113
    Florida
    Spiro
    Had this happen to me at a gas station, couldn't get it off so I left. Kept trying by using both hands to turn the knob. Finally got it off. I think there was a lot of pressure built up which kept it from being able to be untightened.
  15. cuneo
    cuneo Formula 3
    2,454
    Let her cool down fully and it'll come off. I think the fuel filler receptacle is what heats up causing expansion. Don't screw the cap on too tight when replacing after gassing up, this worked for me on a 95 GTB. Same goes for the oil filler cap.
  16. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    39,699
    Huntsville, AL., USA
    Andrew
    If he really needs to heat the cap, a safe way to do it might be to get a small hot water bottle and hold it against the filler cap.
    Of course, if it's internal pressure (mentioned above) - and not actually a case of cold weather conditions - causing the problem , then it might not help.
    Let us know how you get on - and good luck! :)
    All the best,
    Andrew.
  17. Mr Dobermann
    Mr Dobermann Karting
    Jul 31, 2005
    162
    You could always cut it loose with a Plasma-cutter... Moahahahahaaa... :p
    Kimmo.
  18. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
    Start the car and let it warm up for about 15 minutes, take it for a quick drive, then try to unscrew it.
  19. cuneo
    cuneo Formula 3
    2,454
    sorry for the stupid post, duh. Wasn't too sharp last night.
  20. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    haha - very honest... I don't know how many times I've wished that damn 'edit post' button was still active....
  21. NeuroBeaker
    Moderator
    Oct 1, 2008
    39,699
    Andrew
    RossoCorsaItaly,
    How's it going? Did you manage to get the cap off or is it still refusing to budge?
    All the best,
    Andrew.
  22. RossoCorsaItaly
    4,676
    LA & OKC
    Kevin
    I got it off.
    I got a pair of gloves, WD40, and a hair dryer. I sprayed the WD40 on there and spent 10 minutes trying to budge it lose with the gloves and shortly after a friend of mine showed up who is stronger was able to get it off. We then used the hair dryer in typical F355 owner fashion for the rest of the day styling each others hair. ;)
    Thanks for the help and suggestion guys!
  23. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    You need to press down hard on the cap to get the pressure off the threads while unscrewing the cap. It works for me 99% of the time, every time!
    :D
    BT
  24. NeuroBeaker
    Moderator
    Oct 1, 2008
    39,699
    Andrew
    Good to hear your Ferrari will be able to get a drink now. ;)
    All the best,
    Andrew.
  25. RossoCorsaItaly
    4,676
    LA & OKC
    Kevin
    Always do push down, this was that 1% case where it was not enough.
