Garage:Heated vs A/C vs dehumidified | FerrariChat
Discussion in 'General Automotive Discussion' started by Countachqv, Sep 3, 2014.
  1. Countachqv
    Countachqv Formula 3
    Apr 25, 2007
    2,350
    USA/France
    I wanted to know what people think is the best value for spending money on in a garage to store cars.
    Many are boasting heated garage but i dont quite get why other than not freezing your but tinkering in winter.
    I would think what matter for a car is :
    1. To be protected from air polution.
    2.To be protected from the sun U/V
    3.To be protected from moisture
    4.to be protected from roddens
    So it appears to me that a well kept garage that does not let the sunshine hit the cars and has a dehumidifier should be enough for car storage. I cant see what A/C or heat would bring.
    Am I missing something?
  2. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,776
    Dubai / Bologna
    A good question.
    I once had an old MB I kept in an unheated garage that was not airtight. I lived in Canada at that time and the cycle of freezing and thawing over the winter caused condensation to build up on the alloy parts which corroded.
    I would think a garage should be airtight in a damp, cold climate and dehumidified.
    I am not certain that a car, if properly winterized, would suffer if the ambient temperature was below freezing so long as it was out of the sun and reasonably dry.
  3. Countachqv
    Apr 25, 2007
    2,350
    USA/France
    good point. Garage must be remain above freezing temps.Thus attached garage are better
  4. leead1
    leead1 F1 Rookie
    Nov 29, 2006
    2,828
    Florida
    Lee
    I have all of my cars in a 20X40 garge without AC or heat. As you can tell from my profile I have several cars. I have been storing like this for about 11 tears.
    I live in central Florida so it is hot and humid most of the time. I am not sure if that is the right answer for all climates, or any climate. All of my cars are driven no garage queens :)
    Not that I know anything, I am just to cheap to put in AC
    Best
    Lee
  5. xs10shl
    xs10shl Formula 3
    Dec 17, 2003
    2,037
    San Francisco
    I'd say that "dry air" matters way more than "warm air". The less moisture in the air, the better. An AC is of course a dehumidifier, so an installation like that can kill 2 birds with one large energy bill.
  6. PaulK
    PaulK F1 Rookie
    4,768
    Michigan
    Paul
    I don't think A/C is that important, but in a really nice garage, it is a must. I would at least have a dehumidifier. I would also like to have heat in order to minimize temperature fluctuations.
  7. JOEA2
    JOEA2 Formula 3
    Feb 2, 2006
    1,218
    Staten Island, N.Y./ Sea Girt,N.J.
    Joe A
    #7 JOEA2, Sep 3, 2014
    I keep my Garage at 60 in the Winter and 76 in the Summer in New Jersey. My Utility Bills are reasonable and the Cars are PERFECT! Of course, the Garage is well insulated with insulated doors.
    Joe
  8. DennisForza
    DennisForza Formula 3
    May 23, 2006
    1,814
    Arlington, VA
    Dennis
    The big problem with air-conditioned garages is the condensation on unprotected/unpainted parts when you leave the garage when outside humidity levels are elevated. If you are in a dry climate it is fine, if you are in a high humidity climate, not so good.
  9. hans2
    hans2 Karting
    120
    Charlotte
    Humidity control is the most important consideration, especially for vintage cars lacking advanced corrosion resistance. I keep my garages at 55% RH 24/7 all year--not too dry to promote premature rubber/vinyl degradation. During summer dry heat is much more comfotable for wrenching than humid air. AC could achieve same result since they also dehumidify to a degree. Sub 40 temps not a big concern since colder air is relatively dryer. As mentioned, it's the temp cycling that causes issues, but a dehumidifier keeps all in check.
  10. 308steve
    308steve Formula Junior
    Sep 5, 2010
    302
    You might want to look into a mini-split system just for the garage.
  11. norcal2
    norcal2 F1 Veteran
    you also can use something like Carcoon or Permabag..that surrounds your car completely with a de humidify system instead of conditioning your whole garage/storeage area...
  12. Craigy
    Craigy Formula 3
    Mar 19, 2006
    1,679
    Louisiana
    Craigy
    With proper seal & circulation that shouldn't happen.
    One problem that does occur though in the fall & spring is high humidity in general... if the temp is set too high the a/c simply never comes on, especially with good insulation, and the humidity will creep up to match outside air.
  13. texasmr2
    texasmr2 Two Time F1 World Champ
    22,232
    Houston
    Gregg
    That's your garage, impressive!
  14. JOEA2
    JOEA2 Formula 3
    Feb 2, 2006
    1,218
    Joe A
    #14 JOEA2, Sep 11, 2014
    It's nine Cars and a 2500 sq. ft. Apartment above since it's in a Residential Area. After Sandy, friends lived there for a year while rebuilding.
    Joe
